DX8 Final 2.04 Update verfügbar
  • Freeeeak
    • 11.10.2005
    • 464
    • Finn
    • Wolfsburg-Sülfeld
    Habe auf der Hompage gerade gesehen, das das neue Update als Final verfügbar ist...
    Habe mal die ßnderungen copiert. Ist aufbauend auf die 2.03 beta..
    Version 2.04
    11-17-2011
    Software Features
    â?¢ Added G-Force telemetry support.
    � Added -Knob� to calibration screen so users know the status as they calibrate it.
    The knob neutral point was not being updated during calibration. We also
    corrected the criteria for centering on the sticks to improve functionality in some
    radios.
    â?¢ The Switch Select page more accurately reflects the current switch assignment.
    If a wing or tail type uses a channel that a switch is on, the switch setting is
    changed to INH. It remains INH until manually reassigned.
    â?¢ When a model is copied, the bind information for the copied model is now
    erased. This will allow the user to see that the model is not bound, as it will not
    show DSM2 or DSMX on the main screen.
    â?¢ Calibration for mode changes uses the same screen as when a user manually
    selects calibration. This means that mode change cal requires the user to move
    both sticks in a + format (not like an O, X, L, or T), as well as rotate and center
    the knob.
    Software Corrections
    â?¢ Translations - Improve/Correct translation of some terms for some German
    Helicopter screens. Corrected Italian translation -Alettoni.�
    � Calibration - when calibrating, the knob -neutral point� was not being updated.
    â?¢ Flap System - The elevon flap system bug has been corrected. The flaps now
    work smoothly and move correctly for the given speed values.
    â?¢ Channel Assignments - Scrolling through the wing and tail types does not
    change gear or aux channel assignments until the wing or tail type is actually
    selected.
    Diabolo 800+ BE, Diabolo 600 BE, Goblin 770 CE .... VBar+NEO pimped
  • sparepart
    sparepart
    AW: DX8 Final 2.04 Update verfügbar
    juhuu werds mir gleich draufspielen
    • southside81
      • 29.03.2008
      • 3773
      Und schon jemand mit der 2.04 geflogen?
      • Ainag
        • 15.02.2007
        • 554
        • Bjoern
        • Wuppertal
        Jo, keine Probleme. Vorher die 2.03 Beta drauf gehabt die auch kein ßrger machte.
        Gruss André
        Rex450V2,LTG2100,2221-8,Jazz,HS65HB+S9257
        Rex550V2,Beast(noFBL),600M,Bl100G,DS610+1290MG
        • southside81
          • 29.03.2008
          • 3773
          Kann man einfach wieder aufspielen und weiter machen oder? Normalerweise sollte sich in den Einstellungen nix verändern oder? Hab auch 2.03 drauf und bisher war alles Supi. Brauch ich dann die 2.04? Im großen und ganzen hat sich ja nicht viel geändert oder?
          • Ainag
            • 15.02.2007
            • 554
            • Bjoern
            • Wuppertal
            Hab sie einfach drauf gemacht und gut. Keine weiteren Einstellungen nötig.
            Bringen tut sie dir nichts wenn von den Bugs die in der Liste stehen nicht betroffen warst und
            den G-Force Sensor nicht benutzt. Aber ist halt nicht mehr Beta dann...ist ja fix gemacht so ein
            Update.
            Gruss André
            • Der Falke
              Der Falke
              Ich hatte das Problem, dass im Servomonitor und beim kalibrieren vorher mit der 2.03 Beta der rechte Steuerknüppel für Heck (Mode3) dekalibriert war, und bei der Kalibrierung diese sich nur sichern lies, wenn ich Heck ein Tick nach links gedrückt hatte. Jetzt mit 2.04 ist das so wie es soll, die neue Mitte wird gespeichert bei Stick Mitte.
              Also bringt auf jedenfall was für mich.
              Der Falke
              • _JakO_
                STAX Helicopters
                Teampilot
                • 22.02.2010
                • 1305
                • Jan
                • Köln/Porz
                Bei mir funktioniert auch alles nur beim ersten Speicherstand funk. der Pitch Trimmer nicht (ich brauch ihn nicht aber stört schon) und ich hab auch geschaut ob der Trimm aus ist ,ist aber nicht der fall... lohnt es sich gib´s etwas neues für Heli´s *
                Jan
                LOGO 700 XX/ LOGO 700/ LOGO 600 SX
                • mukenukem
                  • 14.11.2010
                  • 11187
                  • Wien
                  Für Helis ist nix neues dabei, außer korrekte deutsche ßbersetzungen (z.B. TS-Mischer). Und die Kalibriererei wurde überarbeitet.
                  • scoobymike
                    scoobymike
                    Seid Ihr da eigentlich angeschrieben worden? Ich hab (schon wieder) keine Mail gekriegt,obwohl auf der Horizon-page registriert.Seit 2.0 krieg 'ich keine Mails mehr...
                    Mike
                    • leechesx
                      • 31.05.2010
                      • 1119
                      Ich bekomme auch keine emails.
                      • JPJonny66
                        • 20.10.2011
                        • 535
                        • Johann
                        Sind die ßbersetzungen für Nick, Roll, Pitch auch richtiggestellt worden? Waren ja im TS-Menü und im Expo vertauscht.
                        mcpx, 130X, TR450, TR550@600@12S, Goblin 700
                        • Hero67
                          Hero67
                          Wer lesen kann, ist im Vorteil
                          Helicopter screens.
                          • leechesx
                            • 31.05.2010
                            • 1119
                            Irgendwie müssen die mal noch was erfinden, wie man die neue Software noch anderst auf die Funke bekommt. Das ist immer ein Oddysse jemanden zu finden der ein SD-Kartenschreiber hat.
                            • JPJonny66
                              • 20.10.2011
                              • 535
                              • Johann
                              Is, soweit ich mich erinnern kann, bei der 2.03b auch schon dabei gestanden, waren aber trotzdem vertauscht. Wenn HH es endlich geschafft hat, umso besser!
