Hitec Drehzahlsensor im Eigenbau
  • Chris Benndorf
    • 30.12.2008
    • 414
    • Chris
    • MFSV Sippersfeld, Pfalz (und auf der Wiese nebenan)
    Ich habe ein wenig gebastelt und einen meiner Arduinos dazu gebracht, die Drehzahl meines Helis zu messen und an die Hitec HTS-SensorStation zu uebermitteln. Der Vorteil der Bastel-Loesung ist, dass man auch andere Sensoren nutzen kann, als die von Hitec vorgegebenen - sprich: Alles, was ein Rechteck-Signal erzeugt!
    Hier der Arduino-Code:
    Code:
      RPM Sensor for Hitec HTS-SS
      Times a pulse on D2 and pulses it out on D13 in Hitecs RPM sensor format
      This example code is in the public domain.
    #define LED  13
    #define SENSOR  2
    void setup() {
      pinMode(LED, OUTPUT);
      pinMode(SENSOR, INPUT);
      digitalWrite(LED, LOW);
      // PullUp for the sensor (may be needed for hall effect sensor)
      // digitalWrite(SENSOR, HIGH);
    void blink_Bit(bool b) {
      digitalWrite(LED, b);     // turn the LED on (HIGH is the voltage level)
      digitalWrite(LED, LOW);   // turn the LED off by making the voltage LOW
    void blink_BCD(uint8_t bcdnum) {
      // 0 = all bits set
      if (bcdnum == 0)
        bcdnum = 10;
      // Blink bcdnum of bits
      for (int i = bcdnum; i>0; i--) {
        blink_Bit(HIGH);
      // Fill up to 10 bits
      for (int i = 10 - bcdnum; i>0; i--) {
        blink_Bit(LOW);
      // long line of stop bits
      delayMicroseconds(25);               // wait a second...
    void blink_Packet(uint32_t rpm) {
      uint8_t value[10] = {0,0,0,0,0,0,0,0,0,0};
      uint8_t i = 0;
      // Convert RPM to BCD
      while(rpm > 0){
        value[i] = rpm % 10;
        rpm /= 10;
        i = i + 1;
      // Send 2 Start bits
      blink_Bit(HIGH);
      blink_Bit(HIGH);
      // and 5 digits as BCD
      blink_BCD(value[4]);
      blink_BCD(value[3]);
      blink_BCD(value[2]);
      blink_BCD(value[1]);
      blink_BCD(value[0]);
    void loop() {
      uint32_t duration;
      uint32_t rpm;
      //Time one rotation, but wait no longer than .5 seconds for a pulse
      duration = pulseIn(SENSOR, HIGH, 500000L);
      rpm = duration;
      if (duration > 0) {
        //Add 2% as offset for the magnet, since it is not measured by pulseIn()
        rpm += rpm / 50L;
        // Devide one Minute (60 * 1000 * 1000 microsecs) by duration of a rotation
        // And devide it again by 10 because the HTS-SS needs it this way
        rpm = 6000000L / rpm;
      // Send rpm to HTS-SS
      blink_Packet(rpm);
      // it needs some time...
      delayMicroseconds(500000L -  duration);               // wait half a second
    Eine kleine Schaltung dazu werde ich demnaechst auch noch liefern, bis dahin ist das wohl eher etwas fuer "Kenner", wobei jeder gerne eingeladen ist, daran mitzuwirken...
    PS: Achtet beim Basteln darauf, dass die Sensor-Station 3,3V Signal braucht! Die normalen Hall-Effekt-Sensoren (TL4905) funktionieren erst ab 3,8V!
    Chris
    Rex 600 N/GT5, 600 ESP/GR-18+3xG, Warp 360 und Atom 500 mit Brain, X3/GR-18+3xG
    GR mz-24
  • Chris Benndorf
    • 30.12.2008
    • 414
    • Chris
    AW: Hitec Drehzahlsensor im Eigenbau
    So, es ist vollbracht - Drehzahl- und Temperatursensor im Eigenbau:
    Als Temperatursensoren (blaue Draehte in den Motor) kann man ganz billige 10KOhm-NTC-Widerstaende nehmen, die Genauigkeit reicht fuer unsere Belange allemal aus.
