X3810 pinlayout ppm output
  • diablotin
    diablotin
    Hello friends,
    Sorry i write in english, but i think in German nobody would understand my question! I like to make a wireless Lehrer Shuler link to my X 3810. The first thing i have to do to make that possible is to find where i can take the ppm signal. I know i can take it from the pins if I take the HF module out. This is however not how I want to do it. I like to make an interface connected to the 3,5 mm stereo jack at the back of the transmitter. I like to know i somebody has experience doing this, and at what pins i find which signal. Do I have to to anything else in the software parameters of the transmitter to make this possible?
    I want to connect a receiver via a transistor interface to the jack of the X3810. The student can then use his own transmitter to fly!
    I tried to couple a FMS/Easyfly interface to the jack at the back but until now without success.
    Who helps?
    tks!
  • Maik Otto
    Maik Otto
    sorry
    in der letzten rotor stand ein schöner artikel
    über den aufbau der drahtlosen schüler anlage . aber warum
    verwendest du nicht die normale lehrer/schüler variante ?
    oder habe ich was falsch verstanden?
    • mjustus
      mjustus
      you can get the signal from the 3.5mm Jack at the bottom of the transmitter. Don´t switch the transmitter on and you will find the signal betwen the two contacts at the te tip of the jack. But it has only 1.5V and not the batterie-level. So this transmitter don´t work as the pupil for an MC-XX transmitter; but it works with another 3810 i.e.
      Maik
