Neue Software 1.024 für MZ-24 Hott verfügbar
  • roxxter78
    • 11.08.2013
    • 958
    • Markus
    • Hartkirchen, AT
    Habe gerade mit dem Firmware upgrade grStudio ein Auto update für meine MZ24 ausgeführt.
    Hier wird die SW 1.024 geladen.
    Leider wird sie derzeit noch nicht auf der Graupner Homepage gelistet.
    Aber ich denke sie wird in den nächsten Tagen noch kommen.
    Was ist neu:
    mz-24, mz-18 Radio Firmware upgrades(v1.021 -> v1.024)
    mz-18 / 24 Release Notes
    â?¢ Changed: When turning on the transmitter and there is an active bind the RF ON/OFF dialog will
    disappear after a few seconds.
    â?¢ Changed: When using a fuel sensor with the General Air Module of General Engine Module fuel
    level is now shown as consumed in ml versus residual in percentage.
    â?¢ Changed: Warning sound and message when DSC port is used in teacher/student mode with
    cable is being disconnected. Control now automatically reverts back to the teacher radio.
    â?¢ Added: Date and time can now be set with the use of Firmware Update Studio.
    â?¢ Changed: THR.POS alarm will sound based on actual throttle channel output and not stick
    position.
    â?¢ Added: ESC key now acts as a BACK button.
    â?¢ Added: Simultaneous pressing of the UP/DOWN keys will bring up the servo monitor screen.
    This will also work on any screen where servo monitoring access is available.
    � Added: Confirmation button when accessing the -Model Sel� menu to avoid accidental model type
    change.
    â?¢ Changed: Voice triggers can now be interrupted. Interruption can either stop or move to the next
    voice announcement.
    â?¢ Fixed: TX OUT SET for RX2 when binding during channel setting.
    â?¢ Fixed: Various screen changes and text improvements.
    â?¢ Added: Separate Vario volume control under FUNCTION/Etc.Set
    mz-24 Only MP3 Player Changes
    â?¢ Added: MP3 player can now be accessed from the main menu pressing the MP3 icon
    � Changed: Display -File NOT Found� is shown when no fil is playing
    â?¢ Added: LEFT/RIGHT keys can now control the MP3 menu
    â?¢ Added: ENT key can now control the PLAY/STOP of the player
    â?¢ Added: UP/DOWN arrows now control the volume
    Der Klügere gibt solange nach, bis er der Dumme ist
  • WoFlei
    • 12.07.2008
    • 1129
    • Wolfgang
    AW: Neue Software 1.024 für MZ-24 Hott verfügbar
    Sie ist als einzelne Datei noch nicht gelistet aber im "automatischen Update" wird sie angeboten.
    Bis bald, Wolfgang.
    • roxxter78
      • 11.08.2013
      • 958
      • Markus
      • Hartkirchen, AT
      Habe ich ja geschrieben.
      • WoFlei
        • 12.07.2008
        • 1129
        • Wolfgang
        Ja sorry, wer lesen kann.....
        Bis bald, Wolfgang.
        • HeliChris1993
          • 21.07.2011
          • 1543
          • Bedburg Hau
          Hey wenn ich das update machen will dann kommt das hier
          Chronos 700 Trex 700 nitro
          • roxxter78
            • 11.08.2013
            • 958
            • Markus
            • Hartkirchen, AT
            Den Usb Treiber cp210 hast du installiert? Verbindung zur Fernbedienung steht?
            • Daniel Schmidt
              • 02.03.2009
              • 6426
              Falscher Com Port evtl...
              • HeliChris1993
                • 21.07.2011
                • 1543
                • Bedburg Hau
                hat geklappt danke hatte einfach die funke nicht an die mus bei dem auto download an sein.
                gruß
                • roxxter78
                  • 11.08.2013
                  • 958
                  • Markus
                  • Hartkirchen, AT
                  gruß
                  na no na ned
                  Aber jetzt hat es doch noch endlich geklappt
