FBL Spirit GT
AW: FBL Spirit GT
Das Spirit Pro kann es doch auch schon, 4 TS-Servos ansteuern.Goblin Kraken 700 S
Chronos 700 V2
Protos 700 EVO
AW: FBL Spirit GT
klar kann es das Pro ,,,, doch dies ist auch schon etwas ältere Soft und Hardware
habe es mal getestet, war aber nicht so gut wie das Axon ( Turbinenheli )
das normale Spirit auf dem kleinen Rex ( 500 ) ist top, auch schon in der Grundeinstellung
AW: FBL Spirit GT
Zumindest die Software ist immer noch nagelneu beim Pro.Zitat von NitroRex Beitrag anzeigenklar kann es das Pro ,,,, doch dies ist auch schon etwas ältere Soft und HardwareTorsten
Voodoo 600, Logo 600SX
Spektrum, Spirit, Heli X
AW: FBL Spirit GT
Quelle FB Spirit System
Spirit GT is almost there!
The new flagship is coming.
Let's look closer at the details ð???
We consider it as our state of the art with respect to available units.
Simply because it opens world of much wider possibilities and new features, while making the flight characteristics even better.
GT has hardware completely different from our other units. The processing core ARM M7 can be considered as beast, because it is even 3x faster than Spirit 2 or Spirit Pro. Now with 64bit math operations. All this allows to use processing power for a plenty of new opportunities that will be presented shortly.
Another aspect is new motion sensor with modifications specifically for Spirit System, thanks to TDK.. The sensor is utilizing the latest development of MEMS sensors offering 20bit data stream, superior bias stability and outstanding vibration tolerance. This can greatly improve flight precision, rescue, stabilisation and all GeoLink modes even in a very inconvinient environment. When comparing with the first Spirit units, even these were capable of running perfectly at Gassers or Jets, but now the level is basically two orders higher.
The unit contains not only variety of motion sensors but also the best pressure sensor from Bosch Sensortec. The unit can give you immediately altitude information through telemetry but also it will bring features you know from GeoLink.
Then, Spirit GT has additional memory dedicated for highly detailed logging. No need for SD Cards, all is integrated. This mean you will be able to store all telemetry variables there and even re-play flight with upcoming updates.
Power rail was also highly improved and is more similar to Spirit 2. In other words, two-stage power supply where main peripherals are isolated from the rest, making it extremely safe. Yet it has additional backup capacitors making connected satellites, GeoLink or other devices less vulnerable for a brownouts at extreme voltage drops.
Our aim is to simplify things and this was possible with Spirit GT.
This mean - no more FrSky integration cable for FrSky integration or telemetry. No more FrSky integration cable for S.BUS2. Just one, stright cable. No more JETI integration cable - just stright one.
Full support for FrSky F.Port protocol - with stright cable.
That is still just fraction of the news. For example there will be extension tray that will allow connection of servo amount you want. And all controlled independently, while powered from high gauge wire.
Finally, Spirit GT has extremely high quality connectors from Samtec plated with strong layer of Gold. High current load is not an issue.
All this in rigid aluminium package as small as 36.8 x 29.6 x 13.9mm.
Spirit System is not making just a new products. Our units are equipped with hardware so they can last for tens of years - and handle new features. This mean our focus will remain on all units, including the very first Spirit FBL as well, with all updates together.
AW: FBL Spirit GT
Also ich fliege das PRO im Turbinenheli! Könnte mich nicht beschweren.
Aber das GT wird aufjedenfall probiertGrüße Willi
AW: FBL Spirit GT
Schön anzusehen: LINTECH - zakázková služba - laserový popis krabiÄek Spirit GT / customized service - laser marking - YouTube
Zuletzt geändert von SlowFlyer; 03.05.2021, 17:22."Glück ab, gut Land"
Henry
AW: FBL Spirit GT
Das Ding ist, wird mit Sicherheit spitze.
Mir wäre allerdings lieber sie würden etwas Zeit in die Software, Bedienoberfläche investieren.
Sowohl am PC als auch in der Integration.
Wenn man jeden Tag Einstellungen verändert ok.
Ich stelle halt nur ab und zu mal was ein oder probiere etwas aus, da suche ich mir jedesmal einen Wolf.
Das haben andere übersichtlicher, logischer angeordnet.
Ok, vielleicht liegt es auch an mir
Grüße Michael
..... ein Mitbewerber auf Augenhöhe von Bavarian Demon in diesem Sektor
