Neue Heckgetriebe Outrage Fusion/Velocity50
  • Tomp
    • 07.01.2008
    • 437
    • Westendorf/Meitingen
    #61
    AW: Neue Heckgetriebe Outrage Fusion/Velocity50
    Zitat von Gala-Tante Beitrag anzeigen
    ENDLICH !!!!!
    Hier die erste offizielle Stellungnahme des Herstellers:
    [FONT="Georgia"]"For the last several months, some of our customers have been experiencing issues with tail gears. Since the workmanship of the gears was not consistent enough, some people experience these issues, while others didn't. Therefore, we have started to use a different vendor to produce new gears. As most of you know, it takes some time to make new products as well as test them to make sure they perform well.
    I really apologize for taking this long, but our new gears will be ready in stock within two weeks. In the mean time, we will continue working on improving them. We at Outrage are very proud of our products and their performance and we will continue to support our customers with spare parts or provide our customers with new products with better performance when the time comes. For example, we will have a new tail system for the Velocity 90 within 3 weeks. The new Velocity 90 tail is completely redesigned and addresses all the issues that are currently present on that model.
    Thanks again for being patient and supportive of our products, rest assured that we will work much harder to earn your trust."
    [/FONT]
    Also, in 2 Wochen ist Weihnachten!
    Christian
    So, zwei Wochen sind um.
    @ Dino,
    hast schon Info zu den Rädchen?
    Protos MAX V2, T-Rex 700N
    • Madness
      • 17.08.2008
      • 2700
      ßber die Info´s kann man langsam nur noch lachen....
      Outrage hat´s damit echt verbockt und kommt bei mir gleich hinter Futaba mit der Telemetrie
      • Madness
        • 17.08.2008
        • 2700
        Doppelpost
        Zuletzt geändert von Madness; 03.10.2012, 12:10.
        • chaoscycle
          • 26.09.2009
          • 196
          • ben
          • Belgien
          #64
          @ all
          Wie gesagt - schade das Aufgrund der Zahnradprobleme die Mechanik fast Wertlos ist. Da ja jeder das Outrage Problem kennt und mit Ersatzteilen es auch nicht so weit her ist.
          Danke für die Infos, ich werde die Zahnräder mal vermessen und sie aus Alu Testweise nachfräsen lassen, mal sehen ob somit diese Kinderkrankheit behoben werden kann.
          Wird aber erst erfolgen wenn ich auch die Baupläne der anderen Teile fertig gestellt habe.
          Weil das Fräsen kostet au bisschen
          LG Ben
          [FONT="Arial Narrow"]Glücklich sein: Hauptsache Spa� beim Fliegen! Fly Safe and have Fun
          Benjamin
          [/FONT]
          • Luckylouds
            PSG-Dynamics
            Support
            • 14.02.2010
            • 3023
            • Dino
            • Heilbronn und Umgebung
            #65
            Hallo Ben,
            Alu geht nicht.....viel zu hoher Reibwert.
            Nimm POM ( Delrin ) ist gut und günstig.....und hält auf jeden Fall.
            Grüße Dino
            Zen...
            • David Tobias
              • 17.01.2007
              • 1648
              • David
              • Schwäbisch Gmünd
              #66
              Gibt es bezüglich der von Outrage angekündigten Teile schon Infos?
              Hat jemand schon den Riemenumbau von Helifreak.com nachgebaut?
              Grüßle
              David
              • Luckylouds
                PSG-Dynamics
                Support
                • 14.02.2010
                • 3023
                • Dino
                #67
                bei der Peter Schmid GmbH mit der ich zusammen arbeite, wurden die Zahnräder schon kalkuliert und auch schon an Outrage angeboten......
                MADE IN GERMANY hätten se gerne gehabt, aber es war ihnen leider zu teuer.
                Wenn ich gewusst hätte wie lange sich das zieht, hätt ich einfach mal 100 Satz fräsen lassen, vielleicht wäre ich dann heute schon ein reicher Mann..
                Was ich damit sagen möchte ist eigentlich nur folgendes, da ich selber einen Fusion 50 fliege und es eigentlich schade fände wenn die Helis vom Markt verschwinden wäre es durchaus möglich da etwas machen zu lassen.
                Kommt eben drauf an wer bereit ist ein paar € mehr für die Heckzahnräder zu bezahlen.
                Grüße Dino
                Zen...
