AW: Baubericht: Vario Hughes MD 520 NOTAR mit Impeller 5 Blatt
What main headspeed are you running (1250rpm, 1300rpm, etc)? Also what fan speed do you think you are running (35000rpm, etc)? Do you think this fan setup would work
1) What main rotor speed are you running on your Trex 700 mechanics?
2) How do you have your two ESC's connected? Are they on a Y-connection to your throttle channel?
3) Who manufacturers your motor? HET Typhoon?
Typhoon 700-68 1200kV
- 1200 KV
-Diameter : 39 mm
-Length : 67.5 mm
-Shaft Dia. : 5 mm
-Weight : 330 grams
-Poles : 4
- Continous power 1400W
- max Power 3000W
Specially designed for 9305-700 fan unit
Great build.
Just wondering if you are using slant main gear or straight cut main gear. If you are using the slant gear is there any problems changing the direction from RH rotation to LH rotation?
If you are using a Scorpion 450 Kv motor, what size pinion and main gear are you using?
@Jan,
the slant main gear version works very wenn in LH rotation for 30 flights now.
it´s the standard main gear 112 T.
Pinion T12. 6mm.
you also build a MD 520??
Thank you for the information.
Yes, I just received the Vario 520 N fuselage. I am in the process of getting the mechanics ready but was unsure about being able to run the Slant gear in the LH rotation. Thank you for confirming that it can run in the LH rotation.
Als Antrieb verwende ich einen Plettenberg Terminator 30-6 und als Regler einen Jeti Master Spin 200 Akkus sind 10 S 2x 5000mah oder 2x 5800 mah also gesamt 10000 oder 11600 mah.
Leistung mehr als genügend und mit den großen Packs habe ich Flugzeiten von knapp 10 min.
Rotorkreis ist genau 200 cm.
Interessant die Modelle groß und klein nehmen sich von der Flugzeit und Stromaufnahme nichts,
Hauptfaktor ist das Gebläse.
Thank you both for the responses. I am almost ready to start my build. I have the fuselage, servos, mechanics, rotor head, gyro, etc, etc, etc. Basically everything except my ESCs and the EDF unit. I'm really excited about starting it. I'm going for the same build as Topknut2.
Topknut2 I did want ask what "C" rating lipo packs you recommend? I currently have Turnigy 6S 5000mah 25C-50C but not sure if I need to go up on the "C" rating. What do you think? Also can I get a clear photo of how your batteries connect?
I finally got my MD520N together and have started the testing phase. I have to say I love this heli. TopKnut I basically used your setup in my build. Thanks for the help!
