Neue Airware für Spektrum Sender (November 2016)
  • mukenukem
    • 14.11.2010
    • 11187
    • Wien
    Da bis auf die "alten", silbernen DX8 und DX7s auf der gleichen Software basieren und auch das gleiche Update bekommen haben, hier das Changelog (betrifft DX6G2/G3/e, DX7G2, DX8G2, DX9, DX10t, DX18, DX18t, DX18G2, DX18QQ und wohl auch die DX20):
    Falls ihr einen Deppen sucht der das ausprobiert, hier bin ich
    [SIZE="5"]Wie immer, vor dem Firmware-Update UNBEDINGT ALLE MODELLE SICHERN !!!
    [/SIZE]
    Außerdem müssen benutzerdefinierte Sounds neu ins neue Soundfile importiert werden.
    Das Changelog ist das der DX18G2. Es kann sein daß "kleinere" Sender ein paar Features weniger haben. Aber die meisten betreffen alle Sender.
    Spektrum TM AirWare TM Change Log
    2016-November-15
    Version 1.07
    Changes since 2016-February-05
    Special Note
    In the Telemetry menu, some sensors may not be reported properly on the display or audibly after updating. If this occurs for you, please remove the sensor from the Telemetry list, then re-add it using the Auto-Config function on the Setup sub-menu. If you made this change to your model since October 2015, you do not need to make it again.
    New Features & Improvements
    A Lap Timer system has been added to aid FPV racers.
    Auto-Config is now on the first Telemetry menu, making it easier for people to configure their telemetry systems.
    Changed the default Multi-Rotor type from Aerial Photography to FPV Racer mode.
    It was not possible to force DSM2 or 22ms binding modes in the previous several versions. This has been corrected. (Non-EU only).
    The Timer system now includes the ability to have switches other than CLEAR button to reset the timer(s) separately.
    Analog and Digital Switch Setup screens were moved to the Function List for radios which have those functions in them.
    When transmitter low voltage is warning, it displays the current voltage to allow you to understand the situation better.
    Complete telemetry support for Alpha-6, generic Gyro, and 6-cell and 14-cell LiPo sensors.
    Complete support for user-defined telemetry sensors per the Spektrum Telemetry specification document.
    Model Match Override allows multiple transmitter models to share a common Model Match ID. This should be used with extreme care, as it disables one of the big benefits that Spektrum has to offer. This is available by selecting NEXT on the Frame Rate screen.
    When assigning channels in Multi-Rotor mode, Flight Mode-based changes are now supported when the Aircraft Type is not FPV Racer. FPV Racer is a new option available.
    You may now suppress the -Sequence Reset� message when using the Stepping Events. This is found on the screen where you are adding/editing an item in the step list.
    Added support for new telemetry receivers with signal strength feedback. This shows as either a dBm or percentage (you select which in Telemetry Flight Log setup screen). This strength is shown on appropriate telemetry screens and during Range Test, where it can be useful for locating lost models.
    For Multi-Rotor models, the high-speed (11ms) channels are THRO, AILE, ELEV, and RUDD. For other model types AUX1 replaces THRO.
    Corrections
    NOTE: Generic Switch Report settings may have changed. Please verify them! If you are hearing invalid speech for them, you may erase all by pressing the CLEAR button while on the BACK icon on the Generic setup screen.
    Timer Expiration sound was not properly volume-limited (speech radios only) Improved system update process to reduce the chance of System Failure messages after an update.
    Channel A/B Warning values were exported as the Throttle warning point instead of as Channel A/B thresholds when using the Inside/Outside alarms. This means that models exported in earlier versions will import incorrectly, and will need to be modified manually. After exporting with this version, they will be retained properly. This applies to Acro, Sail, and Heli models. Multi-rotors were exported correctly.
    Center reports are no longer reset to defaults on power-up.
    The timer Start/Stop tones were changed from the Switch Sound category to the Timer Sound category because they are controlled using the Timer menu.
    When changing the Throttle Trim Setup to 2-/3-position mode, trims are reset to valid values instead of going to invalid extremes.
    Channel warnings could show large negative numbers in certain warning conditions.
    Improved ability to withstand attempted use of bad SD cards. Previously these could lock up a radio, requiring disconnection of battery to recover.
    Changing a 2-/3-pos trimmer will no longer allow invalid trim values.
    When moving a Gyro function to a different receiver channel, it now moves as it should.
    Corrected an import/export issue with -Inside� and -Outside� warning types not functioning correctly.
    -Inside� and -Outside� now alarm properly for general Channel alarms.
