Hobbywing platinum V3 50/100A - Erfahrungen und Austausch
  • Dagobert-Duck-1
    Dagobert-Duck-1
    #2251
    AW: Hobbywing platinum V3 50/100A - Erfahrungen und Austausch
    Weiss jemand, ob nach einem Update die bisherigen Einstellungen (Parameter) erhalten bleiben?
    • Florian S.
      • 17.01.2014
      • 672
      • Florian
      #2252
      Nochmal zur Progbox, die Dymond Progbox geht auch, ist ja nur umgelabelt.
      • buell47
        • 11.12.2014
        • 4161
        • Wedemark (Wildflieger)
        #2253
        Zitat von Dagobert-Duck-1 Beitrag anzeigen
        JA:
        Firmware Revision History:
        2015-08-07
        database version: FLYING_V3.52.02
        1.To support the Platinum-100A-HV-V3.
        2015-07-17
        database version: FLYING_V3.52.01
        1.To support the Platinum-HV-V4 series of ESCs.
        2014-03-18
        database version:140318
        1. upgrade Platinum-V3, Platinum-HV-V3 and LCD Program Box database.
        1.1 Fixed the bug (operational issue in factory reset when setting the ESC parameter mode via throttle stick) in Platinum-V3 & Platinum-HV-V3 series ESCs.
        1.2 Decreased the switching speed, when Platinum-V3 & Platinum-HV-V3 series ESCs were/are in the ¡°governor¡± mode, to 1.7 seconds.
        2. Fix the bug (incompatibility with car ESCs) in firmware "V1.16_131105" (of the multifunction LCD program box) and update it to "V1.17_140315".
        3. Add the firmware of Platinum-30A-OPTO ESCs into the database.
        2014-02-21
        database version:V3.42
        1. add Platinum-V3, Platinum-HV-V3 and LCD Program Box database.
        2013-05-13
        database version:V3.3
        1. add LCD Program Box: PROGRAMECARD / HW310_V2.1 / "V1.14_130508".
        2012-12-4
        database version:V3.1
        1. add LCD Program Box: PROGRAMECARD / HW310_V2.1 / "V1.12_120426".
        2012-4-1
        database version:V3.0
        1. new software for for all produce
        2011-9-21
        database version:1.19
        1.Upgrade Platinum ESC software for PL120A-HV,
        The "V1.08_101106_U_a" is ok for V-bar + Hyperion emeter version2 tachometer RPM sensor
        2011-8-31
        database version:1.18
        1.Upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL100A-PRO,PL120A-HV
        2011-1-19
        database version:1.17
        1.Upgrade 2In1 LCD Program Box software
        2010-11-06
        database version:1.15
        1.Upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL1000A-PRO.
        2010-5-12
        database version:1.14
        1.Upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL100A-PRO.
        2.Upgrade 2In1 LCD Program Box software. add ESC parameters with CAR ESC Xerun series for STOCK,add display ESC software version,add display ESC parameters and items number.
        2010-4-22
        database version:1.13
        1.upgrade Platinum ESC software.only for PL40A-PRO,PL60A-PRO,PL80A-PRO,PL100A-PRO.
        2009-12-24
        database version:1.10
        1.when run to set ESC parameter state,it should must to reset ESC,then can drive motor
        2009-10-23
        database version:1.09
        1.first release
        Ich meine ein Firmware-Update für den Platinum Regler 50A/100A V3 und nicht ein Firmwareupdate für die BOX oder ein Softwareupdate für den PC.
        Jeti DS-16 Red Carbon, REX7
        • Yoshi
          rchobbystar.eu
          • 20.09.2012
          • 677
          • Rheda-Wiedenbrück
          #2254
          Dann guckst Du jetzt!
          AIRPLANE_ESC_HV_readme.txt
          2015-08-07
          2015-07-17
          2014-03-18
          2014-02-21
          2013-05-13
          2012-12-4
          2012-4-1
          2011-9-21
          2011-8-31
          2011-1-19
          2010-11-06
          2010-5-12
          2010-4-22
          2009-12-24
          2009-10-23
          1.first release
          Zuletzt geändert von Yoshi; 11.08.2015, 22:35.
