I made a lehrer/schuler cable between two JR 3810 transmitters. I used screened cable and two 3,5 mm stereo jacks.
However the cable does not function properly. It seems that the HF signal from the master transmitter influences the
slave. If i touch some metal parts from the slave transmitter the system works. If i stop touching it, the system fails.
To dangerous to try in flight! What dit i do wrong? Should i use mono jacks in stead of stereo jacks=
Any advise is welcom.
Danke!