    Some blinking boxes on the Timer screens were repositioned correctly.
    Translation and spelling changes in assorted screens.
    Audio System Changes
    For all languages please use Sound version 1.09
    Version 1.09 adds speech for several new sensors (LiPo Monitors) and Autonomous Mode for GPS-enabled models.
    Turbine Pack Voltage is now reported correctly. Previously it was reporting the Pump Voltage, and at 10X what is should have been.
    Zuletzt geändert von mukenukem; 05.12.2016, 21:58.
  • mukenukem
    • 14.11.2010
    • 11187
    • Wien
    AW: Neue Airware für Spektrum Sender (November 2016)
    Eine interessante Neuerung ist: Das Modelmatch kann umgangen werden. Das heißt man kann mehrere Modellspeicher für dasselbe Modell verwenden. Das erleichtert ungemein unterschiedliche Setups wie z.B. verschieden große Akkus (Zellenanzahl/Kapazität).
    Weiters interessant ist die selektive Rücksetzung der Timer mit unterschiedlichen Tasten. Unter anderem auch z.B. mit dem Gasknüppel oder dem Wert des Gaskanals. Das ist z.B. interessant für Hotliner, bei denen nur eine gewisse Zeit Gas gegeben werden darf. Vielleicht kann mna es auch für Auro brauchen.
    Bitte die Warnung für die Senderakkuspannung überprüfen. Die wurde bei mir auf 6.4V zurückgesetzt. Ich bevorzuge 6.8V oder mehr.
    • luha
      • 07.10.2013
      • 4847
      • Lutz
      • Lehrte bei Hannover
      Funktioniert das auch Senderübergreifend? Sprich, kann ich 2 Sender an das gleiche Modell binden? (Ja, ich weiß welche Gefahr das birgt und bin mir dessen bewusst)
      Gerade bei nur Sat-Lösungen z.B. an Coptern, wo man nur über den FC am PC das binden auslösen kann, ist es immer besonders ärgerlich, den falschen Sender mit genommen zu haben.
      Danke für die Warnung!
      • freakystylez
        • 09.08.2011
        • 9332
        • Mal hier,... mal da... :)
        Das wollte ich gerade ansprechen. Wir hatten es ja mal über PN darüber nen zweiten Timer laufen zu lassen, um zu wissen, wie lange der Bailout des Reglers noch greift. Ist das jetzt realisierbar? Teste mal bitte!!!
        • mukenukem
          • 14.11.2010
          • 11187
          • Wien
          [MENTION=51633]luha[/MENTION]: Nein. Senderübergreifend ist ein No-Go. Stell dir vor du und dein Kumpel schalten den Sender gleichzeitig ein. Das kann und darf nicht gehen. Mehrere Modelle gleichzeitig kannst nicht auswählen. Du kannst nur die Modell-Id ändern. Die Guid ist fix.
          @Freaky: Sicher geht das. Spiel dich damit, du kannst fast beliebige Schalter/Zustände zum reset verwenden
          • carljonas
            • 11.12.2014
            • 587
            • Carl
            Irgendwie kapier ich das Modelmatch nicht bzw. was kann ich jetzt machen, was davor nicht ging?
            • mukenukem
              • 14.11.2010
              • 11187
              • Wien
              Modelmatch heisst daß das Modell AUSSCHLIESSLICH mit einem Modellspeicher auf genau einem Sender betreiben kannst. Jetzt kannst du mit mehrern Modellspeichern alternativ ein Modell betreiben (ohne rebind)
              • freakystylez
                • 09.08.2011
                • 9332
                Du kannst im gleichen Sender Modell X mehrmals binden. Bedeutet, du kannst dein übliches Setup kopieren, daran nochmal herum fummeln und wenn es dir doch nicht passt, wieder zum vorherigen Setup wechseln und das ohne neu binden zu müssen.
                • mukenukem
                  • 14.11.2010
                  • 11187
                  • Wien
                  Du brauchst nicht neu zu binden so wie das aussieht. Du stellst bei dem neuen Modell einfach die ID des alten Modells ein. Der Modellspeicher im Klartext/friendly name wird auch angezeigt.
                  • luha
                    • 07.10.2013
                    • 4847
                    • Lutz
                    Warum, im Gegenteil wäre es konsequent die Wahl und damit die IDs vollständig dem Benutzer zu überlassen.
                    Die Gefahr ist mir bewusst, darum würde ich IDs auch nie mit einem Kumpel sondern nur mit meinen eigenen Sendern teilen.
