I am from Cape Town, South Africa. Please help me in English. There is only 2 NT's here. We both started with Webra motors and are not happy. My friend changed to OS FX with Lottle carb. His heli is now running with no vibrations but the FX lacks the power of the YS or C-Spec as in our Tempest and CS helis. I am concidering the C-Spec Heim version but am batteling with information.
1. Is any one using the C-Spec in there NT's?
2. What carburator are you using (Lottle or standard OS 3 needle carb)?
3. What fuel are you using? I would like to use Cool Power 10% so I think the original carb will be the best for me*?
4. Any problems with Vibrations?
5. Do you get the C-spec with reverse crank?
6. Where is the C-spec available?
7. Has any one owned both FX and C-Spec to compare?
I must mention that we do not like to fly F3C or hover a lot, we like to fly 3D only and would like the best for this purpose. Nitro is olso not a problem here. If the flight time is 10 minutes and not 18 minutes it is also not a problem.
Thank you for your help
Andrew Hudson ( andrew3dnt@yahoo.com )
