DX6i Mailwarnung wegen Knüppelpotis
  • Wings Only
    • 24.11.2002
    • 1057
    • Rudolf
    The Spektrum Signal
    *January 31, 2009*
    ** *Spektrum DX6i Stick Pot Service Bulletin* **
    *** Attention DX6i Users ***
    DX6i owners are advised: our service center has a concern of
    potentially bad stick potentiometers, which can be identified with
    this easy process:
    1) Turn on your transmitter and select the servo monitor display
    2) Smoothly move the sticks in each axis, carefully watching the
    commanded position on the monitor
    3) The monitor should show smooth movement tracking with the input. If
    the monitor “jumps” or hesitates, please send your system
    in for service using one of the links below
    Radios with a date codes of 809E, 810E, 811E, 812E should be carefully
    checked. If your radio does not have a date code, the test is still
    advisable. And please, as is common, check your controls before
    flight.
    We apologize for any inconvenience, and thank you for your patience.
    Spektrum
    DX6i Service--US customers
    Customers outside of the US and Canada should perform the test and
    then contact their local retailer or local Spektrum
    distributor. Distributors may be found here.
    http://MX16.html Last Update März 2012
    Be happy, Rudy
