Ein Update mit Model Presets ist draussen!!
Haben einiges gemacht :
Version is 1.04 and our first batch of model presets are now available on the Spektrum community site for download, so check it out.
Model Presets include:
Park Zone Corsair
Park Zone Habu
Avant Aurora-E
Align T-Rex 700e FBL
Align T-Rex 450 pro
Align T-Rex 700e
Align T-Rex 550e FBL
Version 1.04 includes user-requested feature additions as well as corrections. See the readme file below for details. This update includes all previous enhancements and corrections.
DX8 Spektrumâ?¢ AirWareâ?¢
Change Log
Version 1.04
Software Upgrades
â?¢Trim Center Pause - When adjusting the trims through center, the pause was
lengthened to allow the center position to be more easily accessed.
â?¢Knob Center Tone - When adjusting the knob, it generates a "center trim" tone as it rotates through center.
â?¢LiPo Battery Verification - Attempting to change the battery type in the Extra Settings screen from NiMH to LiPo will not be allowed until a LiPo battery is installed. This prevents the user from mistakenly selecting the LiPo battery voltage cutoff with a NiMH battery installed.
â?¢Frame Rate Defaults to 22ms - The Frame Rate now defaults to 22ms rather than
11ms. This prevents analog servo compatibility issues in the default mode.
â?¢AirWare Auto-Update - To guard against inadvertently downgrading the radio's
AirWare, after installing version 1.04 or higher the system will rename the update file to prevent it from auto-loading in the future.
â?¢Startup Screen - The startup is changed so that an inaccurate "No RF Link" warning is not displayed.
Software Corrections
â?¢Heli Mode Trainer Button - If the Trainer button was assigned to a channel in the Switch Select screen, the channel was inactive.
â?¢Flap Trim - When a Flaperon wing type was selected and the right or left trimmer was assigned to flap trim, the trim was mixed as ailerons instead of flaps. It was also not possible to deactivate flap trim once selected.
â?¢Acro Throttle Curve - Pressing the CLEAR button could allow the displayed throttle
curve to not match the values entered numerically.
â?¢German Timer - The prompts for the German-mode throttle-based timer controls were renamed so as to be more intuitive.
Throttle = Gasstellung
Throttle 1-time = Motorstart
Throttle Out = Motorlaufzeit
Werd sie jetzt gleich mal testen
