Graupner MX 16 Hott - Spektrum Erweiterung
  • floflo
    floflo
    AW: Graupner MX 16 Hott - Spektrum Erweiterung
    Ok this time I don't understand anything!
    It worked once, and now it is back to the way it was!
    -I succeeded to bind the mcpx in the non programmable radio mode, but it was doing things really strange!
    -I succeeded to bind another spektrum receiver that was working perfectly
    -So I tried to bind the mcpx in programmable mode and it didn't work
    Now nothing is working anymore!
    PS It is connected to a mx 20 and I did the exact same connection you did
    Zuletzt geändert von Gast; 14.01.2012, 23:45.
    • floflo
      floflo
      Is it normal that when I'm running the sketch with DE_BUG and I go to serial monitor I got just complete non sense??
      • mha
        mha
        • 10.10.2009
        • 1041
        Yes, that's ok. In debig mode debug data is output with 112500 baud. In non debug mode the baudrate is set to 125000. That's what the AMTX11 requires.
        Je älter ich werde, desto besser war ich.
        • floflo
          floflo
          Ok.
          I can't find what is wrong! I checked every connection and it seems to be ok!
          Do you think it is a problem of software or material?
          with the data streams I send you, could we be sure that the arduino is working normally?
          Because that would mean that the problem is after but the module is ok and I checked the 3 wires between the arduino and the module.
          I send you pictures of everything I made, maybe you will find something wrong!
          • floflo
            floflo
            I tried again, it binded with the mcpx, so I turned it off, put the bind jumper back turn the mcpx on again and nothing...
            • floflo
              floflo
              last attempt:
              The mcpx binded in programmable mode started normally,
              So I didn't touch anything and after 2 minutes or so, it stopped
              I waited 10-15 minutes, tried again and the exact same thing happened!
              Zuletzt geändert von Gast; 15.01.2012, 15:28.
              • mha
                mha
                • 10.10.2009
                • 1041
                From picture #1 it looks like you have connected VCC and RAW on the arduino board. There should be no connection. My drawing shows a non connecting crossing. If a connection was required, the crossed lines would have a dot.
                So +5V from the MX-20 must be connected to RAW. The AMTX11 is only connected to VCC. If I am right you fed 5V to the AMTX11. Hope it is not dead.
                Background: The Arduino board has an onboards 3.3V voltage regulator because the ATMEL micro is a 3.3V device. The AMTX11 is a 3.3V device too! So we feed the unregulated +5V from the MX-20 to the RAW pin. Behind the raw pin is a 3.3V voltage regulator that supplies the ATMEL and forwards the regulated 3.3V to the VCC pin. So in order to supply the AMTX11 correctly we have to feed it the 3.3V from one of the VCC pins.
                Zuletzt geändert von mha; 15.01.2012, 16:05.
                • floflo
                  floflo
                  #38
                  Ok it is working perfectly!!
                  Thank you so much!
                  And sorry about all my questions!!
                  • mha
                    mha
                    • 10.10.2009
                    • 1041
                    Was it the problem that you connected RAW and VCC?
                    • floflo
                      floflo
                      #40
                      Yes!
                      • Denny1
                        Denny1
                        #41
                        Ich spiele auch mit den Gedanken meine MX20 Hott mit zusätzlichen Spektrum Modul auszurüsten.
                        Nur blicke ich da noch nicht ganz durch.
                        Die Version von mha finde ich schon sehr gut und die Komponenten bekommt man sicher mit etwas Geschick noch in der Funke verbaut so das man nur noch mit externen Schalter umschalten kann.
                        Vieleicht kann mir da einer mal helfen.
                        Habe mir mal die MX20 innen mal angeschaut und unter den HF Modul der MX20 ist noch etwas Platz wo sicher das HF Modul von Spektrum rein geht, dem Rest bekommt man auch noch unter.
                        Löten ist kein Problem für mich nur möchte ich nix falsch verkabeln oder verlöten.
                        Bin für Hilfestellung Dankbar.
                        Mfg. Denny
                        • Denny1
                          Denny1
                          #42
                          Kann mir hiermit mal keiner unter die Arme greifen und mir etwas helfen.
                          Gibt doch sicher noch mehr Leute die umgebaut haben.
                          Mfg. Denny
                          • JMalberg
                            • 05.06.2002
                            • 22636
                            • J
                            • D: um Saarbrücken drum rum
                            #43
                            Ohne dass du beschreibst welche Hilfe du benötigst, können wir auch nicht helfen...
                            • Denny1
                              Denny1
                              #44
                              Also ich brauche ein Spektummodul was mindestens 6 Kanäle hatt, 8 währen besser.
                              Es sollte so klein wie möglich sein und ohne großen Aufwand, Zusatplatinen mit der MX20 zu verbinden.
                              Schalter ist kein Problem da kommt was an der Schüler Buchse ran womit ich die Mx20 auf Trainer umschalten kann, gleichzeitig wird das Modul eingeschaltet und mit Strom versogt.
                              Also Schalter ein Spektummodul läuft und die MX 20 geht auf Trainer oder Simulator Modus somit ist auch das MX 20 Modul deaktiviert.
                              Ich würde auch für beide Module die MX 20 Antenne benutzen wollen.
                              Ich brauche also noch einen einfachen Schaltplan und Anschlußplan.
                              Mit den hier aus den Tread werde ich nicht ganz schlau.
                              Mfg. Denny
                              • Denny1
                                Denny1
                                #45
                                Kann ich auch das Modul aus der DX6i nehmen und wie schließe ich es an?
                                Mfg. Denny