    Der Code fuer den ATtiny45 (8Mhz) mit einem Allegro A1120 Hall-Sensor (kann 3,3V!) und ohne weitere Bauteile (optional LED + Widerstand):
    Code:
      Hitec RPM Sensor
      Reads sensor pulse on Port_B1 and pulses it out on Port_B0 in Hitecs RPM sensor format
    #define HTS_SS  0
    #define SENSOR  1
    #define STATLED  4
      digitalWrite() ist too slow to get the timing right at 8 MHz so we have to
      address the registers directly
    #ifndef cbi
    #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
    #endif
    #ifndef sbi
    #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
    #endif
    #ifndef nop
    #define nop()  __asm__("nop\n\t");
    #endif
    void setup() {
      pinMode(HTS_SS, OUTPUT);
      pinMode(STATLED, OUTPUT);
      digitalWrite(HTS_SS, LOW);
      digitalWrite(STATLED, LOW);
    void loop() {
      uint32_t duration;
      uint32_t rpm;
      duration = pulseIn(SENSOR, HIGH);
      rpm = duration;
      if (duration > 0) {
        // the duration is a bit off, so add some percentage to get it right...
        rpm += rpm / 13L;
        // If we got a valid signal, we light up the LED
        digitalWrite(STATLED, HIGH);
      // Send rpm to HTS-SS undisturbed from interrupts
      // otherwise the signal is to unstable
      cli();
      blink_Packet(rpm);
      sei();
      // a little pause...
      delay(100);               // wait a tenth of a second
      // Switch the LED off again...
      uint8_t i = 0;
      while(rpm > 0){
        rpm /= 10;
        i = i + 1;
      pulseout_decimal_digit(value[4],true);
      pulseout_decimal_digit(value[3],false);
      pulseout_decimal_digit(value[2],false);
      pulseout_decimal_digit(value[1],false);
      pulseout_decimal_digit(value[0],false);
    void pulseout_decimal_digit(uint8_t bcdnum, boolean send_start) {
      // 0 = all bits set
      if (bcdnum == 0)
        bcdnum = 10;
      // Send 2 Start bits with the first packet
      if (send_start == true) {
        sbi(PORTB,HTS_SS);
        nothing();
        cbi(PORTB,HTS_SS);
        nothing();
        sbi(PORTB,HTS_SS);
        nothing();
        cbi(PORTB,HTS_SS);
        nothing();
        sbi(PORTB,HTS_SS);
        nothing();
        cbi(PORTB,HTS_SS);
        nothing();
        nothing();
        nothing();
      // long line of stop bits - VERY important timing!
      nothing();
      nothing();
      nothing();
      nothing();
      nothing();
      nothing();
      nothing();
      nothing();
      nothing();
      nothing();
    // Some nops as delay to get the timing right
    void nothing(){
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
      nop();
    Der Code ist sehr kritisch im Timing, deswegen ist er auch sehr hemdsaermelig geschrieben. Er laesst sich aber mit der Arduino-Umgebung compilieren und programmieren. Man braucht aber die Hardware-Beschreibung fuer die TinyAVRs und einen Programmer.
    Die "Schaltung" werde ich auch noch einstellen...
    Kabel und Stecker findet man uebrigens in dieser Apotheke, z.B.:
    Litze-gecrimpt-Serie-ZH
    Buchse/Gehaeuse-RM-15-mm-2Pole
    Chris
    GR mz-24
    • miro911
      • 15.02.2012
      • 1957
      • Jochen
      • Düsseldorf und Umgebung
      Ok , ich gebe es zu ! Ich verstehe nur Bahnhof
      • Chris Benndorf
        • 30.12.2008
        • 414
        • Chris
        Mir geht's dabei scheinbar nicht viel besser: Wollte gerade mal einen Flug damit machen, da kippt beim Hochtouren der Heli fast um! Ich Voll-Depp habe nur einen Magneten eingeklebt und mir somit wunderschoene Vibrationen eingehandelt Dabei ist im HZR des Rex 450 extra ein Platz fuer EINEN Magneten vorgesehen... Grosse Helis sind doch viel toleranter!
        Dann werde ich wohl doch auf optische Abtastung des AuRo-Zahnrades umschwenken, dann habe ich wenigstens auch bei ausgeschaltetem Motor die Drehzahl.
        Chris
        GR mz-24
        • Darko
          Forum-Nanny
          • 27.06.2005
          • 8289
          • Darko
          Re: Hitec Drehzahlsensor im Eigenbau
          Hallo Chris,
          Warum keinen Phasen Sensor?
          Darko
          Darko
          • Chris Benndorf
            • 30.12.2008
            • 414
            • Chris
            AW: Re: Hitec Drehzahlsensor im Eigenbau
            Mein Grund: Ich moechte die Kopfdrehzahl wissen und nicht die (verfaelschende) Motordrehzahl.
            Theoretisch ist aber genauso ein Phasensensor anschliessbar. Ein Phasensensor ist mWn. aber auch erheblich aufwendiger und somit teurer (der Spektrum-Sensor kostet weit ueber 20 Euro). Ein gekaufter Magnetsensor (Align) ist fuer 10.- Euro zu bekommen.
