Spektrum Airware 2.0 mit forward programming
  • -=RAGE=-
    • 01.04.2009
    • 2857
    • Rupert
    • Osterhofen (DEG)
    Die lange angekündigte Airware 2.0 Firmware mit Ausnahme der Sender DX6e/DX8e ermöglicht endlich das forward programming div. Sender.
    Die neuen Updates findet man nach dem Login auf der Spektrum Homepage und den eigenen registrierten Sendern.
    GruÃ? Bert
  • luha
    • 07.10.2013
    • 4847
    • Lutz
    • Lehrte bei Hannover
    AW: Spektrum Airware 2.0 mit forward programming
    Juchu! Super endlich - halt
    <Bullshitbingo off>
    Das bringt dem Nutzer was genau?
    • warhog
      • 06.04.2014
      • 269
      • Tobi
      • Kornwestheim
      Aus dem Changelog:
      New Features
      Except DX6e, DX8e: Forward Programming is enabled. At this time the only
      products it works with are the AS3000-equipped Spektrum PowerSafe receiver
      product line (update your receiver too), and the Blade Fusion 270 helicopter.
      Other product updates will be released shortly which utilize it as well.
      The SD menu now includes the ability to create folders, delete files, and rename
      files. This will reduce your need to access a PC for these simple but important
      SD management tasks needed to help maintain proper backups of your models
      on the card.
      In order to make it easier to register your radios, on power-up the radio now
      automatically writes the serial number XML file that is used during the website
      registration. Note that the radio will overwrite an existing file for this radio type,
      but leave intact files for other radio types.
      After every import, the Validate All Models tool is run in the background to ensure
      that corrupted models are properly eliminated.
      Flight Pack Capacity is expanded to support both A and B datasets from a single
      sensor. Thanks to Kambalunga for noting that we were only supporting Channel
      A data.
      Added support for modern aircraft gyros. Enable the option -3-Axis Gyro� on the
      Aircraft Options screen. This setting then allows access to a new Function List
      menu by the same name. The function allows access to assign a channel to
      control gyro gains, with an optional trim using the Left and Right trimmers (trim
      available on DX9 and higher).
      Added support for improved telemetry Text Generator.
      Added support for telemetry Attitude/Magnetometer device.
      DX9 Only: On the System menu is a new option called Serial Port Setup. This
      allows the enabling of a Crossfire RF system. The Crossfire support including
      information regarding the hardware modification is documented at
      If you are not a Crossfire user, this menu does nothing for you and should be
      ignored.
      NOTE: If you installed version 1.21.07 Crossfire Beta, this version has an
      improved conversion function which may require trim and travel adjustments in
      your models.
      Except DX6e, DX6, DX7: Add Jet Central support as part of the Turbine
      telemetry capabilities.
      DX10t, DX18, DX18QQ, DX18G2, DX18t, and DX20 only: The X-Plus channel
      scheduling algorithm has been improved to provide lower latency by never
      transmitting unused X-Plus channels. To best take advantage of this, when
      adding functions on X-Plus channels start with XP+1, then XP+5, then XP+2,
      then XP+6, and so on.
      Non-Tray Radios only: On the Range Test screen, pressing the trainer switch to
      change between High and Low modes causes the normal click sound.
      Corrections & Improvements
      In Helicopter mode, the radio was using the Elevator Dual Rate/Expo settings for
      the ailerons instead of the Aileron settings. This could cause a very different feel
      for your model if this applies to you. Please verify that your helicopter Dual
      Rate and Expo settings behave as you expect before flying it again.
      Non-Speech radios now honor the Tone/Inh settings for Timer Start/Stop sounds.
      In order to improve compatibility when importing to older versions of radios, it
      does not export VTX data when VTX is disabled or a default configuration.
      VTX interface allows access to all channels, as regional compliance is now
      enforced by the VTX hardware.
      The VTX control screen now accepts telemetry feedback from the VTX device or
      flight controller. When the telemetry data is being received, the VTX screen
      shows a -Status� column to allow the user to confirm operation. Thanks to
      AndWho.
      Some Flight Pack Capacity channel B data was displaying incorrect fields.
      Thanks to AndWho.
      Mixing FLP > anything now works properly. In v1.20 it was using the throttle stick
      as the input instead of the time-controlled Flap System flap output. Thanks to
      ricardo forte.
      The Telemetry Signal Loss alarm now sounds after about 4-5 seconds vs. the
      nearly-instantaneous alert in version 1.20. Thanks to pgoelz.
