Scorpion HK-4525-520KV (Limited Edition)
Dieses Thema ist geschlossen.
  • bronti
    • 16.10.2005
    • 3465
    • sven
    The Scorpion HK-4525-520KV Limited Edition motor* is designed for using on 700 class helicopters running on 12-cell Li-Po power. This motor represents the most technologically advanced power source ever offered for a 700 class electric helicopter and also produces 20% more torque than the Scorpion popular HK4035 series motors and exceed 89% efficiency.
    Each of the new HK-4525-520KV Limited Edition motor is wound with a single strand of 1.4mm wire for the highest possible efficiency. This motor is capable of running continuously at an input power of 4450 watts at 100 amps, and can handle peak inputs of 9600 watts and 215 amps for 2 seconds
    Scorpion Competition Series Brushless Motors are built from the best materials available, and are designed to provide both quality and performance at an affordable price. Scorpion starts with high quality aluminum alloy parts that are produced on the latest CNC milling machines. These parts are then gold Electro-Plated to provide a beautiful, long-lasting finish. The stators are made with 0.2mm laminations to give maximum efficiency, and minimum Eddy current losses. The stators are epoxy coated to prevent shorts, and are wound with wire that is rated at 180 degrees C (356 F). The magnets used in Scorpion Motors are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use.
    Scorpion Motors are built to last, and are backed with a 2-Year warranty against defects in materials or workmanship. However, due to the high RPM of these motors, and the fact that we cannot control the installation and setup, the bearings are not covered by the 2-Year warranty, nor is any subsequent damage caused to the motor by a bearing failure. Bearings are a normal wear item, and as such, need to be maintained and changed periodically. For maximum life, make sure that a sufficient gap is left between the pinion and main gear during motor installation to avoid binding, and put a small drop of oil on each bearing every 5-6 flights. It is the responsibility of the pilot to ensure that the bearings are maintained properly.
    For the best overall combination of quality, performance, and value, uses Scorpion Motors in your helicopter!
    *This motor is using 30mm bolt spacing on the mounting with M4 Screw holes
    Patent Pending
    Specifications
    Stator Diameter 45 mm (1.77 in)
    Stator Thickness 25 mm (0.98 in)
    No. of Stator Arms 12
    No. of Stator Poles 10
    Motor Wind 9 Turn Delta
    Motor Wire 1-Strand 1.4 mm
    Motor Kv 520KV RPM/Volt
    No-Load Current (Io/10V) 1.77 Amps
    Motor Resistance (RM) 0.014 Ohms
    Max Continuous Current 100 Amps
    Max Continuous Power 4450 Watts
    Weight 546 Grams (16.70 oz)
    Outside Diameter 55.6 mm (2.19 in)
    Shaft Diameter 5.98 mm (0.24 in)
    Body Length 53.4 mm (2.10 in)
    Overall Shaft Length 91.5 mm (3.60 in)
    Max Lipo Cell 12s
    Max Peak Current 215A (2 seconds)
    Max Peak Power 9600 Watts (2 seconds)
    Motor Timing 5deg to 15 deg
    Drive Frequency 8kHz
  • rexmex
    rexmex
    AW: Scorpion HK-4525-520KV (Limited Edition)
    Goil, da isser
    • RaidRush
      RaidRush
      Nice, hoffen wir mal das er bald in Deutschland ankommt. Hier in Frankfurt wird er schon erwartet
      • prof.
        • 25.08.2010
        • 199
        • Rainer
        • mbc-friesoythe
        Habe leztete Woche einen bekommen. Direkt in HK bei Scoprion bestellt. Im Trex 700 eingebaut. Nur geil der Motor.
        • marndra
          • 03.03.2008
          • 2935
          • Laudenbach bei Heppenheim ->wild; Weinheim -> Flugplatz
          Den 601er gibts direkt bei Parkflieger:
          RC Modellbau Shop mit umfangreichen Sortiment von Marken wie Scorpion, Dualsky, Rockamp und SkyRC. Schneller Versand und günstiger Preis.
          grü�e marndra
          • prof.
            • 25.08.2010
            • 199
            • Rainer
            • mbc-friesoythe
            Scorpion HK4225-610 Limited Edition*?
