Spektrum IX14 Update AirWare 2.02.10
  • Kieselmohn
    • 20.10.2019
    • 240
    iX Spektrumâ„¢ AirWareâ„¢ Change Log
    2025-December-16
    Version 2.02.10
    New Features
    • For new models, by default Hold warnings will be inhibited. The warnings are still
    available, and can be turned on, if desired.
    • On the BNF model template selection screen, added the ability to check for
    updated BNF template files online. An internet connection is required for this
    feature.
    Corrections & Improvements
    • Fastboot alarm handling has been updated so that if a receiver reboots and is
    still in Fastboot mode, the alarm will trigger again.
    • Sequencer List screen no longer crashes due to invalid input. This was seen
    after importing models from other radios that have inputs that are not available
    on the current radio.
    • Sequencers no longer trigger auto selection on the Rates/Expo screen.
    • Side monitor no longer shows "---" for channels whose value is 50%, on screens
    such as Differential and Throttle Cut
    • Default values and behavior for Curved Mixing now match that of Normal Mixing.
    • The Channel Assign screen now properly handles Sailplane models that have
    the Dual Elevator tail type selected. The channel(s) that have the Left Elevator
    assigned are now identified as CP-controlled.
    • Missing turbine fuel macro was added to macro dialog in Audio Events screens.
    • On the Logical Switch Setup screen, for trimmers that have been configured as 2
    positions, the table now identifies which positions are not accessible.
    • The Trim Setup screen for Helicopter models has been updated to work like the
    Acro models, giving more control over the behavior of the trimmers.
    • The Dual Rates and Expo screen has been renamed to Rates and Expo to match
    other air radios.
    • Fixed issue where NSPM files from NX7e radios would fail to import into iX
    radios.
    • A new Low Throttle message has been added to the Bind Screen.
    • The Digital Switch Setup screen has been updated to account for various
    assignments that were missing, including the new Gear functionality, Flight
    Mode, Combo and Logical Switches, Multi Engine, and Trainer.
    • Fixed issue where assigning the same switch with wiggle select for both relations
    in the Combo Switch Setup screen would cause AirWare to freeze.
    • My List menu screen now properly displays in Dark mode.
    Zuletzt geändert von Kieselmohn; 17.12.2025, 08:14.
    T-REX 700L V2, T-REX 550X, T-REX 470LM, Brain2, IX14
