Iâ??m gonna â??Head Buttâ? my Evo 9 like a French Super Star
  • Burg
    • 22.02.2006
    • 545
    • VA, USA
    Somebody stop me from head butting my Mplx Evo 9 like Zidane did to the Italians. I-ve had it and am about to file it all in the trash!!
    I-m so sick of not being able to set up my GY401 on my Evo 9. Everyone roars on how great these Evo-s are but I can-t get the dang tail to play along. It was a piece of cake to set up on a Futaba 9Z that I was borrowing from my buddy.
    Result:
    1 x T-rex destroyed due to faulty set up gyro (completely my fault)
    1 x inoperable Roxxter 33 (won-t fly w/out having the tail work)
    So, now that I-ve vented my frustrations with Multiplex (which is the Tx that I purchased in the beginning and am determined to make work) I will explain what my ailments are.
    I-ve been flying for a year now and pretty much know what I-m doing in the air and know how to set up GY401-s, etc (with a Futaba 9Z).
    I-m determined to get the Mplx Evo 9 to work.
    In my T-rex I-m using all high quality parts (Jazz/401/Rex motor/SE vers.)
    I thought I had the 401 set up correctly on the T-rex. All the right lights are solid in HH mode and blink when I move the rudder stick. As soon as I let go the light is solid again.
    The heli hovers very solid but when I punch + pitch the tail spins out of control. I-ve increased the gain on the digi adjuster and watched how it spun first slow and then uncontrollably to the ground and smashed into a bunch of pieces. I haven-t crashed like that in a long time. I almost jumped on the heli in sheer frustration.
    So that-s my first problem, the T-rex tail couldn-t keep it in HH. Could the problem be that I didn-t have enough rpm-s on the head? 2450 rpms should be enough to keep the tail solid.
    Now for the one that is really bugging me. I can-t get the tail slider to -stickâ? in HH mode on the heli. I start it up in HH mode and wait for the tail to set  red light is solid but turns off after a short while. Why I don-t know. It worked fine with my Futaba 9Z. I know I must have a mental block on how to set up the 401 on the Mplx Evo.
    The tail blades start off in HH mode and if I move the rudder stick to one side the tail will stay there but when I move it to the other side the tail slowly moves to the other side until it reaches the mechanical limit. ?!%#!?!?
    Is there anyone out there that knows Mplx Evo-s and will help me set up my tails before I lose another heli to a head but!!
    Auf Deutsch zurueck schreiben geht auch. Ich kanns halt besser auf Englisch erklaeren.
    Vielen Dank!
    T-500, HOSS X4E, hybrid Rex mini MP-e, X9303 2,4GHz
