was ich bis jetzt geschrieben hab:
dear phoenix-team,
at first: sorry for my bad english... i´m a 14 years old boy from germany...
in the forum www.rc-heli.de they all want a new model (Henseleit TDR... a very good an fast(ca.230km/h) german helicopter)
and i would like send you technical informations and pictures for modelling this nice helicopter
if you are realy modelling this modell, i would show this nice simulator to all my friends...
here are the informations and pictures of the Henseleit TDR(ThreeDeeRigid):
Technical data and equipment recommendations:
Name: ............................................... Three Dee Rigid
Production and distribution: ..................... Henseleit Helicopters
Main rotor diameter: 1620mm up ......................
Main rotor blades: ................................ 680 to 720mm
Recommended main rotor blades: .............. 710mm / approx 63mm deep / 185g
(specially developed and tuned on the helicopter blades are optional)
Tail rotor blades: ................................. up to 110mm Carbon blades
Unladen mechanics: ............................................. 1 , 7kg
Weight ready equipped flight without propulsion battery ............ 3.0 kilograms
Take-off weight, depending on battery power: ............ 3.9 to 4.6 kilograms
Take-off weight of battery recommended by the manufacturer: .......... 4.2 kilograms
Hood length tip to tail end: 1420mm .............
Overall height: ................................................ 370mm .....
Maximum width of the runners: ................................. 200mm
Maximum width of the hood: 140mm ................................
Recommended Motor: Pyro .............................. 30 -12
Recommended controller: ............................. Jive 80 + HV
Recommended gear for 12s operation: ....... 11.48: 1 (14 tooth pinion)
Recommended gear for 10s operation: ....... 10.04: 1 (16 tooth pinion)
(Among other settings are optional available)
Fixed not updateable sub settlements:
Translation of main rotor to tail rotor: ................................ 1: 5.1
Gear intermediate shaft to the main rotor: .................... 2.55: 1
Recommended rotor speeds: ...................... 1300 to 1850 rpm
V-max (straight forward in the excursion): ............................... 185 km / h
Recommended RC-plant (frequency): ................................ 2,4 Ghz
Servos: (strong and fast high quality digital servos standard size)
e.g. Futaba BLS 451 (3 pieces for dei swashplate) BLS 251 (1 piece for the rear)
When using the recommended control is not a receiver battery is necessary.
Recommended flight battery:
12S1P 3700mAh 1180g
12S1P 4000mAh 1290g
12S1P 4500mAh 1390g
Pictures: http://www.myimg.de/?img=800pxTDRYellow2c9872.jpg
oder kann jemand den für den phoenix machen... ich meine "Matt" kann das... wenn es möglich ist... dann bitte ich dich hiermit im namen aller phoenixbenutzer:
[SIZE="7"]BITTE!!!!!!!![/SIZE]
der zeit aufwand sind die folgenden dankeschön doch wert oder*
