AW: Kenne die Unterschiede der Spektrum-Protokolle nicht.
Keine komplette Beschreibung, aber hier finden sich zum Beispiel folgende Angaben für die Unterschiede:
Sub Protocols
0 - DSM2 1F
DSM2, resolution 1024, servo refresh rate can only be 22ms.
Note: 'DSM2 1F' was previously labelled as 'DSM 2 22ms'.
1 - DSM2 2F
DSM2, resolution 2048, servo refresh rate can be 22ms or 11ms. All servo outputs will be 22ms when more than seven channels are configured.
Note: 'DSM2 2F' was previously labelled as 'DSM 2 11ms'.
2 - DSMX 1F
DSMX, resolution 2048, servo refresh rate can only be 22ms.
Note: 'DSMX 1F' was previously labelled as 'DSM X 22ms'.
3 - DSMX 2F
DSMX, resolution 2048, refresh rate 22ms or 11ms. All servo outputs will be 22ms when more than seven channels are configured.
Note: 'DSMX 2F' was previously labelled as 'DSM X 11ms'.
eh heutzutage unerheblich da in Europa eh nur noch DSMX bei den Sendern ab der DX9 Black Edition verkauft wird.
Alle anderen Empfänger und Satelliten die kein DSMX machen funktionieren eh a den neuen Sendern nicht mehr.
