2009 ircha
  • bronti
    • 16.10.2005
    • 3465
    • sven
    AW: 2009 ircha
    kurzes off topic
    mah/1000 xV= wh
    100 wa/h = 8 gramm
    wenn ich nen 12 nehme mit 3,85v hätte ich 231 sprich 18,48 gramm
    Lithium Ion Batteries with over 25 grams ELC are forbidden in air travel
    Equivalent Lithium Content (ELC). ELC is a measure by which lithium ion batteries are classified. 8 grams of equivalent lithium content are equal to about 100 watt-hours. 25 grams of equivalent lithium content are equal to about 300 watt-hours.
    You can arrive at the number of watt-hours your battery provides if you know how many milliamp hours and volts your battery provides:
    mAh/1000 x V = wh
    Most lithium ion batteries marketed to consumers are below 100 watt-hours (8 grams ELC). If you are unsure of the watt-hour rating of your lithium ion battery, contact the manufacturer.
    Lithium Batteries. When you see this term alone on SafeTravel pages, it refers to both lithium ion batteries and lithium metal batteries. Lithium polymer batteries are a kind of lithium ion battery, and so are also included in this term.
    Lithium Ion Batteries. These are rechargeable lithium batteries, like the ones found in cameras, cell phones, laptop computers, and radio-controlled toys. Lithium polymer batteries are a kind of lithium ion battery.
    Larger Lithium Ion Batteries contain between 8 and 25 grams Equivalent Lithium Content (ELC). Some very large after-market laptop computer batteries, and some batteries used for professional audio-visual application, fall within this definition.
    Smaller Lithium Ion Batteries contain up to 8 grams Equivalent Lithium Content. Cell phone batteries and most laptop computer batteries fall below the 8 gram threshold.
    Lithium Ion Batteries with over 25 grams ELC are forbidden in air travel.
    Lithium Metal Batteries. These are lithium batteries which can not be recharged. They are designed to be discarded once their initial charge is used up.
    Larger Lithium Metal Batteries contain over two grams of lithium, and are forbidden in air travel. (No common consumer lithium metal batteries are in the "larger" category.)
    Spare Batteries. Spare batteries, also called "loose" batteries, are batteries which are not installed in equipment. A lithium ion battery inside your computer is an installed battery. A battery you carry separately in case that battery runs low is a spare battery.
    Watt-hour. For the purposes of this page, the watt-hour serves as an indirect measure of Equivalent Lithium Content (ELC). 8 grams ELC are about equal to 100 watt-hours.
    • bronti
      • 16.10.2005
      • 3465
      • sven
      AW: 2009 ircha
      2009 IRCHA KME Engines
      2009 IRCHA Castle Creations
      2009 IRCHA Bert kammerer Sat Demo
      2009 IRCHA Hiroki Ito Sat Demo
      2009 IRCHA Marcus Kim Sat Demo
      2009 IRCHA Martin Gotschling Sat Demo
      2009 IRCHA Matt Botos Sat Demo
      2009 IRCHA Nick Maxwell Sat Demo
      2009 IRCHA Justin Robertson Sat Demo SAVE! meinten wohl jamie
      2009 IRCHA Kyle Stacey Sat Demo
      2009 IRCHA Dominic Hagel Sat Demo hagel schorsch oder the dome hägele
      • WalsumerA3
        custom-canopy.de
        Haubenlackierungen
        • 11.07.2008
        • 5582
        • Sven
        • FSC Duisburg
        AW: 2009 ircha
        [SIZE="3"]2009 IRCHA Jamboree: Alan Szabo & Lukas Rivas Music Video Trailer[/SIZE]
        http://vimeo.com/6135363
        Gruß Sven
        Align 700XN coming soon
        • helijonas
          • 26.01.2008
          • 3027
          • Jonas
          • Berlin
          AW: 2009 ircha
          GEEEIILLOOOOOO
          Warum gibts denn nichts von unsrem Dr. LOOOOWWWW *
          Da bin ich sowas von heiß drauf, er und ein 90er E
          Gruß Jonas
          • bronti
            • 16.10.2005
            • 3465
            • sven
            AW: 2009 ircha
            IRCHA 2009 photo compilation
            IRCHA 2009 - Protos 500 First Crash!
            IRCHA 2009 - TREX 700 Night Flight Crash
            Zuletzt geändert von bronti; 17.08.2009, 22:10.
