Das hat mir jemand gerade geschrieben:
Daniel Somm spektrum is working on a firmware update for the 4651t. Until it is released it should not be used with the brain or ikon. Causing motor cutouts because of a particular data packet being sent by the sat.
Weiß jemand was da drüber?
Daniel Somm if your sat loses power or has a temporary connection issue, upon reconnecting it sends a packet that will shut your motor down. Check helifreak. Big thread about it, and spektrum has acknowledged the issue. I-d avoid using that sat until it is resolved. 4649t is good to go
