Richtig. Vermutlich ist nämlich nicht nur die Welle zu ersetzen, wenn die mal bricht
Blade 300 Rotorwelle abgerissen.
AW: Blade 300 Rotorwelle abgerissen.
wenn die Welle in der Luft bricht, was zu 99 % wohl so sein wird, geht auch einiges anderes bei dem Aufschlag kaputt, das dürfte doch klar sein.
UweGeschmack macht einsam
Qualität geht vor Quantität
" i like Hirobo "
Habe heute folgende Antwort von Lynx bekommen:
"Hi Denis The std shaft have some design issue that made it fragile. Our frame stiffener help a lot, actually can stop the shaft issue. However we not stop our shaft development, we just delay because we are looking the best shaft ever, that must be supervision per design and material to the std one, otherwise no sense to sale it. We made many sample until now and we just get the one that should be the definitive. We will process our test as usual and we will release asap. However, back to the stock 300x main shaft if used with frame stiffener can handle pretty good the hard 3d maneuvers. One more items that will help to reinforce the shaft is the one way system we are releasing this week, this new system have a solid bushing that support and guide the shaft between the 2 frame bearing and assure no bending stress that actually are the std frame / shaft combination that cause the failure. Hope my information help you understand the situation in your heli and the way lynx is following. Thanks again for your welcome contact."
