Triabolo 800
  • Rosauro
    Rosauro
    Triabolo 800
    I apologize as I do not write or speak in German.
    But I just wanted to share with you a 800 class Triabolo.
    Enjoy!
  • Rosauro
    Rosauro
    Triabolo 800
    • Magneto
      Junior Member
      • 16.01.2012
      • 8
      • Joe
      AW: Triabolo 800
      Rosauro Die Triabolo und Fotografien sind fantastisch!
      Zuletzt geändert von Magneto; 03.10.2013, 05:29.
      Team Kontronik ,Helidirect,Cyclone
      • Mike79
        • 28.07.2011
        • 2357
        AW: Triabolo 800
        Nice Dude
        Thx
        Gruss Mike
        [FONT="Verdana"]McpX V2,T-Rex 100/450Pro/550 FBL AR/700N FBL AR/700E FBL MB - DX8[/FONT]
        • Rosauro
          Rosauro
          AW: Triabolo 800
          Thanks guys! This heli is really amazing.
          • Aleusius
            • 24.05.2011
            • 2012
            • caren
            • Rhein-Main
            AW: Triabolo 800
            Hi Rosauro,
            Great work. Which gives me a few questions:
            what kind of blades did you use (mm). What is the rest of your setup? What is your RPM range? What is the weight without a battery
            Best regards
            Caren
            Protos, Diabolo L
            Voodoo 700 & 400
            • Rapti
              • 16.02.2011
              • 2302
              • Ivor
              • Zürich / Schweiz
              AW: Triabolo 800
              Wow, thanks for the pictures. They're great!
              Logo 550SX - Brain - IISI
              A-10 im Bau
              • Eco-Royal
                Gesperrt
                • 04.04.2011
                • 1595
                • Aaron
                • Sinstorf Maldfeldstr,Finkenwerder,Harmstorf
                AW: Triabolo 800
                Nice Nice, where can i view your moives with the cam under the Triabolo?
                • Rosauro
                  Rosauro
                  AW: Triabolo 800
                  [LEFT]Thank you for the response guys.
                  Caren
                  The blades are made by NHP. It is the very first set for the Triabolo800. I had to test them to make sure they work. The blades measures 790mm from bolt hole to blade tip. Weighs 200g.
                  Tail blades: 120mm
                  Motor: Xera 4035-400, 15T
                  ESC: Heli Jive 120
                  FBL: Bavarian Demon
                  RPM: 1200-1400
                  Weight with 12s 5000 70C - 13lbs. I'll get the weight without battery.
                  Eco Royal
                  The underslung mount was only for payload test. I just wanted to see how the heli would respond. The all up weight with the underslung mount is 21 lbs. I was flying at a head speed of 1200 RPM and flew for 10 minutes.
                  I must admit even at 1200 RPM at 21 lbs the heli flew very smooth and stable.[/LEFT]
                  Zuletzt geändert von Gast; 04.10.2013, 01:48.
                  • Rosauro
                    Rosauro
                    AW: Triabolo 800
                    Here are the Triabolo and Diabolo800 before they were combined together...
                    • klauskolb
                      • 15.10.2002
                      • 1626
                      • Schaafheim
                      AW: Triabolo 800
                      Man - these are cool pics
                      You should send them to Gerd Guzicki for his Homepage !
                      Tschüss
                      Klaus
                      • kobayashi
                        kobayashi
                        AW: Triabolo 800
                        Ich geh mal eher davon aus das Gerd den Diabolo sehr genau kennt und darüber auch Bescheid weis. Wenn ich weiter spinne, gibts bald nen 800er Triabolo beim Gerd im Shop.
                        Die Blätter sind ja neu von NHP, Rosauro hat ja geschrieben das er diese für NHP testet. Das klingt schon als gingen die bald in Serie.
                        Wär natürlich der Hammer, ich liebäugel ja schon mit dem Triabolo seid ich den Diabolo habe.
                        Triabolo als 800er bestellbar - da kann mich dann nix mehr halten.
                        Gruß, Tom
                        • Markus rch
                          • 16.03.2013
                          • 298
                          • Cornel
                          • Jede freie Wiese im Süden Deutschlands
                          AW: Triabolo 800
                          Wow nice idea.
                          Die Bilder sehen wirklich Klasse aus....
                          TREX
                          Voodoo 600, TDR 700, 750, TDF
                          MX 20
                          • Mikewoofer
                            Mikewoofer
                            AW: Triabolo 800
                            Also wenn ein Triabolo 800 kommt ist das auch mit Sicherheit das nächste was bestellt wird
                            Hoffen wir das Gerd da was macht
                            Theoretisch kann man ihn ja jetzt schon kaufen . Mann müsste ja nur einen Triabolo mit 800+ Umbausatz bestellen .
                            Zuletzt geändert von Gast; 19.10.2013, 14:32.
                            • patrickL3
                              • 23.08.2009
                              • 1531
                              • Patrick
                              AW: Triabolo 800
                              meiner ist in der Post (800er)
                              Wenn alles super läuft mache ich
                              am Wochenende Bilder. Leider noch
                              ohne die Blätter, die sind noch nicht da.
                              Triabolo 800 Daten:
                              Pyro 800/40
                              Kosmik 200HV
                              BLS 172
                              BLS 256
                              Mini-V- Stabi 5.3 pro
                              Ritzel 19 Zähne 8 mm
                              1000 Umdrehungen bei ca. 60% (bei 3,7V>Zelle)
                              1200 Umdrehungen bei ca. 70% (bei 3,7V>Zelle)
                              1400 Umdrehungen bei ca. 80% (bei 3,7V>Zelle)
                              12S5000 SLS APL
                              Futaba R7008 SB
                              Futaba GPS
                              J-Log 2.5
                              Gewicht:> 5KG
                              Patrick
                              Zuletzt geändert von patrickL3; 20.11.2013, 20:16.
