Gryphon QUASAR Hyper 75V 20A HV Switching BEC GSR-7075
Specs:
Reg Type : Switching
Input Voltage Range : 11V ~ 75.6V (3~18 Cells)
Output voltage Range : 5.2V, 6.0V, 6.8V, 7.4V, 8.4V Selectable
Voltage ADJ : 4.8V~7.7V ADJ (Potentiometer)
Output currant(Peak) : 20A
Output currant(Cont) : 10A
Low voltage alarm setup : 10V~75V (Available GDB-1010 or GDB-1030)
On/Off Switch : Available (GSB-1010P, GSB-1010S, GSB-1030P, GSB-1030S)
Size : 12mm(H) x 31mm(W) x 52mm(L)
Weight : 20g (Excluding Cables)
lg. Enzo