      The radio will not trigger a Telemetry Signal Loss alarm when going into System
      Mode. Previously it would do that even though RF was disabled.
      Changed the text editing screen to use bold characters in the helper text, fixed
      the >-< (delete) and <+> (insert) characters for proper display, and corrected the
      left/right asymmetry issues in the 1.20 Public Beta version. This also eliminates
      the -jumps� that could happen when moving between different categories of
      characters. Thanks to LenAlessi, davidmc36, and others.
      The text editor is now easier to use. Instead of forcing you to scroll to the right
      set of characters every time, the radio instead inserts the last character on the
      left into the current position when you are changing at the end of the name. This
      should be a big time-saver, since most of the time you will be working with similar
      characters for adjacent positions of a name. Thanks to davidmc36, LenAlessi,
      and others.
      Corrected an issue that could cause a multi-rotor to have incorrect throttle
      outputs when changing from a model that had a lot of throttle trim offset. Thanks
      to jayar.
      When creating new models, the default display for signal strength is changed to
      % Range mode.
      Editing the Signal Strength alarm point now works properly for all display modes.
      In the past, you could get different results from different modes.
      The Vario screen now displays the altitude correctly. Thanks to pgleesonuk.
      The GPS module now reports negative altitude correctly. Thanks to WMF Flyer.
      GPS speed, distance, and altitude data now requires more satellites before
      recognizing the incoming data as valid. This will add very little time to the startup
      process, but should prevent or reduce the number of instances when extremely
      high and unreasonable values are spoken. Thanks to Kambalunga, kallend,
      and others.
      Receiver voltage was incorrectly being spoken when it should have been saying
      -No Data� after timing out.
      It was possible for the Bind Screen to enter a state that only turning off the power
      switch could recover when certain timing constraints were met. This has been
      eliminated by changing the sequence of operations, and by adding a 20-second
      -deadman� timer to report a bind failure. Thanks to sbstnp.
      The Digital Switch Setup screen would enter a mode that kept repeating the last
      two options forever when rolling to the right. Thanks to Mukenukem.
      When adding a new model, the channel monitor & related functions are now
      reset to the default for the transmitter instead of following the previous model.
      Improvements to the Lap Timer system. The Lap Timer is now available in all
      radios.
      The normal 10-second timeout function was active on screens where it should
      have been disabled. Thanks to czorzella.
      Some settings of Digital Switch Setup were not exported. Thanks to czorzella.
      Very long model names resulting in very long export names are no longer
      mangled when the name is edited. Thanks to LenAlessi.
      DX6e Only: Do not give option to change the type of Warning on power-up
      because only Tone is possible in these radios, as they have no vibe and no
      voice.
      DX10t, DX18, DX18QQ, DX18G2, DX18t, and DX20 only: When using the X-
      Plus Input Config screen, you could scroll beyond the PREV button which was
      the last available input. Thanks to davidmc36.
      DX10t, DX18, DX18QQ, DX18G2, DX18t, and DX20 only: When X-Plus is
      enabled and you change the monitor in one of the menus such as Mix or Throttle
      Cut to see X-Plus channels, if you go to the Monitor function the display now
      changes back to the channel monitor setting for this screen. Previously it would
      have allowed the X-Plus monitor to be shown in two places. Thanks to
      davidmc36.
      DX10t, DX18t Only: Switches S & T are functional. Version 1.20 had them
      blocked from operation. Thanks to madmao.
      Non-speech radios Only: Timer alerts were not generated properly. Thanks to
      GadgetMart. Note that timer alert behavior in your existing models may need to
      be changed on the Timer Event Alerts screen.
      High max altitude alarms can now be set properly for alarm points over about
      3200 ft.
      Alarm temperature for 6S LiPo telemetry no longer rolls over at extremes.
      Improved spacing on the Integrated Timers screen to allow room for long
      durations.
      Importing a configuration file which includes a wired trainer setting into a radio
      which does not have wired trainer capability (DX6e) will change the trainer mode
      to wireless.
      Ich wart erstmal noch was alles noch buggy ist
      GruÃ? Tobi
      • michaelczaja
        • 27.09.2014
        • 1489
        • Duisburg
        Zitat von warhog Beitrag anzeigen
        Aus dem Changelog:
        Ich warte mal bis das einer erklärt
        Michael
        • luha
          • 07.10.2013
          • 4847
          • Lutz
          Viel zu erklären gibt es nicht. Derzeit wird nur das AS3000 und der Fusion 270 unterstützt.
          Ich habe mir das Changlog nun durchgelesen und für mich nichts relevantes gefunden.
