MSH Brain Firmware Update inkl. Rescue - Probleme, Fragen & Erfahrungen
AW: MSH Brain Firmware Update inkl. Rescue - Probleme, Fragen & Erfahrungen
Das kannst jetzt aber nicht aufs Brain schieben. Wenn der TDR wieder vibrationsarm läuft, dann funtzt auch die Rettung!Zitat von Kami Katze Beitrag anzeigen
Ja geht mit dem v1Zitat von freakystylez Beitrag anzeigenWo ist diese Funktion? Geht ja auch mit dem Brain V1, oder?
Firmware 2.0.025, Windows Software 2.0.025, Android app 2.0.025 and JETI integration
As usual Software and Firmware update will be automatic and system will prompt user to update once powered unit is connected to a Windows PC with internet connection active. The same for the Android app from Play Store.
Release Notes:
- 2.0.025 (Firmware 2.0.025)
- Jeti EX Bus receiver protocol added with specific channel assignation
- Jeti Connection schematics added
- Jeti transmitter integration with Brain parameters configuration menu (only Brain2)
- Added swashplate HR3_135
- On the top bar added 4 icons for the fast selection between Basic, Advanced, Counters, Diagnostic
- Added Tail gear ratio in Governor (basic & advanced)
- In the vibrations panel added vertical bars for Main Rotor, Tail Rotor, Engine actual RPM
- In the vibrations panel added actual values of Main Rotor and Engine
- Changed event "Power Voltage below 12,5% than startup" to "Power Voltage below 16,6% than startup"
- Now real time vibrations work also on Atom PC and slow PC
- Now when a log is loaded from the unit also the vibrations are downloaded and vice versa
- Corrected for iKon the connection schematic for SUM/SRXL/UDI/Xbus-b
- In the page 1 of the wizard added also the kind of unit connected information
- When Rescue is active, Rescue Gain is fixed and no more editable
- In the Transmitter monitor (basic & advanced) the label "Gain" was changed to "Tail Gain"
- When one of the logs is downloaded from the unit, remain in memory until the end of the session. Changing logs is no more needed to download again the precedent log
- Now AUX channel for Auto Level/Rescue is again usable with standard receiver
- Events downloadable also without sample rate selected (pay attention to download only after the initialization end)
- In the Firmware update windows added on top bar the actual Firmware version of the unit
- In Advanced -> Servos if you select for Type "None" the check is removed from "Reverse"
- -Rescue pitch maxâ? and -Rescue pitch durationâ? are enabled only if "Use Rescue" is checked*
- "Auto Level gain" is enabled only if "Use Auto Level" is checked*
- In panel 6 "Swashplate type selection" of the Wizard if "CW ROTOR ROTATION" is selected, the Tail Asymmetry is set to +5, if "CCW ROTOR ROTATION" is selected the Asymmetry is set at -5.
- Maximum gear ratio allowed values for Main and Tail is now 32.500
- In Advanced -> Common re-added the "Orientation" menu but now with only one drop down menu with the 16 allowed positions
- Now when the application start, the windows is at full screen
- New French translations
- Some instructions corrected / completed
- Small bug fixes and optimization of code
For Jeti integration, from -http://www.msheli.com/en/MSHeli-Protos-Flybarless-System/downloads" download the BRAIN.ZIP file and unzip it, it contains an explanation README file and a BRAIN.bin file to load in to the Jeti transmitter.You can't make it safe, because fools are too innovative!
Sie haben im Nachbar Universum mal gesagt das die Refu ähnlich des Spirit werden soll.
Sprich inverted Flug,Refu, er dreht nicht sondern steigt inverted.Und noch paar andere Sachen
Was macht denn so das neuste Update aus dem Heli?
Sollte man vorher das Setup sichern? Habe gesehen jetzt ist viel auf deutsch übersetzt, aber eine Seite weiter auch wieder Englisch, also die D-englisch ßbersetzung
, und die obere Hauptleiste ist neu gestylt. Bei der Rettungsfunktion scheint es immer noch keine Kalibrierung wie beim Beast plus z. B. zu geben.
GruÃ? Alex
kurze Frage. Ist der Brain2 mit einem Futaba 7008SB Empfänger kompatibel? SBus oder SBus2?
Ich bekomme die Kanäle nicht zum laufen.
LG"Kann mir mal bitte wer das Wasser reichen!"
Ist kompatibel. Ich habs unten beim Sbus2 Steckplatz angeschlossen, funktioniert einwandfrei.Zitat von NewUser Beitrag anzeigenkurze Frage. Ist der Brain2 mit einem Futaba 7008SB Empfänger kompatibel? SBus oder SBus2?
Evtl. nochmals den Empfänger auf Sbus umstellen
- Link Knopf drücken
- Empfängerstromversorgung einschalten, dann Link Knopf loslassen
- mit blinken wird der aktuelle Mode angezeigt
- falls nicht korrekter Mode, Link Knopf drücken bis die rote LED 2 mal blinkt (Sbus mode)
- Link Knopf mindestens 2 Sekunden gedrückt halten
- LED sollte dauernd leuchten
- Empfängerstromversorgung ausschalten
Gruss, Leo
Dann zeig mal Deine Verkabelung
Findet die Software das Brain?
Initialisiert der Regler?
Funktionieren die Servos am Empfänger (ohne Brain)? Läuft der Motor an?
So ohne zusätzliche Informationen ist es schwierig, da weiter zu helfen. Vielleicht solltest Du mal schreiben, was Du genau in welcher Reihenfolge gemacht hast.
Gruss, Leo
Empfänger ans Brain angeschlossen, Software gestartet. Alles geupdatet alles wird gefunden.Im Setupprogramm richtigen Empfängertyp eingestellt und das Brain nach Anleitung verkabelt. Ich verwende SBus2 habe auch schon mit SBus versucht und auf Mode B umgestellt.
Im Schritt 4 (Transmitter Setup) stehen jedoch die Kanäle für Aileron, Elevator, Tail, Pitch & Gain auf 0% und bewegen sich nicht, wenn ich an den Knüppeln rühre. Throttle, Aux & Current Setup funktionieren jedoch einwandfrei. Ich habe im erweiterten Menü die Kanalzuordnung geändert. ßndere ich den Kanal für Throttle funktioniert dies. Aber wenn ich den Kanal wieder für z.b. Roll verwende bleibt wieder alles auf 0% unverändert stehen.
Wenn ich das Brain einschalte leuchtet die rote LED kurz, dann die grüne kurz. Danach blinkt die rote LED 3 Mal wiederholend. Alle Servos fahren in Mittenposition und bewegen sich danach nicht mehr. Servos funktionieren, Regler funktioniert und man kann auch den Motor fahren. Empfänger funktioniert auch.
Ich habe mir jetzt einen anderen Empfänger R6303SB gekauft. Vielleicht funktioniert es damit...Zuletzt geändert von NewUser; 12.09.2016, 08:43."Kann mir mal bitte wer das Wasser reichen!"
