â?¢ 3 blade default setups for all model sizes
â?¢ Added Jeti EX-Bus telemetry data transmission for the value selected in "Parameter settings" diagnostics logging tab
â?¢ Revised the Jeti integration releasing a new brain.bin file, with all the new parameters added in this release and some other improvements/changes and a fix for timers
â?¢ Added Futaba S.Bus2 for telemetry data transmission
â?¢ Added Spektrum SRXL decoding including telemetry data transmission (requires a receiver that has bidirectional SRXL port enabled such as the 4649T)
â?¢ Added Spektrum DSM2 11ms decoding and binding with 2048 step and more than 7 channels (compared to 22ms)
â?¢ Added a new option for HoTT-SUMD/UDI/Xbus-B/Mpx-SRXL protocol with a standard connection to the s-rec port using a normal 3 wire Female/Female cable (no more split cable needed)
â?¢ The "OLD" HoTT-SUMD/UDI/Xbus-B/Mpx-SRXL is no more selectable, and if you go in the page of receivers with the old HoTT-SUMD/UDI/Xbus-B/Mpx-SRXL selected, a warning appears to update to the new preferred single port configuration
â?¢ Now S.Bus & S.Bus2 decoding is more reliable with poor signal strength
â?¢ Reduced the load of the CPU with Jeti integration (with or without the new telemetry)
â?¢ Now the internal values of Castle Creation ESC can be read and/or logged with all the protocols and/or also transmitted with enabled telemetric protocol (Jeti, Futaba and Spektrum)
â?¢ Now the internal values of Hobbywing ESC can be read and/or logged with all the protocols and/or also transmitted with enabled telemetric protocol (Jeti, Futaba and Spektrum)
â?¢ Now the internal values of Kontronik JIVE and Heli JIVE ESC can be read and/or logged with all the protocols and/or also transmitted with enabled telemetric protocol (Jeti, Futaba and Spektrum)
â?¢ Now the code for read the internal values of Scorpion Tribunus ESC and/or logged with all the protocols and/or also transmitted with enabled telemetric protocol (Jeti, Futaba and Spektrum) is ready (but must be tested with the new Scorpion firmware not yet ready)
â?¢ In Wizard -> Governor and in Advanced -> Governor, added the menu for the selection of ESC capable to send telemetry data
â?¢ In Wizard -> Governor and in Advanced -> Governor, added the mAh Correction factor % parameter to compensate for inaccurate ESC current measurement. This is used to precisely calibrate the fuel gauge after the first flight and battery charge.
â?¢ Added the ESC log variables: "Main Battery Voltage, Main Battery Current, Main battery mAh used, ESC Power Out, ESC Temperature1, ESC Temperature2(only HW), Main Battery ripple(not HW)
â?¢ Sometimes with SW, during the change of receiver type, the reception of the radio signal is blocked and is needed to first select standard receiver then the new receiver. Fixed
â?¢ Improved "Magnet Detection" also with ESC RPM that let signal sometime low and sometime high when motor is off and now is also highlighted in software to make the graphic more visible
â?¢ RPM logs are now unfiltered to better diagnose really bad rpm sensors. Some glitches in rpm log are to be expected but do not effect governor performance
â?¢ Implemented a little change in governor to be able to read and compensate more fast RPM change (fast overspeed with nitro very dangerous for combustion motors)
â?¢ Autorotation bailout ramp improved (allowed to be far more aggressive)
â?¢ Added the new loggable parameters Sat1 & Sat2 FADES of DSMX sat's
â?¢ Added the event -PowerOn with AutoLevel Active!â?