            • RV
              RV
              Mikado-Heli.de
              VStabi-Support
              • 02.06.2001
              • 7766
              • Rainer
              AW: 2009 ircha
              Sodele, auch meine IRCHA Eindrücke sind soweit fertig:
              http://www.vstabi.de/forum1/read.php?10,31148
              • helijonas
                • 26.01.2008
                • 3027
                • Jonas
                • Berlin
                #37
                AW: 2009 ircha
                Warum gab es nichts vom besten deutschen Avant Teampiloten ??
                SEHR SEHR schade...
                Gruß Jonas
                • Albert
                  • 17.04.2001
                  • 8599
                  • Albert
                  • MFC Hochstadt
                  #38
                  AW: 2009 ircha
                  bei Runryder gibts auch schon Video´s.....
                  Und das Nachtflugbild von Mark Fadeley ist das beste, das ich je gesehen habe....
                  Albert
                  • helijonas
                    • 26.01.2008
                    • 3027
                    • Jonas
                    • Berlin
                    #39
                    AW: 2009 ircha
                    wie geil !!!!
                    • Pascal Chr.
                      • 20.04.2007
                      • 200
                      • Pascal
                      #40
                      AW: 2009 ircha
                      hier jetzt auch die Videos von Runryder: (ua.Daniel Jetschin mit Avant)
                      und ein kleines Bild :-)
                      Mfg.Pascal Chr.
                      • Eddi E. aus G.
                        • 12.12.2003
                        • 6399
                        • Edward
                        #41
                        AW: 2009 ircha
                        Der hat ja wieder ein V auf'm Kopf ... falschrum
                        • helijonas
                          • 26.01.2008
                          • 3027
                          • Jonas
                          • Berlin
                          #42
                          AW: 2009 ircha
                          ganz ohne das V gehts wohl doch nicht
                          • Falk7
                            • 07.09.2005
                            • 3303
                            • Falk
                            • Holleben
                            #43
                            AW: 2009 ircha
                            ist aber schon ein merklicher Unterschied zum Logo 600 !
                            GFB1
                            [FONT="Trebuchet MS"]Logo 600sx, Logo 690sx, T-Rex 700L Dominator[/FONT]
                            • helijonas
                              • 26.01.2008
                              • 3027
                              • Jonas
                              • Berlin
                              #44
                              AW: 2009 ircha
                              ja, geht viel schlechter (steigleistung) und ist deutlich behäbiger als andre 90er! Meiner subjektiven Meinung nach war das Nitrolike, wenn nicht drunter.
                              Aber ich denke mal die Maschine war nicht ansatzweise ausgereizt und da geht am Pitch und bei der Drehzahl noch deutlich was nach oben. Klar, ist kein 600er, aber auf Roll und Nick ging ja auch kaum was, nu weis man aber nicht ob es daran lag das dani nur soft fliegen wollte und wenig geknüppelt hat und er sich erstmal auf die Maschine einstellen muss/te. Das der/die? Aurora aber nur so dürftig geht glaube ich jedenfalls nicht.
                              Das was jedenfalls alle erwartet haben, vor allem bei einem Demoflug drüben bei den Amis, ist auf jeden fall nicht dagewesen. Wenn man Jahrelang immer und überall so saugeile Shows abliefert liegt die Messlatte eben ziemlich hoch
                              Gruß Jonas
                              Zuletzt geändert von helijonas; 19.08.2009, 18:25.
                              • vw-bussmann
                                • 03.01.2007
                                • 1518
                                • Oliver
                                • Kirn/Bad Sobernheim (Verein)
                                #45
                                AW: 2009 ircha
                                Evtl. hattense nur einen und er durfte nicht wie er wollte (war das in München wo er 3 Stück gekillt hat in 5 Minuten), oder die Kiste war nicht auf ihn eingestellt.
                                Irgendwo mittendrinn sah es auch aus als hätter er ihn mal mit dem Heck am Boden touchiert.
                                Hatte mir auch was anderes vorgestellt normalerweise brennt doch die Luft.
                                Sah irgendwie so aus , als wollte er dem behäbigen Vogel Beine machen , klappte aber nicht.
                                Naja mal abwarten, evtl. schreibt er mal was dazu.
                                Es wäre sehr schade wenn ein solcher Top Pilot , "Nur" weil er mal eine Luftveränderung macht , von der Bildfläche (Videos) verschwindet.
                                Gibt es eigentlich Avant in Deutschland *
                                --GruÃ? Oliver--
                                My Tube
