Jetzt sind wenigstens schon alle Details bekannt. Hoffe man kann den Hyper jetzt blad vorbestellen.
Features:
Factory Programmed Flight Controller
Bail Out Capability
Active Self Leveling Technology
Designed for Beginner and Advanced Pilots
High Quality Airbrushed Fiberglass Canopy
Easy Maintenance & Repair
High Performance 2212 1450Kv Brushless Motor Power
(4) Engineering Grade 3D Plastic Propellers Included
Integrated CNC Motor Heat Sink System
3S 11.1V - 4S 14.8V Power Options
Integrated Power Distribution Board w/ Pre-Soldered XT60 Connector
All New Hyper Quick ESC Systems
High Quality Carbon Fiber / CNC Aluminum Construction
Durable, Simplified & Robust
Incredible 3D Performance
Spektrum Satellite Compatible
Required for Flight:
(1) 6+ Channel Transmitter
(1) Receiver (Spektrum Satellite / Traditional Rx / Futaba S-Bus - Requires Included Signal Inverter)
(1) 3S 11.1V 2250mah LiPo Battery / (1) 4S 14.8V 1800mah
(1) LiPo Battery Charging System
Specifications:
Class: 400 Size
Width: 310mm
Length: 310mm
Height: TBA
Weight: 610g (Without Rx & Battery)
Voltage Range: 3S 11.1V - 4S 14.8V (3S 11.1V 2250mah / 4S 14.8V 1800mah)
Motors: (4) 2212 1450Kv Brushless Outrunner Motors
ESC's: (4) 25A ESC's w/ Hyper Refresh Rate & Reversible Programming
Props: (4) 8x4.5 Fixed Pitch 3D Propellers
