Handy und Sender in 2m, Multiplex Pressewarnung
  • Wings Only
    • 24.11.2002
    • 1057
    • Rudolf
    Hallo Alle,
    gerade per Mail erhalten, danke Ralph!
    Nachträglich die Originalquelle, somit jetzt doppelt gemoppelt:
    MULTIPLEX Press Release
    December 2004
    Dear all,
    MULTIPLEX is extremely sorry to hear of the unfortunate incident involving the gas-turbine helicopter in early October 2004. An immediate investigation was launched to ascertain the cause. We have also taken into consideration the BMFA Safety Bulletin No 6 relating to the use of mobile telephones in proximity to electronically programmed transmitters.
    The UKRCC (earlier JRCUC) has reported there may be a problem associated with operating mobile telephones in close proximity of programmable transmitters causing memories to be partly or fully erased. This problem has yet to be scientifically substantiated, however, it is generally known that RF radiation can disable or permanently damage some modern electronic devices.
    Although the risk may be small, we believe it should be minimised by bringing to the attention of RC pilots and clubs that pending resolution, we recommend that mobile telephones are not switched on within 10 feet of any programmable transmitter. This may appear to be -overkill-, but better safe than sorry. Care should be taken during pre-flight checks to ensure that all controls are operating effectively in their correct sense and to ensure that the memory has not been affected by any undetected or unknown transmission since the last flight.
    The UKRCC (earlier JRCUC) pointed out that the International limit for radio control RF transmissions is restricted to 100 mW, this means that mobile telephone transmissions could be up to 30 times more powerful. Civil aircraft and hospitals etc. request all mobile telephones or similar electronic devices are turned off, and these are the reasons why MULTIPLEX points out in instruction manuals, particularly in the latest issue for the Royal evo, -Do not operate mobile phones within 2 meters (6 ft 8") of the transmitter-.
    Care must also be exercised when modifying brands of radio equipment. The essential range test procedure, as clearly stated in every MULTIPLEX instruction manual, must be carried out. In extreme cases the manufacturer's warranty could be invalidated together with insurance.
    Flair Products and MULTIPLEX dealers have been informed and are pleased to answer any questions.
    The MULTIPLEX Team wishes you safe flying, but we need your assistance to make flying even safer!
    Fette Hervohebungen von mir.
    Wenn schon Sender so empfindlich sein können, wie gefährdet sind dann Empfänger-Prozessoren?
    Wieder ein Grund MEHR nicht über Personen zu fliegen!
    http://MX16.html Last Update März 2012
    Be happy, Rudy
  • Wings Only
    • 24.11.2002
    • 1057
    • Rudolf
    Zusatzinformation über die Quelle dieser Presse-Mitteilung:
    Dazu hat mich vom rc-soar-Website-Betreiber folgende Mail erreicht:
    Hi Rudolf,
    Karl Hentschel is the man who asked me to post the press release. He is the
    UK marketing manager for Multiplex.
    Kind regards,
    Mike
    Offen bleibt allerdings, warum wir das am "Kontinent" nicht auch schon erfahren haben!
    Oder werden es wir in Bälde doch?
    Grüße, Rudy
    Be happy, Rudy
    • Uli Haslinde
      Uli Haslinde
      Kann mich noch gut erinnern, als alle "Spezialisten" über das handyempfindliche Futaba Synthesizer Modul gelästert haben. Das ist schon fast 10 Jahre her und offenbar konnten die anderen diese Zeit auch nicht sinnvoll nutzen.
      Für mich ist diese Technik einfach nur eine weitere Fehlerquelle und zwar eine, die man einfachst vermeiden kann: Nicht benutzen.
      Die deutschen Hersteller sollten sich viel lieber mal dem Thema PCM widmen. Eine brauchbare PCM Technik würde sicherlich einen Schwung neuer Kundschaft bedeuten.
      Bevor ich damit die endlose Diskussion über PCM oder nicht neu entfache:
      KEINER müsste es nutzen. Ist also kein Grund es nicht anzubieten und so Kreis der Interessenten zu erweitern.
      • lama
        lama
        Auf der anderen Seite wird in den USA gerade darüber diskutiert, ob
        man Handy Telefonieren in Flugzeugen erlauben soll da sich herausgestellt
        hat, dass Handies keinen Einfluss auf die Sicherheit haben.
        Dazu auch: seit Kurzem kann man auf vielen Flügen schon WiFi
        benutzen.
        Also, was auch immer das Problem ist, zu sagen "benutzt mal keine Handies"
        und alles wird gut ist meiner Meinung nach nicht der richtige Ansatz.
        Und zu sagen: uups, wir haben da ein Memory Problem auch nicht.
        FLASH Speicher werden in Millionen Stückzahlen auf der Ganzen Welt
        benutzt, aber man hört nur sehr wenig von irgentwelchen Handy Problemem.
        Da war mal was: "Handy zerstörte Notebook Festplatte", oder so ähnlich.
        Hat man auch gelöst.
        -Joerg
        • Wings Only
          • 24.11.2002
          • 1057
          • Rudolf
          Hallo Alle,
          ich habe jetzt auch den Link zu dem Sicherheitsbulletin Nr.6 aus der Presse-Mitteilung:
          Many thanks to Michael Mike Shellim, RC-SOAR
          Be happy, Rudy
          • Dieter F. Heinlin
            Dieter F. Heinlin
            hier nun die Anwort von MULTIPLEX Modelltechnik GmbH & Co. KG:
            Die Meldung nimmt bezug auf eine Meldung aus England, wo ein Pilot bei einer Royal evo mit umgebauter Antenne, die Anlage war daher eigentlich nicht zugelassen, Störungen durch Betrieb mit einem Handy in weniger als 1 m Abstand vom Sender hatte.
            Grundsätzlich schreiben wir in unseren Anleitungen einen Mindestabstand von 2 m vor. Die einschlägigen Zulassungsbestimmungen bezüglich EMV etc. sollten hier relative Sicherheit schaffen, sie werden von unseren Geräten durchweg auch deutlich übertroffen.
            In der Regel führt Handybetrieb zu keinen Störungen, sie können aber auch nicht verbindlich ausgeschlossen werden.
            Da Sicherheit an erster Stelle steht, sollte für Modellflieger gelten, was auch in Flugzeugen oder Krankenhäuseren gilt: Handy in näherer Umgebung aus. Das wird ja auch in vielen Clubs praktiziert.
            Mit freundlichen Grüssen
            Gerhard Greiner
            Marketingleiter
            Tel. ++49 (0) 7233- 73-0
            Fax ++49 (0) 7233-73-99
            www.multiplexrc.de
            www.hitecrc.de
            • Wings Only
              • 24.11.2002
              • 1057
              • Rudolf
              Danke Dieter für Nachfrage!
              Den RCL-thread habe ich hierher verlinkt.
              In RCN läuft das auch, aber dort kann ich nicht posten. wenn Du dort registriert bist......
              Von einer geänderten Antenne (Wie??) war im Original kein Wort enthalten. ?(
              Wäre ja vermutlich für das Problem gar nicht relevant. Oder doch? Komisch. ?( ?(
              Grüße, Rudy
              Be happy, Rudy
