First sorry for my englisch, but i can't write German.
You may answer in German, because i can read it
I'm currently flying a t-rex 600E with ac-3x.
Now I'm going to buy a logo 6003d and use the ac-3x in it, and I'm wondering where you guys placed the ac-3x?
I could place it on the gyro platform, but I think the elevator servo would be in the way?
I guess since the black box of VBar fits, the other one will fit, too. Just bear in mind that the upper rc deck is not level in relation to the rotor disk but slightly tilted forward (if I'm not completely wrong ...). But that should be easy to check.
There should be a longer wiring harness available, so you could use the lower rc deck instead.
Hello,
he is right, to put the AC-3X on the upper platform. So is guaranteed that one can help it also still. Just for the first flights that one is very important.
Would it be a problem when I mount the ac-3x of axis like in this picture?
or would the cables just co pas the elevator servo when I mount it in the center.
I only put the cables going round the reciever an not between AC-3X and reciever, so they do not have contact to the AC-3X, caused in vibrations reduction to it.
My reciever is bigger, so i mounted it standing up.
