Spektrum DX9: Erfahrungen und Tipps
  • RedDragon
    • 12.10.2010
    • 101
    • Patrick
    #811
    AW: Spektrum DX9: Erfahrungen und Tipps
    Klar doch
    Changes from Version 1.01
    New Features & Improvements:
    Added spoken telemetry warning reports for more devices.
    The BACK button is now enabled while downloading a sound file, allowing the process to be aborted. Note that you will lose spoken sounds if you do this, but most clicks and beeps will still function. Completing the sound file installation process will restore spoken sounds.
    Does not show hidden Mac files and directories in file lists
    Added ability to create mixes to channels which were moved using the Channel Assignment feature.
    Corrections:
    Imported DX18 files will now operate all mixes properly
    Model warnings now import/export correctly
    Pressing CLEAR on the transmitter low voltage alarm setpoint will now select the appropriate low voltage based on battery type
    Prevents lock-ups when using Export All when "Unusable Models" were listed
    Improved translations in several languages
    Fixed import of Flight Mode sound options
    Lock-ups during import, export and turning on to "blank screen" have been fixed.
    Import errors which corrupted the Flight Mode table have been fixed. These could also cause lock-ups in certain situations.
    Corrected position of receiver voltage display on status screen.
    Removed limitation that could occur when manually creating models right at the 100-model point.
    Corrected export error that made the DX9 unable to import files it created
    Audio Changes:
    Added many new voice items, in particular related to multi-copters and
    photo/video.
    Trainer status changes are now reported when not in Master Override mode.
    Spoken and Tone inactivity alarm reports now function properly with vibrator/
    Intermittent "Bind Failed" speech after proper binds is now corrected.
    Airspeed and current are now reported using the correct units and value.
    Reduced default volume for each category to 50% based on customer feedback.
    Maximum volume can be increased by using System Settings second screen.
    Improved speech and sounds for several languages. Please download the updated sound files from this link: Spektrum DX9 Support
    Corrected speaking of numbers for French
    PowerBox status reports are now speak the correct values
    Expired timer volume now works off configured value.
    • southside81
      • 29.03.2008
      • 3773
      Und, gibt es schon erste Erfahrungen?
      mfg Michael
      • mukenukem
        • 14.11.2010
        • 11187
        • Wien
        #813
        Ich kann jedem nur ans Herz legen, dieses Update SOFORT einzuspielen. Damit sollten die Crashes beim Import/Export, welche ein Einschicken nötig machen, behoben sein. Und die Flight Modes funktionieren jetzt auch. Und ausserdem und überhaupt
        Gerade für die Copter Fraktion gibts viel neues Geplapper, und auch für die Helis ein paar nette Kleinigkeiten (Bank x, Panic, etc.). Einfach mal die neuen Sound-Files durchhören. Keine Ahnung, ob die ßbersetzungen stimmen, aber zumindest die Geschichte mit dem falsch angesagten Trainer Mode wurde korrigiert.
        Ich hab mir die Soundfiles mal durchgehört, ganz nett.
        Gibts schon Erfahrungen ? Du bist schon ein Witzbold
        Sicher, ich hab die ganze Nacht nix anderes gemacht als 30 Akkus zu verfliegen und die neue Airware getestet
        SPIEL SIE EIN ! Kann nur besser als die aktuelle sein.
        Zuletzt geändert von mukenukem; 18.12.2013, 11:22.
        • mukenukem
          • 14.11.2010
          • 11187
          • Wien
          #814
          Gibt schon den ersten Bug:
          Wenn man 5 Flugzustände beim Heli aktiviert, wird anstatt des letzten Flugzustandes Hold (Autorotaion) ausgelöst.
          Also solange man nur 3+Hold (also nur 2 Schalter) hat, kein Problem, bei 3 Schaltern gibts ein Problem.....
          Juckt mich persönlich nicht, da ich Helis mit der DX18 fliege und sowieso nur 4 FZ hab. Aber für F3Cler....
          Wird wohl demnächst die 1.02A nachgereicht....
          • 5of9
            5of9
            #815
            Juckt zwar wohl die wenigsten und ich brauchs erst im Frühling und nicht bei dem Frost, aber Jetcat Audioausgabe gibts auch immer noch nicht...
            Und eins ist schade, leider wird wenn man ein alternatives Logo eingepflegt hat, dieses wieder nicht mit auf die SD exportiert.
            Zuletzt geändert von Gast; 18.12.2013, 17:21.
            • Zisko
              Zisko
              #816
              Enttäuschend, das Update.
              Das einzig Wichtige bei einer Sprachausgabe für mich ist, dass mir Telemetrie-Alarme angesagt werden - und das geht immer noch nicht - höchstens in Zusammenhang mit der Vibrationsfunktion. Ich weiß nicht, wie Spektrum die Software absichert, zumal das Problem mit den Telemetrie-Alarmen doch angeblich bekannt war.
              • mukenukem
                • 14.11.2010
                • 11187
                • Wien
                #817
                Hast du es probiert ? Ich kann bei den Alarmen Voice alleine auswählen.
                • 5of9
                  5of9
                  #818
                  Das konnte man aber in der 1.01A auch schon, nur sagt Sie nix wenn der Akku leer ist...
                  • Zisko
                    Zisko
                    #819
                    Genau das ist das Problem. In meinen Augen eine Riesensauerei, zumal der Bug angeblich (so hat es mir Andy Kunz zumindest geschrieben) bekannt war. Ich bin deswegen gerade wieder in Kontakt mit ihm. Mal sehen, was er mir dazu sagt.
                    Zuletzt geändert von Gast; 18.12.2013, 18:41.
                    • 5of9
                      5of9
                      #820
                      Würde mich auch interessieren, bitte den Grund posten.
                      • glange
                        • 01.10.2011
                        • 3180
                        • Gerolf
                        • Bremer Umland
                        #821
                        Mein Gott, entspann dich mal. Das sind doch nicht deine Leibeigenen ....
                        Beste Grü�e Gerolf
                        • Zisko
                          Zisko
                          #822
                          Na klar
                          • mukenukem
                            • 14.11.2010
                            • 11187
                            • Wien
                            #823
                            Wahrscheinlich weil einfach keine Zeit war.
                            Die Geschichte mit dem Flight Mode wird wahrscheinlich kurzfristig gefixt. 1.02A oder so.
                            • 5of9
                              5of9
                              #824
                              Bitte mir hier keine Beschimpfungen unterstellen. Die Aussage kam von Zisko!
                              • glange
                                • 01.10.2011
                                • 3180
                                • Gerolf
                                • Bremer Umland
                                #825
                                Sorry Flo
                                War keine Absicht. Die Zitatfunktion hat mich bzgl. des immer noch bestehenden Bugs schon immer genervt.
                                Beste Grü�e Gerolf