          Michael
          KDS 450C,450SD,550
          • frank.wagner
            • 04.07.2010
            • 370
            Funktioniert der Hobbywing Platinum 100A V3 Regler
            mit dem neuen Flybass System MICROBEAST PLUS PRO-EDITION (inkl. Rettungsmodus ) ?
            Hat diese Kombination schon jemand im Einsatz ?
            • Der_Basti
              • 17.07.2012
              • 1299
              • Sebastian
              • Abu Dhabi
              #2256
              Warum sollte das nicht funktionieren?
              [CENTER]People fly airplanes...Pilots fly helicopters![/CENTER]
              • parkplatzflieger
                • 18.03.2012
                • 8994
                #2257
                Wo erwartest Du ein Problem? Bei der Nutzung des Beast-Governors?
                Torsten
                Voodoo 600, Logo 600SX
                Spektrum, Spirit, Heli X
                • buell47
                  • 11.12.2014
                  • 4161
                  #2258
                  Falls der Lüfter auch wie bei mir und ein paar anderen zu stark vibriert, kann es zu Problemen mit dem Rettungsmodus kommen, da sich der Horizont verschiebt.
                  In dem Fall hilft dann nur weglassen oder für 5-20€ einen vernünftigen Lüfter zu kaufen.
                  Mehr Probleme sind nicht zu befürchten.
                  Der Regler selber ist Top und das noch zusätzlich zu einem Hammerpreis.
                  Wie kommst du jetzt vom BD3SX zum BeastX und hast dabei das Spirit FBL unberücksichtigt gelassen?
                  Guck dir mal den BeastX Thread an und du wirst feststellen, daß dort nicht gerade wenig Leute Probleme mit der Rettungfunktion haben.
                  Gruß Frank
                  G700C Carbon, Kosmik160, Pyro800-48, MKS950/980
                  T-REX 550L, Spirit, MKS, DX9
                  • rrunner
                    rrunner
                    #2259
                    Ich fliege ohne den Lüfter! Bei wie derzeit 38° im Schatten fliege ich ohnehin nicht und bis zu 30° null problemeo mit dem Teil!
                    • leaf
                      • 28.12.2007
                      • 2092
                      • norman
                      #2260
                      meiner Schaltet öfter ab bei 30'
                      • patrik_mk2
                        Oxy Teampilot
                        • 08.03.2014
                        • 174
                        • Patrik
                        #2261
                        Bei ca 24 grad und 134A laut Telemetrie noch kein Problem ohne Lüfter
                        Lg
                        • stephan1985
                          stephan1985
                          #2262
                          Bin mim 400er Voodoo bei 36°C 5 akkus hintereinander geflogen, peak waren 105A . Regler ohne Lüfter und unter Haube mit null Luftzug --> Läuft tadellos
                          • Capelini81
                            • 26.03.2014
                            • 291
                            • Marcel
                            #2263
                            Hi zusammen,
                            ich bin der Meinung ich habe es schon gelesen, da der Thread aber so lang und über einen so langen Zeitraum entstanden ist frage ich jetzt mal vorsichtig nach:
                            Laut Anleitung gibt es einen Sanftanlauf (klar ist ja auch für Helis) dieser lässt sich nicht anpassen. Wie lange läuft der HW 100 denn an? Sind das immer die angegebenen 11 sek. unabhängig von der Zieldrehzahl/Regleröffnung? Ich habe mir den Regler jetzt für mein Scale Projekt bestellt - der Sanftanlauf ist eher sekundär aber neugiereig bin ich trotzdem
                            VG
                            Marcel
                            • Dachlatte
                              • 19.05.2011
                              • 9259
                              • Maik
                              • Braunschweig und Umgebung
                              #2264
                              Gibts eigentlich irgendwelche Telemetrielösungen für die Regler ?
                              Banshee 850
                                Ja - sind wohl immer 11s. Finde das passt auch ganz gut.
                                Was mich aber stört: Er startet erst nach rund 8s den Sanftanlauft.
                                Also 8s lang passiert gar nichts, dann geht er in 11s auf die entsprechende Drehzahl.
                                An was das liegt oder ob das normal ist - keine Ahnung. Hatte schon mal gefragt, aber noch keine Antwort bekommen.