          Den Fehler mit Nick/Roll DR & Expo kann ich ignorieren, da ich das beim Heli sowieso immer gleich setze.
          Von daher kann ich wieder auf auf die nächste Version warten.
          Trotzdem Danke für die Benachrichtigung. Spektrum hat es nämlich noch nie geschafft mir eine Mail zu den Updates zuzuschicken, obwohl sie meine Mailadresse haben und ich den Mails auch zugestimmt habe.
          • Oxigen
            • 26.01.2013
            • 1193
            • Stephan
            • Oberhausen
            Bezüglich der Möglichkeit "forward programming" beim Fusion 270.
            Das konnte ich aber auch schon mit der 1.21.08.
            Allerdings sehe ich auch mit der 2.00 nicht das beim Fusion 270 was allem Anschein nach der ix12 bei der vorwärts Programmierung vorbehalten ist.
            Also bleibt abzuwarten, wann Spektrum damit rüber kommt so, das ich auch mit der DX9 das sehen kann wie bei der ix12.
            • sascha1603
              • 29.01.2015
              • 754
              • Sascha
              • Kempten Allgäu
              meine IX12 hat das Update allein gemacht heute Vormittag
              bei der DX9 vom Sohnemann hab ich´s mal drauf gemacht
              Hangar:
              Compass Chronos 12S MKS X8, 2x Compass 6HV Ultimate 12S
              • -=RAGE=-
                • 01.04.2009
                • 2857
                • Rupert
                • Osterhofen (DEG)
                Dann wäre das Update - zumindest für mich - wertlos. Andy Kunz von Spektrum sagt, dass alle Sender - bis hoch zur DX20 - das forward programming unterstützen. Daher ging ich schon davon aus, dass auch die "tieferen" Menüs nun zugänglich wären.
                GruÃ? Bert
                • Oxigen
                  • 26.01.2013
                  • 1193
                  • Stephan
                  • Oberhausen
                  Wie bereits oben geschrieben konnte ich die vorwärts Programmierung bereits mit der 1.21.08 beim Fusion 270 sehen. So wie im Handbuch vom Fusion 270 beschrieben.
                  Leider sehe ich mit der 2.0 die "tieferen" Menüs nicht, das habe ich sofort nach dem Aufspielen heute ausprobiert. Das ist wohl der ix12 zurzeit vorbehalten.
                  Vielleicht kommt, da von Spektrum in Kürze noch etwas.
                  • -=RAGE=-
                    • 01.04.2009
                    • 2857
                    • Rupert
                    • Osterhofen (DEG)
                    Mit der "alten" Airware meiner DX6G3 bzw. DX18 G2 konnte ich auch die PID Einstellungen im AR636 des Fusion 270 vornehmen. Knüppelstellung und Panikknopf für enter...
                    Die komplexeren Untermenüs wären das Ziel! Was soll dann das Update?? Oder braucht es für diese Menüs einen anderen Zugangsweg?
                    GruÃ? Bert
                    • michaelczaja
                      • 27.09.2014
                      • 1489
                      • Duisburg
                      könnte bitte mal einer erklären was das bedeutet? danke
                      Michael
                      • mukenukem
                        • 14.11.2010
                        • 11187
                        • Wien
                        Damit kann man Spektrum Stabis vom Sender aus programmieren. Theoretisch. Im Moment wohl nur das AS3000 Flächenstabi. Ich bezweifel daß das BX dazukommt. Geht wohl nur mit Stabis mit Telemetrierückkanal, also kein BX.
                        • -=RAGE=-
                          • 01.04.2009
                          • 2857
                          • Rupert
                          • Osterhofen (DEG)
                          ... Im Moment wohl nur das AS3000 Flächenstabi. Ich bezweifel daß das BX dazukommt. ...
                          Erster Abstatz Release Notes: AS3000 und Fusion 270.
                          GruÃ? Bert
                          • mukenukem
                            • 14.11.2010
                            • 11187
                            • Wien
                            Jaja. Hab ich gelesen
                            Trotzdem wird das BX wohl nicht programmierbar sein.
                            • Robert Englmaier
                              ( Roben155 )
                              • 02.11.2010
                              • 8956
                              Damit kann ich mein FBL, meinen Regler, meine Telemetriesensoren, das 3-Digi, das
                              Spirit, das Unisens .......etc. über meinem Sender einstellen!
                              Sorry für den kleinen Seitenhieb, aber anscheinend bekommt Spektrum das nicht hin!
                              Grüsse Robert
