Hybridlager im O.S. 91SZ-H
  • holco
    holco
    AW: Hybridlager im O.S. 91SZ-H
    Udo,
    I use the Hatori 938 with the OS 91 RZ-H, shim 0.2mm, Enya 4 plug.
    Fuel, 16% carbolin oil and 10% nitro.
    Grub,
    Mario
    • Hughes 500
      • 28.11.2006
      • 1119
      • Udo
      • Zülpich/Heimbach
      Hello Mario,
      It´s so perfectly.
      Gr.Udo
      • holco
        holco
        I have made my first flight (rich) with the Leuschner engine, running very smooth!!
        Bud the ceramic bearing makes a rattle ling sound at idle, is this normal and will this go away?
        Grub,
        Mario
        • Uwe Caspart
          • 19.08.2005
          • 7418
          • uwe
          • EDDS / Goldboden
          Maybe, some rests of Dremel-Action.
          Sorry, insider-joke and I couldn´t resist.
          Kontronik. Simply the best.
          • Hughes 500
            • 28.11.2006
            • 1119
            • Udo
            • Zülpich/Heimbach
            Grub,
            Mario
            Hello,
            this rattle leaves.
            If the engine rattles in the flight, put more a lot of fat.
            Gr.Udo
            • holco
              holco
              Zitat von Hughes 500 Beitrag anzeigen
              Hello,
              this rattle leaves.
              Gr.Udo
              Udo its only in idle, how long will it take before this sound disappears?
              Grub,
              Mario
              • Hughes 500
                • 28.11.2006
                • 1119
                • Udo
                • Zülpich/Heimbach
                Hello,
                12 - 15 litre. for run in the bearing.
                give Power, on and on power.
                rings the engine in the flight, put more a lot of fat, ready.
                Gr.Udo
                • ferry
                  ferry
                  mario , how is your engine going , did the sound go away ?
                  mine is superr and is not making noise any more [20 liter] , running smooth , starting and idling super , and no vibes !
                  but , i flew today and when i finished , i was just checking the heli , and i felt a little bit of play on the cooling fan .
                  what do you think , is that ok ? mario can you check if you got this also ? it is only a little bit .
                  regards ferry
                  • Hughes 500
                    • 28.11.2006
                    • 1119
                    • Udo
                    • Zülpich/Heimbach
                    Hallo Ferry,
                    gratulation to the nice engine.
                    The play is OK. It,s 0,05 mm axial in the bearing.
                    Give Power, only Power, no Problem.
                    Gr.Udo
                    • ferry
                      ferry
                      ok , but the play is not axial but from right to left . is that bad ?
                      regards ferry
                      • Hughes 500
                        • 28.11.2006
                        • 1119
                        • Udo
                        • Zülpich/Heimbach
                        regards ferry
                        Hello Ferry,
                        from right to left is not ok, examines where it comes here.
                        Gr.Udo
                        • Hughes 500
                          • 28.11.2006
                          • 1119
                          • Udo
                          • Zülpich/Heimbach
                          Hello Ferry,
                          send the engine to Leuschner.You need a new Frontbearing.
                          Send the engine completely with collingvan, of the fans are weighed out.
                          Gr.Udo
