Ich würde beides im Vorfeld schon mit loctite untereinander verkleben. Ich glaube mit sekundenkleber kommst du da nicht so weit.
Der Chase 360 Thread
bonsai
AW: Der Chase 360 Thread
Könnte noch was dauern, wenn das neue Ritzel wirklich nicht passtZitat von freakystylez Beitrag anzeigenIch hoffe, das hält solange, bis das Ritzel kommt.
Zitat von von Helifreak (eMail von acme hobbies)Dear Customers,
Firstly I like to thank you for pre-ordered the Chase 360 helicopter!
You should have all been received your orders and maybe even maidened it already, base on the customer feedback globally and test with the designer/engineering team, we have identified the following issues/improvements that you need to be aware of:
- The stock plastic tail blades cannot be used with the Chase, the molds design causing them to be too heavy for the Chase and the material used resulting them flex too much. It will cause high vibration on the tail and make the Chase unflyable, even break the carbon tail boom completely in extreme case. STOP using and discard them immediately please. KDS is making the new molds to produce suitable ones and you will receive 2 pairs of the newly replacement as soon as they become available.
- The original second stage pinion (KC-360-030) was missing the top flange, I have sent out the replacement to you but unfortunately they were wrongly supplied by KDS and are too long to fit in the motor cage assembly, this is very disappointing and embarrassing I am so sorry for the disappointment and inconvenience this must have cause you... Please discard them and the correct ones have been expressed out to me and will be sent to you ASAP.
- Some of the belt pulley (KC-360-017) is not running true, the inner bearing might be the issue, this is an isolated issue so if it affects you, please contact us to arrange a RMA to have it replaced.
That's what we have identified so far, if there is any other issue you are experiencing, please do not hesitate to contact us to discuss. We are committed to improve the Chase and make it the best RC helicopter.
On behalf KDS I say sorry again for all the troubles these might have caused and big thank you for your patient and support!
Regards,
HunternCPX - mCPX BL - T-Rex 250 - 450X - Chase 360 - DX6i - DX9
Achtung Leute, es gibt offizielle und sehr wichtige Infos zu den Problemen:
" Dear Customers,
Regards,
Hunter"You can't make it safe, because fools are too innovative!
Ich denke, das würd nicht viel nutzen, da das Kupferband nicht auf beiden Seiten kupfern ist...Zitat von bonsai Beitrag anzeigenIch würde beides im Vorfeld schon mit loctite untereinander verkleben. Ich glaube mit sekundenkleber kommst du da nicht so weit.
Wenn das Ritzel nicht passen sollte ist das sehr ärgerlich. Gerade wie bei mir, da ich noch zwei Wochen Urlaub habe, und der Chase wohl stehen muss, falls mein provisorium nicht klappt... :/Banshee 850 #05 / Voodoo 700 / KDS Chase 380 / DX18 / IISI
At SZhobby show. Jae - YouTube
Chase 360 with option canopy.
Scorpion 2520-1880kv motor.
Hobbywing 50A V3
KDS Ebar v2
Savox mini servo
Gens ACE 6s 1400mah 45c
Roter tech 366mm main blade 63mm tail blade
bonsai
Zitat von freakystylez Beitrag anzeigenIch denke, das würd nicht viel nutzen, da das Kupferband nicht auf beiden Seiten kupfern ist...
Kannst ja abschleifen.
Ghost
Ich habe das Ritzel mit Flansch von Anfang an dabei gehabt. Verstehe das Problem von KDS irgendwie nicht...!
Geht doch um dieses Rad (das Goldene
) oder verstehe ich alles falsch?
Ja, darum geht esZitat von Ghost Beitrag anzeigenIch habe das Ritzel mit Flansch von Anfang an dabei gehabt. Verstehe das Problem von KDS irgendwie nicht...!
Bezüglich den Heckblatthalterschrauben:
Die des Blade 450x (450 3D sind identisch) passen von der Schaftlänge her genau. Der Schaft hört minimal hinter dem Heckblatt auf, also das Heckblatt liegt komplett auf dem Schaft auf.
Es gibt zwar auch ein Hardware Set mit allen Schrauben etc, aber das ist wesentlich teurer...
Anbei noch ein paar Bilder:
image (20).jpgZuletzt geändert von freakystylez; 24.09.2014, 16:02.Banshee 850 #05 / Voodoo 700 / KDS Chase 380 / DX18 / IISI
Ist ja witzig, die habe ich auch gerade montiertZitat von freakystylez Beitrag anzeigenDie des Blade 450x (450 3D sind identisch) passen von der Schaftlänge her genau.
Die Alignschrauben (H25125T) vom T-Rex 250 passen zwar auch, aber die vom 450X
gefallen mir deutlich besser, hier noch der Vergleich, original-H25125T-BLH1670
Blatthalterschrauben hinten.jpgnCPX - mCPX BL - T-Rex 250 - 450X - Chase 360 - DX6i - DX9
Die HRW-Schrauben vom 450x (450 3D) sollte auch passen...Zitat von Onkel Opa Beitrag anzeigenIst ja witzig, die habe ich auch gerade montiertBanshee 850 #05 / Voodoo 700 / KDS Chase 380 / DX18 / IISI
Gibts eigentlich eine Lösung dafür, dass sich das Kunststoffrad der Heckschiebehülse
nicht mitdreht, das macht bei mir Schleifgeräusche.
Beim 450X ist da eine Sperre drin, das kann sich maximal um 180° mitdrehen.
Man könnte ja einfach ein Stück Kunststoff oder Carbon dort einkleben, spricht da was gegen?nCPX - mCPX BL - T-Rex 250 - 450X - Chase 360 - DX6i - DX9
Einfach einen ordentlichen Tropfen 2K-Kleber rein. So hab ich es beim Goblin 500 auch gemacht. Dann dreht die Scheibe nicht mehr mit.
HelmutYou can't make it safe, because fools are too innovative!