            Ansonsten weiss ich derzeit auch nicht, wie man so einen Phasensensor aufbaut - vermutlich ein einfacher Comparator oder Schmitt-Trigger?!
            Chris
            GR mz-24
            • Husi
              • 11.01.2007
              • 117
              • Mirko
              • Darmstadt
              Moin Chris,
              saubere Arbeit von dir. Berichte bitte weiter (auch wenn ich mit MPX unterwegs bin).
              Viel Ahnung habe ich auf diesem Gebiet (noch) nicht. Darum nutze ich im Augenblick diesen Sensor: SM-Modellbau - Brushless Drehzahlsensor für ca. 15€, den ich direkt am Regler verlötet habe.
              Mirko
              • Chris Benndorf
                • 30.12.2008
                • 414
                • Chris
                Demnaechst in diesem Theater (heute angekommen):
                Das ist uebrigens dieser Phasensensor, wobei so ziemlich jeder andere auch gehen wird...
                Melde mich in Kuerze, wenn ich den AVR programmiert und auf eine kleine Platine verfrachtet habe...
                Chris
                GR mz-24
                • Chris Benndorf
                  • 30.12.2008
                  • 414
                  • Chris
                  So, ich habe gerade den ersten Test abgeschlossen, der mich aber vor ein Problem stellt:
                  Wie ermoeglicht man jemandem, der keine Erfahrung mit AVRs hat, die Anzahl Zaehne fuer das Ritzel und das HZR und die Menge Magneten im Motor einzugeben, wenn man nur 3 Pins frei hat (mit 7-8 Pins koennte man das binaer codieren)?. Wenn man einen Programmer hat, ist das ja auch kein Problem - Aber fuer Otto Normalverbraucher...?
                  Ahhh, ich wusste doch, dass Phasensensoren schwierig sind
                  Falls jemand eine Idee hat, raus damit!
                  PS: Ansonsten tut's, wie es soll! Die Konfig ist aber noch hart codiert...
                  Chris
                  GR mz-24
                  • Darko
                    Forum-Nanny
                    • 27.06.2005
                    • 8289
                    • Darko
                    Serielle Schnittstelle wäre mein Vorschlag. Dafür reichen 2 Pins...
                    nen USB zu seriell Wandler hat man von irgendeinem FBL System meistens zu hause...
                    Ansonsten.. hmm schwierig
                    Darko
                    • Linus
                      • 11.03.2010
                      • 1338
                      • Marc
                      • Zumikon
                      LED und Taster oder Codierbrücke. Die LED kann dann im Programmiermodus nett blinken und einem alles mitteilen was es braucht - mit dem Taster oder der Brücke wird programmiert. Regler-like.
                      Linus
                      [FONT="Century Gothic"]linus[/FONT]
                      • Chris Benndorf
                        • 30.12.2008
                        • 414
                        • Chris
                        die Idee mit der seriellen Schnittstelle ist zwar softwareseitig leichter umzusetzen, ist aber spannungsabhaengig (3,3/5V) und kann leicht etwas kaputt machen. Die ganzen Schutzmechanismen einzubauen waere (mir) widerum zu aufwaendig.
                        Die Idee mit dem Taster und der LED finde ich gar nicht schlecht... Wir haetten sogar ein Display, dass die Werte anzeigen kann: Den Drehzahlmesser in der Anlage! Dh.: Wenn man das Setup macht, koennte das Display dazu genutzt werden, die ausgewaehlten Werte darzustellen.
                        Wenn man aber mal abschaetzt, fuer wieviele das ueberhaupt interessant ist, lohnt sich der Aufwand wahrscheinlich gar nicht. Ich war gerade bei meinem favorisierten Elektronikdealer auf der Webseite und habe dort fuer 15 Euro eine Teensyduino-Platine mit USB-Port gesehen. Damit waere es jedem Unerfahrenen moeglich, soetwas zu basteln und zu programmieren. Es sind ja nur noch zwei dreiadrige Kabel an den richtigen Pins anzuloeten. Nachteil: das Ganze koestet dann ca. 30 Euro... Alle die einen AVR programmieren koennen, haben ja sowieso alle Moeglichkeiten offen.
                        Mal sehen, wie ich da weitermache...
                        Chris
                        GR mz-24
                        • Del Torres
                          • 17.05.2010
                          • 1376
                          • Hendrik
                          • Meersburg
                          Halte uns auf dem Laufenden
                          Den Phasensensor hätte ich noch rumliegen
                          Perfekt wäre natürlich wenn das Ganze ohne der Sensor Station geht ;-)
                          Grü�e vom Bodensee,
                          Hendrik
                          • nettworker
                            • 01.03.2012
                            • 111
                            • Dieter
                            Gibts eigentlich was neues?
