Genau. Im Normalbetrieb wird die Stromversorgung direkt über den Schalter geschaltet, da ist das kein Problem. Wenns kritisch wär, hätt ich meine schon eingesendet
habe es bestellt:
<Silence> Spoilers Time Remaining HOLD NORMAL Stunt 1 Stunt 2 Stunt 3 Stunt 4 Stunt 5 Idle Up 1 Idle Up 2 Idle Up 3 Idle Up 4 Idle Up 5 MODE 1 MODE 2 MODE 3 MODE 4 MODE 5 MODE 6 MODE 7 MODE 8 MODE 9 MODE 10 Launch Cruise Land Thermal Speed Knife Edge Mode Rolling Mode 3D Mode Normal Mode General Rates Hammerhead Rates Stall Turn Rates Rolling Circle Rates Spin Rates 3D Rates High Rates Mid Rates Low Rates RPM Temperature Rx V Volts Ignition Amps Airspeed Altitude GForce JetCat F-Log GPS Distance Photo Click Low Battery System Idle Timer Expired Alarm Timer Start Timer Stop Timer Cleared Tele Start Tele Stop Canopy Attached Rx Battery Test Fuel Tank Full Hatch Attached Test Controls Wing Bolts Secured Air in Retracts Prop Secured Reset Timer Start Timer Flap Position Ing. Batt. Charged Fuel Plug in Place Flight Batt. charged Thro. Trim Position Gyro Initialized Gyro Gain Position Gov. Gain Position Glow Driver Active Blade Bolts Tight Student Control Instructor Control No student Signal Position Throttle Cut Gear Up Gear Down Off On Mix Off Mix On Mix Inhibited Mix Active Braking Release Flaps Up Takeoff Flaps Landing Flaps Tow coupling closed Tow coupling open Mix Inactive Smoke Off Smoke On Bomb Drop GPS Mode Attitude Mode Manual Mode Course Lock Mode Home Lock Mode Return Home Failsafe Smart Mode Stability Mode Agility Mode Indoor Mode Outdoor Mode Stability High Angl Stability Low Angle Altitude Hold Waypoint 1 Waypoint 2 Waypoint 3 Waypoint 4 Waypoint 5 Waypoint 6 Waypoint 7 Waypoint 8 Waypoint 9 Waypoint 10 Bailout Panic Self-Level Hover Mode Bank 0 Bank 1 Bank 2 Bank 3 Bank 4 Loiter mode Stabilize Mode Simple Auto Guided Mode Position Mode Return to Launch Circle Mode Head Tracker On Head Tracker Off Gimbal Control On Gimbal control Off Camera On Cmaera Off Video Start Video Stop Take Still
