Beleuchtung Fernsteuerungsdisplays - egal welche!
  • Hobbypapillon.be
    Hobbypapillon.be
    #286
    AW: Beleuchtung Fernsteuerungsdisplays - egal welche!
    Hello,
    I tryed to make the display iluminated to my new FX-30, the light works, but the display dous't work anymore, you can see olny in direct sunlight a litle bit of the display, but not enougt to work with it.
    Is the display broken? I did everyting as carefull as possible !!
    Steve
    • JMalberg
      • 05.06.2002
      • 22636
      • J
      • D: um Saarbrücken drum rum
      #287
      Maybe you have removed the wrong film?
      IMO there are 2 films: a "gray", opaque and then the polarization filter.
      • Hobbypapillon.be
        Hobbypapillon.be
        #288
        I have removed the thick gray alu film of the original display.
        Steve
        • Hobbypapillon.be
          Hobbypapillon.be
          #289
          Here some pics of this afternoon.
          Steve
          • Thomas Hert
            Thomas Hert
            #290
            you have remove the Polarization Filter too. And thats your problem! You must only remove the Alu foil.
            I have last week rebuild an FX30 and it works perfekt.
            The Alu foli is extremly thin, when not then you have gets up both foils
            You can see that in the third picture when you remove only the Alu foil the alu foil will be rolled and your foil was extrem hard and thats not normal
            Beast Reaguards
            Thomas
            Zuletzt geändert von Gast; 20.10.2010, 19:25.
            • Hobbypapillon.be
              Hobbypapillon.be
              #291
              Yes, you are wright. I find the old film and there is a thin alu film on it, i separated it so when the new display enters, i know now how to do it, otherwise it works perfectly. Just that i see the 2 polarisation stripes on my display, because i was skared to cut in that section of the iluminated film. Anyway, thanks for the info, i know now what i did wrong, great service !!
              Steve
              • Hobbypapillon.be
                Hobbypapillon.be
                #292
                Voila,
                The FX-30 is raedy with a new display and works graet. I don't have any noise from the power suply, i orderd a white display but it shines Bleu. Anyway, thanks.
                Steve
                • Thomas Hert
                  Thomas Hert
                  #293
                  Hi Steve
                  that's normal, the display shines blue because it's a effekt from the polarization Foil
                  Thomas
                  • Surzflug
                    Surzflug
                    #294
                    Hallo ist ja alles Prima, habe meine Umgebaut mit de Teilen wie Beschrieben.Nach dem alles Fertig war, voll in die Kacke Gehauen. Der Inverter ist so Laut am Pfeifen das mir der Spaß an der Beleuchtung vergangen ist. Habe dann ein wenig Gegoogelt und siehe da, hatte ich mal Besser vorher Gemacht. Billig Inverter von Conrad Made aus dem Asiatichem Raum. Alles für wenig Geld, besser wäre wohl ein Elektronischer oder halt Markrnware from Germany. Habe nach einigen Recherchenwas EL Technick gefunden aber Zu anderen Konditionen, muss ich Fairerweise sagen, liegt so bei 50,- € aber erst Bestellt und noch nicht Getestet.Hoffe nun das die Aussagen von Herrn xxxxxxxx Stimmen und das der Inverter wirklich Laurlos ist.
                    Also was haben wir Gelernt, ja Genau zuerst einmal Googeln bevor man was Kauft.........
                    • claus.carstensen
                      claus.carstensen
                      #295
                      Zitat von Surzflug Beitrag anzeigen
                      ... zuerst einmal Googeln bevor man was Kauft.........
                      Tja, die Welt ist eine Guugel...
                      Ich hab den hier gefunden, arbeitet völlig lautlos.
                      C.C.
