Futaba 9252 on Trex600 FBL
  • sapca1
    sapca1
    Can I use the futaba 9252 servo's on the Trex 600 esp FBL *?
    Gr.
    sapca
    PS : You can answer in German,I understand bud can't write it
  • Mini Titan
    Mini Titan
    AW: Futaba 9252 on Trex600 FBL
    YES, you can. But BLS-451 are better.
    If you have thoose servos still at home, you can sell it and then buy the BLS.
    The advantage of the BLS is that they will life 5 times longer.
    Yours ULrich
    • sapca1
      sapca1
      I know there are better servo's at this moment.
      The power of the 9252 is oke, bud the speed *
      I see that the servo's 0.14 sec @ 4.8V on 60deg
      I gone fly them @ 5.5V !!!
      Gr
      sapca
      • zab
        zab
        • 20.01.2006
        • 338
        • Claus
        • MFCO homebase Oberottmarshausen
        we use the 9252 om 2 identic Rex 600 with AC3X since more than 150 flights each. We have absolutely no problem.
        Best regards
        Claus
        P.s. The gear box is absolutely cheap. In "worst case" the replacement cost you only 5 Euro.
        Nur der Kleingeistige behält Ordnung, das Genie überblickt das Chaos
        • sapca1
          sapca1
          Hi Claus,
          That's the answer I liked to hear
          Gr
          sapca
