Neue Firmware MSH Brain
  • Diablol
    • 03.11.2011
    • 4430
    • Mathias
    • Aalen & Iffezheim
    Da ich eigtl schon im Bett lag und nochmal den PC anmachen musste weis ich nicht ob ich Träume..
    Es is eine neue Soft und Firmware draußen.
    New Software/Firmware 1.0.010/1.3.050 is available
    Release notes:
    - 1.0.010 (firmware 1.3.050)
    - Added Spektrum Binding in software
    - Cyclic Rotational Speeds are now separated for Aileron and Elevator
    - Overspeed after spoolup with some ESC: fixed
    - Dynamic headspeed management during extreme overspeed maneuvers added
    - Random hot start on startup on some ESC: fixed
    - Governor precompensation optimization
    - Added tail drag precompensation
    - Added Cyclic Pitch Pump
    - Added swashplate design in radio setup for see the servo number position
    - In wizard (panel 7) doubled the resolution in swashplate setup
    - Factory default "Tail Dynamics" is now at 6% (easier on TT transmissions)
    - In Model Size Selection (panel 11) Elevator preset D Gain raised
    - Governor: Deadzone range raised now at 0-350
    - Bailout ramp range raised now at 0-140
    - Removed JR trademark from drop down menu and also from swashplate selection
    - Added in cyclic setup instruction "10 degree"
    - Minimum and Maximum throttle pulse width for the esc, is visible also in the Wizard
    - "Motor is Electric" check now is also in the Wizard
    - Inserting, complete, correction, of texts.
    - Overall optimization and bug fixes (Cyclic Ring, Feed Forward, etc.)
    Setting changes to do from previous version :
    - Set the new Rotational Speed
    - VERY IMPORTANT Verify the cyclic rates separately for ail/elv before flying in each bank
    Rates for ail/elev are in Advanced->setup1-2-3->cyclic
    Android version will follow in about 2 weeks, we decided to not hold the new firmware and release for windows and have people enjoy it even if Android not out yet.
    Quelle:New Software/Firmware 1.0.010/1.3.050 is available - HeliFreak
    Naja hört sich ganz gut an aber wie vermutet hauptsächlich eben "nur" der Governor.
    Zum Updaten müsst ihr nur die Software starten mit Internetverbindung.
    Ich werds morgen mal testen wenns klappt, bin eh seit Monaten nicht mehr geflogen..
  • dslraser
    • 25.01.2012
    • 773
    • Heiko
    • Wolfsburg und Umgebung
    AW: Neue Firmware MSH Brain
    ich habe es auch gerade gesehen
    [FONT="Georgia"]GruÃ? Heiko[/FONT]
    • cc1975
      • 27.11.2008
      • 3824
      werds dann mal auf meinem g380 testen am wochenende. bin gespannt ..........
      • KU-HELI7
        • 02.02.2012
        • 1847
        • Helmut
        So, endlich ist auch ganz offiziell bestätigt und in den Anweisungen aufgenommen, dass 10 Grad zyklisch einzustellen sind. Damit sind hoffentlich die letzten Skeptiker überzeugt, dass die 10 Grad korrekt sind.
        Helmut
        • cc1975
          • 27.11.2008
          • 3824
          also hab update grad gemacht, altes setup aufgespielt ist soweit alles gleich geblieben AUßER: die werte für servomitte sind jeweils um 10 nach oben, hatte, 8,6 und 4, jetzt 18, 16 und 14. servomitte ist aber geblieben. bin gespannt standard setup 450 für meinen goblin 380, pitch-precompensation hab ich mal auf 5 gesetzt und tail agility auf 10 (standard soll ja 6 sein)......
          • dslraser
            • 25.01.2012
            • 773
            • Heiko
            Hier die Links zum Download, da in der Vergangenheit auch immer mal danach gefragt wurde:
            (alt-neu, vielleicht will man ja downgraden)
            alt:
            neu:
            Für die anderen Systeme einfach die Namen und Firmwarenummer im Link austauschen und nicht nur "STALLER" sondern "INSTALLER"
            z.B.
            alternative Downloadmöglichkeit ist hier, falls was down ist:
            Ich hoffe ich habe mich nicht vertippt, bin am Handy.
