Bell Huey UH-1 composite
  • fokke
    fokke
    hi guys,
    First post around here and hopefully not the last. I've been doing scale Rc work for wuite some time, but mostly in the plane dept. Should you have any interest here are some of my past projects.
    http://www.rcuniverse.com/forum/m_78..._8/key_/tm.htm
    http://www.rcuniverse.com/forum/m_53..._2/key_/tm.htm
    I have a personal preference towards using tin/foil plating on my molds. This method yielded quite high "realism-ratio" on my plane projects, so I decied trying a heli project this time around.
    So i'd like to presnt you my Huey UH1D in 1/8.5 scale, length-143 sm for 60-90 class .
    this is my first steps
  • fokke
    fokke
    AW: Bell Huey UH-1 composite
    Here are several pics of the almost ready for moiulding fuselage body
    Uploaded with ImageShack.us
    Zuletzt geändert von Gast; 29.07.2010, 20:39.
    • fokke
      fokke
      this is my assistant ( my daughter)
      ImageShack.us[/URL]
      • HeliRaven
        HeliRaven
        Hello,
        it looks like you really know what you`re doing
        Will you take out the interior shape to make the heli fly some day or how will you go on with this?
        Only the metal moulding would be to thin and unstable, i guess, so what will you do inside?
        Keep us posted!
        Greetings
        Manu
        • fokke
          fokke
          Thanks for the comment Manu ,Now I'll post several other pics and you will understand what is the idea Yes I'll make the mould for the composite fuselage
          • Jürgen F.
            • 26.11.2008
            • 2625
            • Jürgen
            • 59174 Kamen
            Hi Rumen,
            fantastic job, fantastic helicopter, i've never seen anything like that!!
            I hope to see some more pics soon, now i have to hide my own Bell helicopter
            Bauberichte auf http://www.Helipoint.de Update 21.03.2017
            • HeliRaven
              HeliRaven
              Oh my god, that looks nice. A whole lot of work and effort you put in this. What mechanic and what kind of electronic will you use?
              • Rossi
                Rossi
                Whow, now we understand your idea
                But that you do that in your flat is really cracy. You must have a good wife.
                Do you want to build this fuselage for sale or only for you?
                What kind of mechanic do you want to install?
                greetings Rossi
                • fokke
                  fokke
                  I"m glad that you like my job guys ,thanks
                  Manu , actually I build airplanes see the links of first post ,this projekt I made for several my friends who whant fly some interesting scale helicopter So I builded it for them ........ one of them will put in nitro mechanic,the other guys electric .
                  hahhaha Rossi yes my wife is a veeeery patient ,but never know ))))))
                  Cheers
                  Rumen
                  Zuletzt geändert von Gast; 29.07.2010, 21:50.
                  • HeliRaven
                    HeliRaven
                    Rumen you are a really good friend (-:
                    • Roger
                      Roger
                      Hi Rumen,
                      awesome...
                      • fokke
                        fokke
                        Thank you very much guys !
                        This is the next part of pictures of process :
                        • ulc22
                          • 05.09.2002
                          • 901
                          • marco
                          • Ulm u. Umgebung
                          Very Very Nice!!!
                          Please post more pictures.
                          Thanks Marco
                          • fokke
                            fokke
                            Thanks Marco , tomorow I'll post more pics and moments of my work .
                            • fokke
                              fokke
                              Hi again
                              The continuation :
                              I made the mould and start with the real composite fuselage.
                              I use 80gr m2 glas for first layer and then 160 gr m2 glas for other layers .
                              I start with the gel coat,I make it my self . All epoxi with I use is a germany EPOXI resine LN1 .....
                              the first picture made my daughter
                              Here I put the gel coat
                              And this is the result of all this work