                • Daniel.N
                  Daniel.N
                  #68
                  Hey leute,
                  Wollte mal nachfragen wo genau das problem liegt? Hab schon lang nicht mehr hier gelesen und flieg seit monaten meinen fusion ohne probleme, der heli hat sich zu meinen lieblings heli entwickelt, gerade weil er so robust ist und alles mitmacht. kann also irgendwie nicht verstehen warum die leute hier ihren heli die ganze zeit unterm tisch stehen lassen. Also wenn ich irgendwas verpasst hab lasst es mich bitte wissen.
                  MFG Daniel
                  • Tatum
                    • 21.12.2010
                    • 448
                    • Alexander
                    #69
                    So es ist fast vollbracht. Hab erstmal das Heck gegen Align (H60123T) getauscht mit Abstandsscheibe 0,2 mm aber das kennt ja schon jeder.
                    Mfg Alex
                    Wer nicht fliegt kann auch nicht abstürzen ;-)
                    • Tatum
                      • 21.12.2010
                      • 448
                      • Alexander
                      #70
                      Als nächstes ging es an die eigentliche neue Baustelle das vordere Getriebe. Dort hab ich erstmal die alte Welle ausgebaut und nur das Kegelzahnrad entfernt. Das Antriebszahnrad brauchen wir ja noch weil das verwendete Heckgetriebe von Align (H60228T) ja Modul 0,8 besitzt.
                      Bevor man jetzt das weisse Rexzahnrad montiert muss man sich um die Torque-Tube kümmern.
                      Mfg Alex
                      • Tatum
                        • 21.12.2010
                        • 448
                        • Alexander
                        #71
                        Bei der Torque-Tube brauch man fast nix ändern. Die länge des Rexrades ist zwar länger, aber der innere Anschlag ist unser Problem. Durch diesen kommt das Kegelrad wesentlich weiter heraus. Es sind so 12mm genau bei mir. Dies stellt eigentlich kein unbedingtes Problem dar, da das Heckrohr dann eben etwas weiter raussteht. Da wiederrum ist dann aber das eigentliche Problem nämlich die daraus resultierende zu kurze Heckanlenkung. Dazu hab ich etwas gegrübelt und bin jetzt darauf gekommen das ich einfach die torque tube versuchen werde zu kürzen.
                        Stay tuned :-P
                        Mfg Alex
                        • Tatum
                          • 21.12.2010
                          • 448
                          • Alexander
                          #72
                          Wie schon gedacht hab ich die Torque-Tube gekürzt. Von dem aluadapter musste ich etwas Material abnehmen weil er nicht wieder in das gekürzte Alurohr reibwollte. Ist aber nix wildes da alles aus Alu ist.
                          Und siehe da das Heckrohr geht wieder bis Anschlag rein.
                          Mfg Alex
                          • Tatum
                            • 21.12.2010
                            • 448
                            • Alexander
                            #73
                            So jetzt muss das Alignkegelrad auf die Antriebswelle. Dabei muss man langsam und bedacht arbeiten. Bei diesem Vorgang stellt man auch gleich das Zahnflankenspiel ein! Also immer schön langsam und immer wieder kontrollieren. Das neue Loch für den Splint mit 1,5mm muss ich morgen in der Firma bohren weil ich keinen Bohrer dahab.
                            Mfg Alex
                            • Tatum
                              • 21.12.2010
                              • 448
                              • Alexander
                              #74
                              Es macht bislang einen guten Eindruck aber es gibt noch keinen Flugversuch. Ich kann daher keine gewähr oder so für irgendwas geben. Der Nachbau geschieht ausdrücklich auf eigenes Risiko!
                              Sobald die ersten Testflüge abgeschlossen sind werde ich wieder berichten.
                              Mfg Alex
                              Mfg Alex
                              • chris99
                                chris99
                                #75
                                Hey, cooler Umbau
                                Wenn bei meinem Fusion mal das Heck kaputt geht mach ich den Umbau vielleicht auch. Bis jetzt hatte ich allerdings keinerlei Probleme mit meinem Fusion.
                                Auf einem deiner Bilder sind noch die original Kegelräder im eingebauten Zustand zu sehen. Wenn ich mir das auf dem Bild so ansehe sieht das nach extrem viel Spiel aus... So viel Luft zwischen den Zähnen hab ich da zumindest nicht. Die zwei Zahnräder berühren sich ja nur mit den obersten 10% der Zähne?? Kannst du das bestätigen oder sieht das nur auf dem Bild so aus?
                                Link zu dem Bild:
                                Zuletzt geändert von Gast; 03.10.2012, 19:21. Grund: Bild-Link eingefügt
