binding walkera master cp to futaba t8j
  • 47110815
    • 30.07.2014
    • 4427
    AW: binding walkera master cp to futaba t8j
    ...and start with a new (virgin) modell on the TX and use the manual for the setup.
    Liebe Grü�e
    Thomas
    • jumphigh
      • 16.12.2009
      • 4248
      • Allstedt
      At least for the V120D02S you need a firmware update on the FBL receiver as well. Stock receiver with version 1.1 from Walkera do not work with the RXF-01, you need the "Robbe" version of 2.0. Maybe it's the same for the Master CP? Robbe got a special firmware on request to allow flying with their supported Futaba radios with S-FHSS instead of the stock Devos.
      Grüße von Andreas
      • 47110815
        • 30.07.2014
        • 4427
        Thank you, Andreas.
        Yes, that is correct. Eventually you need a firmware update, but first you should check the other proposed points.
        Zuletzt geändert von 47110815; 04.09.2019, 12:24.
        Liebe Grü�e
        Thomas
        • masoud
          Junior Member
          • 30.08.2019
          • 6
          • masoud
          Hi,,I think you are right ,,,I remember now,,,For my V120D02S I was facing same problem,,
          I had to change the receiver to get it woking,,,But is there any way to upgrade master cp receiver,
          to version 2.0. via USB??
          Thank you,,
          masoud
          • 47110815
            • 30.07.2014
            • 4427
            Yes, for the update you need a Walkera UP02 Interface, i think. But i don't know, where to find the firmware. May be Google helps.
            Liebe Grü�e
            Thomas
            • jumphigh
              • 16.12.2009
              • 4248
              • Allstedt
              https://walkera-fans.de/downloads/, especially Firmware 2.0 for Futaba RXF-01
              Zuletzt geändert von jumphigh; 06.09.2019, 05:51.
              Grüße von Andreas
              • masoud
                Junior Member
                • 30.08.2019
                • 6
                • masoud
                OOOOOHHHH ,,,,What a headache,, I got the up02 adapter, but cannot download the software,,
                Which is really annoying,,OK to download the original software, must visit (Walkera official website - Walkera-Intelligence makes it possible),
                which is the official website,,create an account,, which I already did,, and then download,,
                Unfortunately,,,in Walkera official website - Walkera-Intelligence makes it possible ,,, You see nothing but only drones,,I could not see any thing for heli...I have tried to download from other sources like google,,,,and when I run ,,
                I get a massage saying '' the software is not made by Walkera,,, BANG,,,then I have to delete
                it from the PC,,,I really dont know what do do,,I also tried the link you posted same cannot run..
                I appreciate your feedback on this,,
                Thank you ,,
                max
                • jumphigh
                  • 16.12.2009
                  • 4248
                  • Allstedt
                  Install https://walkera-fans.de/download/too...UP02_Tools.zip.
                  Flash https://walkera-fans.de/download/hel...F-01%202.0.zip with the installed UP02 tool. Inside of the firmware ZIP file there are also two manuals.
                  If it surprisingly doesn't work you can try a manual update on your own. Have a look at the series Flashing new Firmware to Walkera RX/TX without UP02.
                  Grüße von Andreas