â?¢ Added the user event "App connected, Log deleted"
â?¢ Now at the end of a rescue, the return of pitch to the stick value is 50% faster
â?¢ Improved the AutoLevel correction with different flying styles selected
â?¢ Changed the default values of feed forward set by Beginner and Sport icons
â?¢ Revised the filter used in the vibration log that gives greater magnitude to the very low frequencies
â?¢ Changed the name of loggable variable FramerateTX to RxFrameRate
â?¢ Added in all "2" schematics a connection diagram for the auxiliary power connections
â?¢ Now in event tab, the -Refresh Eventsâ? button work also if Sample Rate is set to "Disabled"
â?¢ Changed name of panel 12 from "Governor Setup" to "Throttle & Governor Setup" otherwise some user without governor active doesn't set the "Throttle out"
â?¢ MIN & MAX values of Throttle out are now the first items in panel 12 and in Advanced -> Common -> Governor
â?¢ In the Wizard, governor ratios and divider moved in Throttle out panel
â?¢ Divisors and dividends now are in the correct position in the two Governor gear calculators
â?¢ In Wizard, Governor "Engine is electric" moved from MIN/MAX panel into the Gain panel
â?¢ In Wizard, Governor put a scrollbar to allow you to see the whole also on small monitor screen
â?¢ Added in all connections schematics a diagram that explain where it is possible connect other power connections
â?¢ When you connect a new unit or after a factory reset, a "factory values loaded" message appears to confirm also that the factory reset worked
â?¢ Added at the end of the .MTR files the kind of unit from which .MTR file is saved
â?¢ Added a main button "MANUALS" to list all PDF-s of the more in depth instructions (Jeti integration, ESC parameter's logs, Jeti telemetry, etc.)
â?¢ Added an integrated PDF reader
â?¢ After a Firmware/Software update, the "Release Notes" panel is automatically opened
â?¢ Revised the "Configure Bluetooth module" changing the "OK" button to "Write", adding a -Cancelâ? button and adding some explanation about the displayed default values
â?¢ In panel 2 of the Wizard "Servo setup", the second top presets icon brought from 120Hz to 165hz and third icon from 200Hz to 333Hz
â?¢ In panel 2 of the Wizard "Servo setup", selecting one of the top tree icons, the values of +/- trim in the panel 7 -Swashplate setupâ? were reset. Now are reset only if swashplate servos are not yet set
â?¢ In panel 2 of the Wizard "Servo setup", revised the Max Frequency algorithm (now if a 1520uS tail servo is selected the max refresh rate value is around 440Hz instead of the unusable 530Hz)
â?¢ Updated the Servo chart list with some new servos (Xpert, BK, JR, OMG)
â?¢ In Advanced, "Model Type" selection moved from the toolbar to inside the CCPM menu (and revised the selectable names)
â?¢ In Advanced, "Check Mode" selection moved from the toolbar to inside the Servos menu
â?¢ Now when in Diagnostic Realtime Logs is running, the four top selection icon are disabled until real time is stopped to avoid possible hang of software
â?¢ In panel 3 of the Wizard "Receiver selection", selecting DSM2 22ms 1024 step receiver (with only 7 channels), the AUX channel is set to "No channel"
â?¢ In panel 3 of the Wizard "Receiver selection", selecting HoTT-SUMD/UDI/Xbus-b/Mpx-SRXL receiver, the AUX channel is set to "Channel 8"
â?¢ In Advanced -> Receiver changing Receiver type, channels are reassigned as in the Wizard
â?¢ In panel 2 of the wizard, if the default value selected by one icon is changed with slider or textbox, now the related icon is immediately deactivated instead of only at the next launch of the software
â?¢ In panel 10 of the wizard if the default value selected by one icon is changed with slider or textbox, now the related icon is immediately deactivated instead of only at the next launch of the software
â?¢ In panel 13 of the wizard if the default value selected by one icon is changed with slider or textbox, now the related icon is immediately deactivated instead of only at the next launch of the software
â?¢ In the Receiver panel of the wizard and Advanced changed the labels -Nose upâ? and Nose Downâ? (that are obtained with stick in the opposite down and up direction) are changed to Forward and Back to avoid misunderstanding
â?¢ During firmware update with servo-powered, sometime happens that there is a displacement of the swashplate. Fixed (for update done from this new firmware or successive)
â?¢ Added Russian Language
â?¢ Uniform black color of the label and tooltip
â?¢ All instructions and balloons revised, updated, corrected, completed
â?¢ Raised the trigger level for "Sensor out of range" event
â?¢ Reduced default values of elevator D gain for each size
â?¢ Flight counter & Timer don-t increase if the user is connected to the unit with one app (Windows, Andorid, iOS) during setup operations
â?¢ Added to the names assigned to the timer: "Model Flight Time"
â?¢ Small bug fixes and optimization of code
Werner
