Update für AR7200BX
  • Plastekasper
    • 09.04.2012
    • 838
    • Heiko
    • Roth
    AW: Update für AR7200BX
    Hat schon jemand ßnderungen gesehen? Gov vielleicht?
    [FONT="Comic Sans MS"]GruÃ?
    Heiko
    [/FONT]
    • tasse
      • 12.09.2011
      • 6061
      • Tassilo
      Es ist 1:1 die MS Software vom Microbeast - nur das Logo haben sie geändert.
      • Dennis_HB
        • 31.05.2011
        • 511
        • Dennis
        • Bremen und Umgebung
        Hat inzwischen jemand Infos darüber was sich in der Firmware geändert hat?
        Dennis (helimanie.de)
        • Mike79
          • 28.07.2011
          • 2357
          man lädt die normale Beasx 3.0.8 Software runter siehe...
          Bin immer davon ausgegangen wie haben wir schon drauf -- na ja anscheinend nicht.
          Gehen wir mal davon aus wir haben die 3.0'er drauf dann...
          Changes from V3.0.0:
          Unfortunately since V3.0.0 receivers with SRXL protocol could not be used because power output to swash and tail servos has been seriously disturbed. This could range from slight twitching to total dropouts for several hundred milliseconds. As this was depending on the chosen servo frequency and the applied servos, we didn-t notice.
          Improved locking in on the elevator axis when using large / heavy helicopters.
          Uniform rotation rates on aileron and elevator when same amount of stick input is applied.
          Adapted values ??in parameter menu points G and H. The values ??are now lower in the beginning and rise progressively.
          Improved sensor signal conditioning.
          Note: This update uses the same database version (V6.1) as V3.0.0. I.e. when V3.0.0 is already used on the Microbeast, the basic settings will not be changed when updating to V3.0.8. However, please note that the values in parameter menu points G and H slightly changed! We recommend for the first flight to switch these parameters back to the default values (Status LED purple) and then again adjust them as desired.
          Mike
          Zuletzt geändert von Mike79; 23.08.2012, 11:01.
          Gruss Mike
          [FONT="Verdana"]McpX V2,T-Rex 100/450Pro/550 FBL AR/700N FBL AR/700E FBL MB - DX8[/FONT]
          • BladeMaster
            • 10.09.2011
            • 3372
            • Dirk
            Bleiben nach dem Update alle Setup-Einstellungen erhalten ?
            Zuletzt geändert von BladeMaster; 23.08.2012, 11:06.
            • Mike79
              • 28.07.2011
              • 2357
              Ich hoffe ja doch! - wobei ich mir vom 3GX her angewohnt habe nach jedem Update den Setup Prozess zu durchlaufen - Man weiß ja nie...
              Mike
              Gruss Mike
              • GenMjr_GPL
                • 13.06.2012
                • 35
                • Gunther
                Mike
                Nach Anfrage bei Micro Beast wurde mir mitgeteilt, dass die beastX SW und die AR7200BX SW nicht kompatibel zueinander sind.
                Weiters wurde mir bestätigt, das die 3.0er vom AR7200BX die 3.0.8er vom BeastX ist, also identisch.
                Würde mich interessieren ob es jemand schafft die beastx SW aufs AR7200BX zu spielen.
                • Mike79
                  • 28.07.2011
                  • 2357
                  Sieh dir mal den Link an -- das ist doch die Standard Beast Software oder?
                  Wenn wir schon die aktuelle hätten -- warum dann das Update?
                  Mike
                  Gruss Mike
                  • glange
                    • 01.10.2011
                    • 3180
                    • Gerolf
                    • Bremer Umland
                    Die erste SW-Revisionsnummer des AR7200 ist die 3.0.0 und entspricht der BeastX 3.0.8. Wurde hier schon mehrfach im Forum durchgekaut.
                    D.h. die Rev. beider Beaster ist unterschiedlich (bei gleichem Funktionsstand im Bereich FBL).
                    Beste Grü�e Gerolf
                    • tasse
                      • 12.09.2011
                      • 6061
                      • Tassilo
                      Die Entwickler (BeastX und HH) haben sich ja einmütig auf Helifreak geäußert. Es besteht also die berechtigte Hoffnung, dass die Updates in Zukunft kompatibel sein werden.
                      • parkplatzflieger
                        • 18.03.2012
                        • 8994
                        Ehrlich gesagt verstehe ich das Durcheinander bei Horizon nicht.
                        Ich habe meinen ar7200bx bei der Spektrum-Community "registriert".
                        Meine Erwartungshaltung war, dass ich über Updates informiert werde
                        und dann von _dort_ die Updates beziehen kann.
                        Stattdessen erfahre ich von Updates hier im Forum und die gibt
                        es nicht aus der Spektrum-Community, sondern über eine neue,
                        eigene Website nur für den ar7200bx.
                        Bin ich der Einzige, der das komisch findet?
                        Torsten
                        Voodoo 600, Logo 600SX
                        Spektrum, Spirit, Heli X
                        • sirius1977
                          • 16.09.2010
                          • 609
                          • oliver
                          • Fürth
                          Ich hatte mich auch in der Spektrum Community registriert mit meinem AR7200BX gerade wegen Updates. habs auch nur durch zufall erfahren.
                          Und euch hier gleich mitgeteilt.
                          Aber eigentlich ist das dann doch recht eigenartig das Sie das Update nicht gleich in der Community bereitstellen.
                          das wäre doch super wenn man die Original Beast software und die Updates verwenden könnte.
                          Oliver
                          Gruss Oliver
                          Compass 6HV, Airwolf in der 600er grösse,
                          Sender Graupner MZ24
                          • parkplatzflieger
                            • 18.03.2012
                            • 8994
                            Was soll sich durch das Update eigentlich ändern? Gibt es ein offizielles
                            ChangeLog?
                            Torsten
                            • Dennis_HB
                              • 31.05.2011
                              • 511
                              • Dennis
                              Die Frage kam jetzt schon mehrfach auf aber offensichtlich hat leider keiner eine Antwort
                              • sirius1977
                                • 16.09.2010
                                • 609
                                • oliver
                                • Fürth
                                Da ich bisher keine ßnderungen feststellen konnte ist das Update nur däfür gemacht um es mit der Software Kombatibel zu machen.
                                Oliver
                                Gruss Oliver
