FrSky Twin X Lite S ELRS
Ja aber es geht ja einigen elrs nutzern um die latenz. Deshalb war meine idee das man keine Nachteile mehr hat wenn man den race mode benutzt. Habe mit diesem aber noch keine erfahrung.MZ-24 Pro, Kraken 580, Protos 380, Heim 100 3D
Frage auf dem discord-Server/Rotorflight:
Any disadvantages/advantages using e.g. ACCESS over ELRS?
Antwort:
neither.
they both use LoRa tech
ACCESS is better if you use FrSky tx like X18 or X20
ELRS is better if you use EdgeTx
ELRS does have 500Hz and 1000Hz modes, that are faster than the 250Hz "race mode" with ACCESS
But those are shared speeds with telemetry, so in reality 500Hz is less than 500.
Whereas FrSky 250Hz is "real" 250Hz with telemetry.
The telemetry with FrSky is about the same speed as 500:4 with ELRS
