I have the AC-3X in my MP-XL-V91, and I love this small peace off electronic art!!
Bud,
I have a problem with the heck gyro from the AC-3X, the BLS 251 (servo type 3) is drifting slowly!! The higher I put the Integral factor the faster it will drift,
also the more system gain I Giff the faster the servo will drift, when I put the Integral factor to 0 it stops drifting.
I tested the gyro with a Futaba S9254 (servo type 1 and 2) with the same result (drifting!!), so I am sure the BLS 251 is OK.
This is with 0% input in the display, and no trim used in the transmitter (Futaba T12FG)
All this is with the engine off!!
The tail also drifts slowly when flying!!
I can understand that the tail drifts because off vibes from the engine, bud
what I like to know is if its normal that the tail drifts when the engine is off ??
Before the AC-3X I used the 601 gyro from Futaba, that gyro never had this problem, and was rock steady.
Grub,
Mario
