2.66?
The new firmware 2.66 version is available now with the following improved :
- Improved flight feeling for extrem 3D.
- Upgrade sensor vibration filter, more stable flying feeling , better for cyclic and tail servo.
- Improved tail stop better, more precise.
- PWM output by Tx channel 8 value on R pin (R/G/P port of the unit) for other devices (glow plug control, servo...).
Note: the R/G/P port has not power and GND lines. It has only signal pin. You need to make power cable for your other devices.
wir werden sehen, wobei solange ich die MRCI nicht an den Redline montiere sollte da doch nichts passieren, sonst wäre das Silverline robuster gegen Vibs als das NEO