            Meine den 4525 520KV (Limited Edition)
            • klausk
              klausk
              http://www.parkflieger.eu/Scorpion-H...tail_3525.html
              hier geht es aber um den 4525
              Gruß Klaus
              • prof.
                • 25.08.2010
                • 199
                • Rainer
                • mbc-friesoythe
                ßbriegens die Produkton ist eingestellt worden. Limit erreich!!! Habe zum Glück frühzeitig noch einen Bestellt.
                Kommt in meinen TDR rein.
                • RCHelis4-ever
                  • 22.05.2009
                  • 1130
                  • Dominic
                  • Niederauerbach
                  ist das ein Fehler oder gings wirlich so schnell?
                  Sorry, order quantity had reached the limit for this motor.
                  zu Deutsch
                  Entschuldigen Sie, aber die Nachfrage hat die Limitierung des Motors erreicht.
                  * kanns ja wohl nicht sein oder?
                  wieviele waren es? 150? das is etwas wenig... naja ist eh nicht interessant für mich
                  T-Rex 450
                  T-REX 500
                  • nexus665
                    nexus665
                    Da kann ich nur sagen, wickel doch mal 150 Motoren mit 1,4er Draht Das dauert schon ein bißchen länger als mit Litze...
                    Der Motor ist genau wie der 4225-610 eine Limited Edition - also eine limitierte Serie. War von vornherein klar. Die Stückzahl klingt auch nicht ganz unbekannt...
                    Zeigt aber auch, daß sehr wohl Interesse und Bedarf da ist für solche Motoren.
                    lG,
                    Simon.
                    • prof.
                      • 25.08.2010
                      • 199
                      • Rainer
                      • mbc-friesoythe
                      Da ich schon lange fliege, aber hier im Forum neu bin. Würde mich interessieren wer einen besseren gekauften Motor kennt?? Also kein Powercroco. (Eigenbau)
                      Habe schon viel im Netz gesucht, aber Gewicht/Leistung keinen besseren gefunden. Daher habe ich auch zwei 4525 bestelllt.
                      Ist so ne Frage an die Top-Piloten in 3D.
                      Mein T-rex 600 ist umgebaut mit einen 4035/800, Regler Phönic ICE 160. Macht ca. 3000 umdrehungen auf dem Blatt. Die Leistung ist ausreichend. Beim 700 suche ich noch die Grenze.
                      • Deluxe1
                        • 27.05.2008
                        • 1323
                        • Philipp
                        Bin ich froh, dass du nicht in meiner Nähe fliegst.
                        • BRoman
                          • 12.03.2008
                          • 247
                          • Roman
                          • IG Heliflieger Bornheim
                          3000 klingen aber wirklich etwas viel? Für was für einen Flugstil benötigt man denn diese Drehzahl mit 600er Latten? Ich fliege auch ganz gerne mal viel Drehzahl, aber das finde ich schon ein wenig sehr viel
                          [FONT="System"]Banshee 850 [/FONT]
                          • Michelfrank
                            Michelfrank
                            Vielleicht ist das:
                            gefühlte 40% : womit du auch gleich mal schön gezeigt hast, was man mit einer ganz simplen fehlabstimmung des systems ohne jeden nutzeffekt an eingangsleistung einfach vernichten kann. :D vg ralph
                            und das:
                            @werner, manchmal ist es einfach nur schade, dass es kein voll durchsichtiges CFK Chassis gibt!:cry: ... aber gewusst dass ... ist schon eine Genugtuung!:)
                            ja der Vorgeschmack auf die nächste "limited edition" von Scorpion.
                            Michelfrank
                            • mavnezz
                              • 21.04.2008
                              • 996
                              • Julian
                              Servus,
                              ich zweifel in keiner Weise an deinen Flugkünsten, aber meinst du nicht das 3000upm nicht ein wenig viel sind? Du betreibst die Mechanik und die Blätter weit ausserhalb der empfohlenen max. Drehzahl.
                              Wenn ich 1900upm auf dem Logo 600 anliegen habe geht schon die Post ab, was mit 3000 abgeht wage ich gar nicht zu träumen. Ich glaub ich hätte angst. Und ja, ich hab schon mal eine abgerissene Blattlagerwellenschraube mit dem damit verbundenen Umherfliegen der Blätter gesehen. War "zwar" nur ein 500er, aber doch heil froh, dass die Blätter nicht in meine Richtung flogen.