            • marndra
              • 03.03.2008
              • 2935
              Hi, suuuper !!
              na was ich auch gut finde, dass es keine "grundlegende" ßnderung ist und man dadurch das Update ruhig machen kann, da auch auch Tipps gegeben wurden was man danach prüfen sollte.
              Denn ein komplett neues Setup zu erfliegen würde ich nicht, da das oft sehr viel arbeit ist, bis da alles wieder linear ist, wie mans braucht.
              Bin gespannt.
              Vorteile für mich, der Kosmik und Jive Pro fliegt und nicht vom Gov profitiert:
              grü�e marndra
              • Diablol
                • 03.11.2011
                • 4430
                • Mathias
                • Aalen & Iffezheim
                Vorteile für mich der HW Governor fliegt und mehr als 3 rpm Setups braucht:
                Keine...hahaha
                was genau ist das eigtl.
                • Der_Basti
                  • 17.07.2012
                  • 1299
                  • Sebastian
                  • Abu Dhabi
                  Zyklischer Pitch Pump - Mal vom Vstabi´s Pitch Pump abgeleitet
                  Also die Servos fahren ein Stück über die gewünschte Position und dann langsam zurück auf den festgelegten Steuerwert, um ein knackigeres Steuergefühl zu vermitteln.
                  Ich hoffe das kann man so vom Vstabi übernehmen. Wenn nicht lasse ich mich gerne belehren.
                  [CENTER]People fly airplanes...Pilots fly helicopters![/CENTER]
                  • rasterfarian
                    • 22.01.2013
                    • 274
                    • ralf
                    Denke es verhält sich anders. Der zyklische PP entspricht der Paddel-Sim beim VStabi. Der kollektive PP ist das Pendant zum VStabi-PP.
                    Gruss ralf
                    • Diablol
                      • 03.11.2011
                      • 4430
                      • Mathias
                      • Aalen & Iffezheim
                      Ach ja jetzt hab ich das im Setup auch gelesen habs nur vorher nicht gefunden daher konnte ich mir das nicht erklären.
                      Aber dann ists klar was es ist.
                      Is ja ne meeega Entwicklung...
                      Und mal gespannt wer die Tail Drag Comp wirklich braucht.
                      • digi-foto
                        digi-foto
                        Was genau soll das eigentlich sein?
                        • papads
                          • 07.01.2012
                          • 5575
                          • Werner
                          • Koblenz
                          hat jemand über Bluetooth mit der Desktop Software eine Verbindung versucht?
                          Mit der alten Software war das kein Problem. Und für mich sehr praktisch.
                          Mit der neuen Software war kein connect mehr möglich.
                          (Ich meine nicht die Handy APP die ist ja noch nicht aktuell.)
                          • papads
                            • 07.01.2012
                            • 5575
                            • Werner
                            • Koblenz
                            Also, der IOSYS Port wird von der neuen Software nicht richtig angesprochen!
                            Bluetooth über PC ist z.Zt.nicht möglich. (mit der App sowieso nicht)
                            Ebenfalls funktioniert auch der (optionale) Adapter IOSYS > USB nicht.
                            Wer auf diese Verbindungsmethode z.Zt. nicht verzichten will oder möchte, sollte von einem Update absehen bis der Fehler behoben wurde.
                            Werner
                            • digi-foto
                              digi-foto
                              Anscheinend gabs wohl ein Problem mit der FW beim upload zum Server..
                              Man sollte das Update noch mal neu machen, wenns wo ein Problem gibt..
                              Zitat Corrado auf HF....
                              Ok, problem solved.
                              Please update firmware again even if you already are on 1.3.050.
                              For some unknown reason the file got corrupted while charging it on the update server.
                              All the people that will update from now and on will have no prob.
                              Please let us know if the fix is working for you.
                              Corrado
