Neue Firmware für Aurora9x und HP-22
  • helibasher
    • 04.07.2010
    • 1141
    • Wildflieger
    ist schon was älter das Release der Firmware aber ich habe es gerade erst entdeckt. Es gibt eine neue Firmware für den HP-22 Programmer V1.19 als auch eine neue Firmware für die Aurora 9x V1.02. Damit lassen sich nun endlich Modelle am PC abspeichern.
    Die Software V1.19 für den HP-22 Programmer runterladen und dort die A9X updaten.
    HPP-22 VERSION 1.19(0) 7/17/2015
    LYNX 4S ver. 1.03(0) Firmware Update (09/14/15)
    Added Functions
    Now displays a warning message when changing Mix Type
    LED can be turned -OFF� in the LED setup
    Users can now select -SCREEN TYPE� for each model
    User can set the -LED� color for each model
    Improved Functions
    Moved �RF-SCAN� menu to the MANAGEMENT screen to avoid confusion
    Saves the setup value on the Auxiliary (AUX) channel
    Maintenance Fix
    Fixed the update error bug
    H4 Charger Ver.1.04(1) Firmware Update (10/23/15)
    Added Functions
    Added a safety feature that prevents you from selecting the wrong battery type when connected to a balancer. If you try selecting NiMh, NiCd or Pb type battery when a balancer is connected to the charger an error message will be displayed.
    Maintenance Fix
    Fixed LiXX overcharge error
    Maxima SL ver. 1.21(0) Firmware Update
    Maintenance Fix
    Fixed compatibility issues with certain flight controllers and gyros
    Maxima SL ver. 1.20(0) Firmware Update
    Added Functions
    Added lost frames counting function when used with PowerBox system
    Aurora 9X Maintenance Release
    Improved Aurora 9X model data backup function
    HTS-VOICE Maintenance Release
    Fixed Czech language bug
    [FONT="Courier New"]GruÃ? Klaus[/FONT]
