Heckservo T-Rex 500
  • spohr76
    spohr76
    Heckservo T-Rex 500
    kann ich dieses Servo nehmen?
    Danke schonmal...
    Gruß Alex
  • spohr76
    spohr76
    AW: Heckservo T-Rex 500
    Daten:
    Turnigy BLS980 Digital Heli Rudder Servo is designed specifically for helicopter rudder operation. This hyper fast digital servo is ideal for tail rotor control on helicopters as well as many other applications requiring the ultimate in response speed, yet still requiring good torque.
    This servo features a Brushless motor that lasts longer and operates at a lower temperature than a brushed motor with 30% faster response times, smoother operation and Titanium gear train with dual XL bearings.
    Compatible with Super Narrow Pulse (760µs) drive.
    Suitable Gyros: Spartan DS760, Spartan Quark, Futaba GY611, GY601, GY520, ALIGN GP700, GP750, Mikado V-Bar Tail, CSM SL720, Curtis Youngblood Mini-G, Solid G, Thunder Tiger TG-7000
    Specification:
    Dead band: 0.0004ms (Default)
    Control System: +Pulse Width Control
    Working frequence: 760?s / 560hz
    (RX) Required Pulse: 3.5 ~ 6.0 Volt Peak to Peak Square Wave
    Operating Voltage: 4.0 ~ 6.0 V DC Volts
    Operating Temperature Range: -10 to + 60 Degree C
    Operating Speed (4.8V): 0.04 sec/60° degrees at no load
    Operating Speed (6.0V): 0.03 sec/60° degrees at no load
    Stall Torque (4.8V): 2.5 kg.cm (34.7 oz/in)
    Stall Torque (6.0V): 3.1 kg.cm (43.0 oz/in)
    360° Modifiable: NO
    Motor Type: Brushless Motor
    Potentiometer Drive: Indirect Drive
    Bearing Type: Dual Ball Bearings
    Gear Type: Titanium Gears
    Programmable: NO @
    Connector Wire Length: 24.0 cm (9.40 in)
    Dimensions: 40 x 20 x 40 mm ( 1.57x0.79x1.50 in)
    Weight: 58.0 g (1.97 oz)
    • don_king
      • 23.11.2009
      • 2743
      Kannst du, wenn dein Gyro oder FBL-System Servos mit 760µs Neutralimpuls ansteuern kann...
      • spohr76
        spohr76
        brauche aber dann den halter vom 600er, richtig
        • Chorge
          Chorge
          Ich verwende das Servo im 550er (Microbeast)... Geht super! Brauchst den 600er Halter, richtig! Im Protos läuft derzeit das BLS251 - eigentlich bin ich nur zu faul, die Servos zu tauschen. Das Turnigy ist schneller aber schwächer, und somit im kleineren Heli besser aufgehoben - das BLS251 ist etwas langsamer, aber stärker, und somit besser für den größeren Heli. Zum Glück wissen die beiden Servos dies nicht, und funktionieren daher in beiden Helis top!
