Höhenansge funktioniert, die ßbersetzungen bei Multirotor sollten jetzt auch passen, Powerbox müsste jetzt auch richtig angesagt werden.
Ein wichtiges Update wurde vor allem für die DX6 implementiert: Wenn die Spannung unter 3.8V sinkt, wird das HF Modul abgeschaltet. Das wird hoffentlich die sterbenden HF Module verhindern.....
Was auch noch nett ist: Die Lautstärke kann mittels Poti oder Slider geändert werden.
2016-January-26
Version 1.06
Changes since 2015-October-24
Features& Improvements
In Multi Rotor models you may now assign trims to the sticks. The Trim/Channel Config screen is available by selecting NEXT from the Trim Setup screen. You may configure different trims per flight mode if you desire. Trim inputs are limited to the trimmer inputs on each radio.
Sound volume is adjustable using analog inputs (sliders, knob).
In Multi-Rotor models, you may now selectively enable trims for the gimbals using the Trim Setup screen and selecting NEXT. Note that the trims can be en/disabled differently for each flight mode, but the input device will be the same for each mode.
After 5 minutes of sounding the System Idle alert, the radio will automatically turn off the RF transmission.
If the transmitter battery voltage gets below 3.8V, the system will automatically turn off RF transmission.
Added status support for Xicoy, evoJet and Hornet ECUs (turbine telemetry).
Corrections
In Sailplane model type, the L and R trimmers did not display the 2- or 3-position status properly. They were blanks, although the roller would change them.
The telemetry log file is now created properly again. The session headers are now positioned correctly.
Correctly exports and imports multirotor models with the -insideâ? and -outsideâ? warnings enabled.
Altitude telemetry is now reported properly in audio for both imperial and metric users, and visually on the Vario status screen which previously did not report imperial negative altitudes properly.
PowerBox Voltage and Capacity speech is now corrected. It had been spoken 10X what it should have.
Some Italian, French, and German translations have been improved in Multi Rotor model type and Telemetry sections.
In Multi-Rotor mode, Throttle Curves with only 3 points will now display and function correctly.
X-Plus channels are now properly configurable and controlled in Multi-Rotor mode. They were previously only usable in Acro, Heli,a and Sail modes.
Telemetry for Turbine Fuel Remaining and Fuel Flow Rate are now properly displayed and alarmed.
This version requires Sound version 1.08 for full compatibility. You should download it from this link. You do not need to re-install this if you already have it from an earlier update.
Spektrum Audio Support
