Spektrum DX8 Firmware 2.05
  • Dagobert-Duck-1
    Dagobert-Duck-1
    Angeblich war die 2.05 bereits kurz im Internet verfügbar.
    Version 2.05
    10 August 2012
    Software Features
    â?¢ Added support for GPS and High Current telemetry sensors.
    â?¢ Enabled up to 32-pole motors for the brushless RPM sensor.
    â?¢ Enabled SD telemetry log file
    â?¢ Enabled ability to configure inactivity timer
    â?¢ Enabled backlight configurability (Auto/On/Off)
    â?¢ Enabled dimming control of the orange Spektrum LED for night flying
    â?¢ Adjusted vibe motor RPM to be less aggressive
    Software Corrections
    â?¢ Fixed bug that could reset the radio when scrolling through Mix options.
    â?¢ Corrected L/R trimmer -forgetting- assignment after power cycle.
    â?¢ Improved translations in French and Italian screens.
    â?¢ Corrected export of flap configuration.
    â?¢ Corrected over-travel of flaps that could result in reversed operation at extreme
    deployments.
    â?¢ Corrected switch change on Acro throttle cut screen when going from the initial
    switch selection to the edit page.
    â?¢ Corrected timer to work properly in Throttle Out mode when using reversed
    throttle channel.
    â?¢ Corrected end-point adjustability when Trainer is used as an input to a channel.
    â?¢ Corrected trainer normal Master mode so that it doesn-t modify controls from the
    slave. In previous versions it could reverse channels vs. what was expected.
    NOTE: This change affects sub-trim and travel of existing models and ones you
    will import. You may need to adjust sub-trims and travel on all control surfaces in
    both airplanes and helicopters
  • John Heli
    • 28.10.2009
    • 701
    • Ansger
    • MFV Böblingen
    AW: Spektrum DX8 Firmware 2.05
    Hui, die Telemetrie kann geloggt werden. Da bin ich aber einer der Ersten, die das Update aufspielen!
    • John Heli
      • 28.10.2009
      • 701
      • Ansger
      • MFV Böblingen
      Das Dimmen der Spektrum-Empfänger-LEDs eignet sich auch gut für meine Puma. Sie hatte bis dato immer eine orange Innenbeleuchtung.
      Bleiben wir gespannt, wann das Update (wieder) online geht. Noch ist nichts zu sehen.
      • Daobenfliegter
        • 01.06.2011
        • 1130
        • Rene
        • Ja
        Da wäre dann ein Kurzbericht von dir eine schöne Sache.
        [FONT="Arial"]Nicht geschimpft, ist Lob genug.[/FONT]
        • John Heli
          • 28.10.2009
          • 701
          • Ansger
          • MFV Böblingen
          Gerne berichte ich, sobald der Download verfügbar ist. Ich kann die 2.05 noch nicht runterladen. Bitte hier berichten, wenn es bei Euch geht.
          Und endlich kann man den nervigen Inaktivitätstimer konfigurieren!
          • Denny86
            Denny86
            Juhu,
            auf die Logs freue ich mich. Bin gespannt, wie diese ausgewertet werden. Ich hoffe, dass sie nicht einfach nur als Logfile irgendwo angelegt werden.
            Denny
            • Aerodeck
              • 24.07.2010
              • 1030
              • Ralf
              • Kleinenbroich
              Sind ja ein paar nette Sachen bei .
              Wiedergeburt meiner Bell 222 - 90
              • tiepel
                • 30.07.2011
                • 2260
                • Reimumd
                Das ist für mich das wichtigste Feature
                Endlich keine Chance auf Herzinfarkt beim Einstellen des Helis mehr!!!
                Gruss Reimund
                • mukenukem
                  • 14.11.2010
                  • 11187
                  • Wien
                  Wenn du das Changelog von RCgroups hast, würde ich es nicht für bare Münze nehmen, dort hat es VictoryPete gepostet. Der ist niemand, dem ich trauen würde
                  Klingt sehr nach wunschdenken. Vor allem die dimmbare Power-LED. Und der Wortlaut gefällt mir nicht, bei den interessanten Funktionen steht überall "Enabled" dabei, meiner Meinung nach müßte dort aber "Added" stehen, weil es eine komplett neue Funktion ist.
                  Je mehr ich mir das so durchlese, desto mehr glaube ich an Bullshit
                  • John Heli
                    • 28.10.2009
                    • 701
                    • Ansger
                    • MFV Böblingen
                    Wieso? Andy als Entwickler bei Spektrum hat zwei Beiträge weiter gepostet:
                    "It's NOT out yet, and if you downloaded it DON'T install it.
                    Andy"
                    Anscheinend wurde es zurückgezogen.
                    • marndra
                      • 03.03.2008
                      • 2935
                      • Laudenbach bei Heppenheim ->wild; Weinheim -> Flugplatz
                      Andy"
                      not more
                      grü�e marndra
                      • ethix
                        ethix
                        Mich würde vorallem mal interessieren wann es endlich nen/ne mah-Verbrauchszähler/-anzeige gibt...
                        • mukenukem
                          • 14.11.2010
                          • 11187
                          • Wien
                          Es wurde nicht zurückgezogen. Er hat es auf der Webseite editiert, aber scheinbar versehentlich online. Wahrscheinlich war es ein paar Minuten online und VP hat nix besseres zu tun, als permanent die community Seite zu refreshen
                          Normalerweise gibts zeitnah ne e-mail Benachrichtigung.
                          Kann natürlich auch sein, daß es den Trainer Bug hatte. Schließlich sind die Firmwares der neuen DXen verwandt.
                          • Slevin Kelevra
                            Slevin Kelevra
                            Nicht so ganz. Sehr wahrscheinlich waren die Funktionen in der Firmware schon inkludiert und werden jetzt einfach nur frei - bzw eingeschaltet.
                            Auch nicht so ganz richtig. Ich lese es so, dass damit das Orange Spektrum Logo auf der Funke gemeint ist.
                            /Klugscheissermodus aus
                            • Stephan Lang
                              • 23.03.2011
                              • 3007
                              • Stephan
                              jeder der schon mal Nachflug gemacht hat weiß das eine kleine LED am Heli sicher nicht auffällt.. nochdazu wo der Empfänger meistens irgendwie verbaut ist...
                              eine LED oder ein (dauer) beleuchtetes Display hingegehen stört gewaltig beim fliegen... nochdazu wo einem das ziemlich sicher immer genau anstrahlt ...
                              ich gehe also auch davonaus das die LED am Sender gemeint ist... man muss aber tatsächllich 2 mal lesen da ich beim ersten "überlesen" auch an den Empfänger gedacht habe...
                              btw nettes Feature
