"Eine neue Ã?ra" - Blade Pro Series 550X
  • helibilly
    OMP/KDS Support
    • 31.01.2013
    • 3550
    • Guido
    • Hannover
    #886
    AW: "Eine neue ßra" - Blade Pro Series 550X
    • freakystylez
      • 09.08.2011
      • 9332
      • Mal hier,... mal da... :)
      #887
      Gerade in Facebook gelesen:
      On Behalf of Horizon Hobby:
      PRODUCT BULLETIN: E-flite 130-amp ESC (EFL3130H) Included with the Blade® 550 X
      May 17, 2013
      Product: E-flite 130Amp ESC (EFL3130H)
      Issue: Horizon Hobby is aware of a small percentage of Blade® 550 X owners who have experienced a failure of the E-flite® 130-amp ESC (EFL3130H) resulting in a loss of power to the motor. The actual number of ESC failures is still relatively low and our data indicates it is currently around 6%. This is only affecting a proportionately small number of Blade 550 X owners, but it is higher than what we consider reasonable. We have been working on a solution, but at this point have been unable to re-create the failure mode pattern as indicated by most customers reporting the problem. It is not required to stop use of the EFL3130H 130-Amp ESC.
      If you decide to discontinue use of the 130-amp ESC included with your 550 X, Horizon Hobby will issue you a $100 check. A sales receipt and return of the ESC is required to receive the check. If you decide to continue using the EFL3130H ESC, the original warranty is still valid, but any product support that necessitates replacement of the original ESC due to failure, will result in the customer receiving a $100 check. Horizon Hobby will no longer stock or issue replacement EFL3130H ESCs
      For customers who decide to return their 130-amp ESC, Horizon Hobby suggests the following products as possible alternatives:
      ESC Product Part Number/ Notes
      Castle Creations Phoenix Edge 100* CSE010010000 The red wire must be removed to disable internal BEC per the Castle Creations instruction manual. This option is only recommended for 14-tooth pinion/sport flying
      Castle Creations Phoenix Edge 130* CSE010009900 The red wire must be removed to disable internal BEC per the Castle Creations instruction manual.
      Castle Creations Phoenix Edge 120HV* CSE010010400
      *Soldering is required
      Other required components:
      E-flite EC2� device connector w/4� wire (EC2EFLAEC04)
      E-flite EC5â?¢ device connector (EFLAEC501)
      E-flite Gold bullet connector set, 4mm (EFLA249)
      If you decide to return the 130-amp ESC:
      1. Please complete the Return Request form.
      2. Upon receipt of the completed form, a prepaid shipping label will be sent to you. Return your ESC, along with a copy of the Return Request form and sales receipt to Horizon Hobby. Upon receipt of the ESC, Horizon Hobby will issue a check in the amount of $100. Please allow 14-21 days for processing and delivery.
      We apologize for this inconvenience.
      Horizon Hobby Contact Information Address
      Horizon Service Center
      (Repairs and Repair Requests) Product Service Center - Request Form
      4105 Fieldstone Rd
      Champaign, Illinois, 61822 USA
      Horizon Product Support (Product Technical Assistance) Product Support E-Mail Manager - Add EMail
      888-959-2304
      Sales sales@horizonhobby.com
      888-959-2304
      For customers outside of the United States and Canada, please contact the retailer you purchased the product from.
      Quelle: https://www.facebook.com/BladeHelis/...45869478869293
      • Howling Mad
        • 09.06.2011
        • 2324
        • Ã?sterreich / Linz
        #888
        Ok, halten wir also fest:
        Die "Ausfallsquote" des 130A ESC ist so hoch, dass sich Blade dazu entschlossen hat ihn aus dem Programm zu nehmen.
        Jeder der einen aus der Combo hat und ihn zurückschickt, bekommt dafür $100.-
        Zukünftig wird keine ESC mehr der Combo beiliegen.
        Blade empfiehlt statt dessen einen von Castle Creations einzubauen.
        • donaldsneffe
          • 01.04.2011
          • 3878
          • Walter
          • Wien - Donauinsel
          #889
          ... dafür kostet er jetzt nur noch etwas über 600 US$...*
          Walter
          • tasse
            • 12.09.2011
            • 6061
            • Tassilo
            #890
            Wo?
            • Krissi
              • 17.04.2011
              • 835
              • Dudelange/Luxemburg
              #891
              Zitat von tasse Beitrag anzeigen
              Wo?
              Kombo oder Kit ??
              Christian
              UUUUPS.........Es fliegt ;-))
              • Krissi
                • 17.04.2011
                • 835
                #892
                Wo?
                Hier
                Christian
                • tasse
                  • 12.09.2011
                  • 6061
                  • Tassilo
                  #893
                  Das ist der Kitpreis. Was hat das mit dem Regler zu tun?
                  • Krissi
                    • 17.04.2011
                    • 835
                    #894
                    Nix, aber für den Preis für den Kit schmeist du den Regler weg, kaufst dir nen anderen und hast noch immer nen billigen 550 Heli
                    Christian
                    • tasse
                      • 12.09.2011
                      • 6061
                      • Tassilo
                      #895
                      *gelöscht*
                      EDIT: Oh - gibts ja doch für 580,- inkl. Versand. Macht immer noch über 900,- inkl. Servos und FBL. Also noch nicht billig oder günstig.
                      Zuletzt geändert von tasse; 19.05.2013, 14:40.
                      • Krissi
                        • 17.04.2011
                        • 835
                        #896
                        *gelöscht*
                        550€ ohne Versand für das Kit
                        880 € Combo
                        Christian
                        • tasse
                          • 12.09.2011
                          • 6061
                          • Tassilo
                          #897
                          Macht immer noch über 900,- inkl. Servos und FBL .
                          888,- EUR kostet er bei Freakware.
                          Verrechene ich die 100,- USD und lege noch 25,- EUR drauf für nen Talon, bin ich bei 913,- EUR. Auf was kommst du?
                          • reddog
                            • 30.11.2012
                            • 603
                            • 52399 Golzheim
                            #898
                            Hier schon für 799,-
                            Blade, 550x, Hubschrauber, 550 x, Spektrum, Horizon, Heli, Helikopter, Helicopter, DSMX, DSM2, bnf, 2,4Ghz,3D, Kreisel, Lipo, 2s, Ferngesteuert, Funk, 3s, BLH4080, 3d, heli, helicopter, helikopter, helikobter
                            Gruß Stefan.
                            GruÃ? Stefan.
                            Beim Landen immer die Kufen nach unten..... :-)
                            • Silver79
                              Silver79
                              #899
                              Der Preis wird immer besser:
                              Klick!
                              • juniorfuzzi
                                • 15.12.2011
                                • 1203
                                • Timm
                                #900
                                Klick!
                                Der Preis ist meines Erachtens nach eine RICHTIGE Ansage! Inkl. FBL/EMPF Kombi... Aber ich bleib meinem X5 treu.
