DX10 - Neue Spektrum Sender Firmware 1.05
  • Freeeeak
    • 11.10.2005
    • 464
    • Finn
    • Wolfsburg-Sülfeld
    Hallo.
    es gibt eine neue Software für die Spektrum Sender...
    Habe mal den Text von der Homepage angefügt.
    Spektrumâ?¢ DX10t AirWareâ?¢ Version 1.05 (30 January 2013)
    All AirWareâ?¢ updates have been extensively tested by our internal and external test teams prior to public release.
    Due to the complex nature of the software and the nearly endless combination of setups that are possible, the first public exposure of a new version to thousands of consumers is the most likely time to uncover any undetected issues. As always, the pilot should ensure that all programming behaves as intended in the model.
    This version will erase ALL models on your radio. Before you install this update, you must export any models you wish to preserve. After the update, you need to import them.
    Please do NOT turn off the transmitter during this update process! It may take up to 2 minutes for the update to be completely executed. The progress bar may flash and/or move several times as part of the update process.
    You may find it necessary to reset some transmitter settings after installing this update. The settings for transmitter stick mode may revert to Mode 2, and the stick switch configuration (CLEAR/BACK and Momentary/Toggle) may need to be reset after the update.
    NOTE: If you are using the upgraded sticks SPMA3012, you MUST set the stick switches to the center ("1") position. Failure to do so will result in an incomplete update of your radio.
    Zuletzt geändert von Freeeeak; 12.02.2013, 09:48.
    Diabolo 800+ BE, Diabolo 600 BE, Goblin 770 CE .... VBar+NEO pimped
  • Xantrix
    Xantrix
    Ds mit dem Löschen der Modellspeicher stimmt definitiv!
    Also Sichern nicht vergessen!
    • beershare
      • 03.02.2013
      • 291
      • MFC Freckenhorst; FMG Warendorf und Wildflieger
      AW: Neue Spektrum Sender Firmware 1.05
      Gibts irgendwo ne Changelog wo drin steht, was verbessert oder gefixt wurde?
      Sehe sonst momentan keinen Grund fürs Update.
      Greetz
      Doppelte Power - Doppelter SpaÃ?
      • Freeeeak
        • 11.10.2005
        • 464
        • Finn
        • Wolfsburg-Sülfeld
        Changelog auf der Homepage....
        Change Log
        Version 1.05
        30 January 2013
        New Features & Improvements
        â?¢ In a V tail model, if the Aileron > Rudder mix is used, the V-Tail Differential
        setting is now fully supported.
        â?¢ Reduced exporting for some unused mixes to improve interchangeability.
        â?¢ Added Version Info screen by clicking version on Serial Number screen.
        â?¢ Enabled 2-pos switches (E-H, L-N) as options for CLEAR/BACK/Auto-Trim
        inputs. This enables access to these functions on radios with no momentary
        inputs (that is, the user has installed SPMA3012). Note that CLEAR and BACK
        are disabled on the CLEAR/BACK/Auto-Trim setup screen. If CLEAR is active
        (black dot shown) then other keystrokes can be inhibited.
        â?¢ When changing Trainer mode, settings for Master/Slave channels are always
        preserved.
        â?¢ The default telemetry filename is changed to be based on the model name in the
        same way as it is for saving the SPM files. The name may be edited, and is
        retained through power cycles. It is not exported/imported.
        � Added -Distance to Model� feature for GPS. This calculates the distance from
        the starting point (-Home�) to the model, and the bearing from Home to the
        model. It does not include altitude in the calculation. Home may also be reset to
        the current position by pressing CLEAR on the GPS Status screen. It can also
        generate a max distance warning to help prevent flying too far away. Distance
        alarms may be set in 30m increments (about 98 ft).
        â?¢ The JetCat sensor now may generate alarms on various items reported by the
        ECU.
        Corrections
        â?¢ Enabled UMX telemetry display (AR6400-s with DSMX provide Flight Log data
        but not receiver voltage).
        â?¢ Correctly display data from SPMA9590 current sensor.
        â?¢ Correctly display screen for SPMA9584 JetCat telemetry configuration.
        â?¢ Several minor translation changes.
        â?¢ Corrected a display area for GPS altitude at high altitudes.
        NOTE: Do not revert to older versions after installing version 1.02B or higher!
        • beershare
          • 03.02.2013
          • 291
          Dank dir!
          Hab aber auch gerade erst gecheckt, dass es nur die DX10t betrifft. Hatte mich auch ein wenig mit der Versionsnummer verwundert.
          Besitze nur ne DX8 und dort sind wir bei AirWare 2.06 aktuell^^ Wusste nicht, dass es für jeden Tx ne unterschiedliche Software gibt.
          Bin also nun auch schlauer als vorher!
          PS. Als nicht Besitzer hat man auch keine Chance in die Changelog reinzukommen, oder?
            Ich finde es sehr gut, dass sie das vorher sagen!
            Spektrum halt.
            • Xantrix
              Xantrix
              Spektrum halt.
              Ja, und das mit dem Restore dauert ja nur ne Minute. Hat prima funktioniert.
              • ArguZ
                ArguZ
                Koennte ein Mod bitte den Titel auf DX10 anpassen...Danke
                • mukenukem
                  • 14.11.2010
                  • 11187
                  • Wien
                  Spektrum halt.
                  Wenn man keine Ahnung hat, einfach mal....
                  Könnt ihr bitte vermeiden, diesen Troll zu zitieren, sonst klappt das mit der Blacklist nicht
                  Wird Zeit, daß die FW auch fur die anderen Sender rauskommt. GPS Entfernung zum Startpunkt ist nett, und vielleicht werden ja jetzt die Telemetriealarme richtig angezeigt.
                  Und endlich gibts verschiedene Dateinamen für die Telemetrielogs.
                  ECU heißt übrigens Engine Control Unit (von Turbinen)
                  Zuletzt geändert von mukenukem; 12.02.2013, 14:24.
                  • ArguZ
                    ArguZ
                    AW: DX10 - Neue Spektrum Sender Firmware 1.05
                    Das waer nett, dann kauf ich mir vielleicht auch noch so einen GPSknopf.
                    macht bestimmt Laune im Zephyr
                    • mukenukem
                      • 14.11.2010
                      • 11187
                      • Wien
                      Ich hab schon 3, 1 für die Phönix und 2 für 550/700. Bis jetzt hats nur mit dem Eier-Spielzeug Sinn gemacht. Ich find allerdings, daß sie zu teuer sind. Wer weiß
                      • Henk1
                        • 05.02.2003
                        • 81
                        • Henk
                        • Munstermaifeld
                        Update und Restore ging einwandfrei, hat nicht mahl ne Minute gedauert und alles funkt schon wiede,r ob nix passiert ist.
                        Gruss aus der Eifel
                        "Fliegender Holländer"
                        DX10t, Genesis, Logo 10, HK450, Blade 130x