                    Sorry, aber das ist Quatsch! Eine ID ist technisch immer einfach setzbar, hier nur leider von Spektrum unterbunden. Auch MACs von Netzwerkkarten lassen sich bei ordentlichen Karten relativ einfach vom User setzen.
                    Natürlich kann man für den unbedarften User eine Warnung vorschalten aber für jemanden der weiß was er tut, ist diese Bevormundung durch den Hersteller einfach Mist.
                    Früher (TM) wurde nur mit einer Frequenztafel sichergestellt, dass nichts passiert. Dafür konnte ich problemlos den Sender wechseln. Heute braucht man zwar glücklicherweise die Frequenztafeln nicht mehr aber hat auch die Senderwechselmöglichkeit eingeschränkt. Das müsste nicht sein, wenn man die Geräte IDs editierbar hätte oder die Bindung nur an die Modell IDs hängt.
                    Die Aussage verstehe ich gerade nicht. Zwei Modelle auf den selben Modellspeicher binden ging doch schon vorher. Ich bin selbst mal gleichzeitig 2 mCP-X geflogen - OK nur kurz, um zu zeigen, dass es wirklich funktioniert
                    Wie gesagt, sehr schade diese Bevormundung.
                    Hat aber auch was positives. Ich kann mir das Update schenken, weil es keine für mich interessanten anderen Features gibt und auch keine mich betreffenden Fehler behoben wurden.
                    • mukenukem
                      • 14.11.2010
                      • 11187
                      • Wien
                      Mehrere MODELLSPEICHER gleichzeitig auswählen kannst du nicht. Das meinte ich. Insofern gibts da kein Potential das was schief geht. Ich finde das gut, so kann ich verschiedene Flugzeiten für den Acrobat mit verschiedenen Akkus einfach realisieren.
                      Es gibt keinen Sender wo du die GUID ändern kannst. Das ist auch gut so. Selbst wenn dir das bewußt ist was du tust. Die GUID ist im HF Microcontroller verankert. Spektrum ist eine US Firma und amerikanische Bürger sind bekannt für ihre grenzenlose Dummheit (und dafür ihre Dummheit auf andere zu "klagen").
                      Das Update lohnt sich. Sind auch ein paar Bugfixes beim Import/Export gefixt. Kannst ja mal abwarten und schaun welche Bugs neu sind
                      • k-nipser
                        Junior Member
                        • 07.11.2016
                        • 15
                        • Uwe
                        ... schon alleine das die nervige Registrierungsanmeldung beim Sender (DX8G2) ausschalten nicht mehr kommt war es wert
                        • running
                          • 13.06.2014
                          • 1478
                          • Maik
                          • Wild in 31600
                          Welche dich betreffenden Fehler wären denn noch offen?
                          [FONT="Arial Narrow"]Viele Grü�e vom Maik[/FONT]
                          • luha
                            • 07.10.2013
                            • 4847
                            • Lutz
                            Keine Frage, das ist schon mal ein Schritt in die richtige Richtung.
                            Leider! Auch wenn es technisch einfach wäre die GUID in der HF-Firmware zu ändern. Es ist ja auch nur ein Wert im Speicher. Man müsste nur zugreifen dürfen.
                            Das ist doch aber unfair, dass ich wegen der Dummheit anderer eingeschränkt bleibe
                            Mit der derzeitigen Firmware bin ich soweit zufrieden. Jedenfalls habe ich keine mich betreffenden Fehler mehr offen.
                            Das neue editierbare Modell Match Feature, wenn es denn Sender übergreifend gewesen wäre, wäre halt praktisch für mich gewesen. Dafür hätte ich auch das "running system" angefasst. So bleibe ich bei dem, was ich als "funktioniert" getestet habe. Ich fliege lieber, als einen Sender auf Funktionalität zu testen. Das muss man nach einem Firmware Update ja nunmal bei jedem Modell machen.
                            Trotzdem nochmal Danke an alle die entwickeln, testen und über neue Features informieren. Wenn etwas dabei ist, womit ich etwas anfangen kann, nehme ich so ein Firmware Update gerne an.
                            • mukenukem
                              • 14.11.2010
                              • 11187
                              • Wien
                              Ich denke die GUID ist fix und kann nicht geändert werden. Soweit ich weiß wird die beim Produktionsprozess anhand von Datum, Uhrzeit, Position am Wafer und was weiß ich noch alles festgelegt. Damit sie wirklich einzigartig ist.
                              Und andere Leute laß ich mittels LS fliegen. Das ist eine Sache von Sekunden. Ich weiß jetzt nicht wo dein Problem ist und warum du partout dein Modell an 2 Sender binden willst
