und noch etwas neues von der Senderfront.
Futaba 9C Super Radios still have 9-channel PCM and 8-channel FM capacity, plus all the same easy programming and the same switches and dials. But 9C Super Radios offer so much more for your advanced R/C pilots: more memory, more functions and more flexibility when it comes to controlling airplanes, helis and/or gliders. This is the system for the modeler who wants it all!
18-model memory - Memory has been expanded to 12 models, and the 16K CAMPac module that's included adds another six models - bringing the total up to 18.
A three-function timer - Can be utilized as an up timer or down timer - or to keep track of total flying time for a particular model - and can be programmed to any of the switches, the power switch or the throttle stick.
Enhancements to all three modes.
Glider Mode - With its extensive glider mode updates, the 9C Super is comparable to other high-end systems! In addition to the Basic offset trim, the 9C Super offers three other offsets (launch, thermal and speed), with camber that can be customized for each. The four camber mixes can be set up on one screen and programmed to any of the variable dials. Besides setup ease, the glider mode boasts much more built-in flexibility. Any R/C aircraft with 4-servo wings will benefit the 9C Super's technology!
Airplane Mode - With either a selectable switch and through channels 5, 7 or 8, fliers can set up a 2-rate (Up/Down) or 3-rate (Up/Center/Down) GYA gyro system. The Air Brake is now switch-selectable.
Heli Mode - Throttle Curve and Pitch Curve now feature a delay that makes for a smoother transition from hover to idle-up and better control. The throttle hold and idle-up can be assigned to any switch that feels more comfortable for the pilot.
Die FF9 Super bietet somit endlich eine langsame Flugphasenumschaltung! Ich glaube das ist das Feature das FF9 Besitzer am meisten vermisst haben.
Dazu kommt noch die freie Schalterzuordnung...
Leider wird das Ding wohl nicht für 270eur zu haben sein. Warten wirs ab! Bis jetzt ist das Ding erst in den USA angekündigt, wie es in Asien/EU aussieht weiss ich nicht.
Gruss,
Andi
aber davon steht leider nix drinnen.
